Engine Problems - 456 GT | FerrariChat
Discussion in '456/550/575' started by Higgins23, Sep 20, 2004.
  1. Higgins23
    Higgins23 Karting
    Jul 16, 2004
    179
    Europe
    Are there any common or known engine problems with the 456 GT (cambelts slipping, valve problems, etc). Would appreciate any insights. Thanks Higgins23
  2. F456 V12
    F456 V12 F1 Veteran
    5,264
    Coto de Caza
    Christian
    I have owned my 456GT for over 4 years and the engine is rock solid and bullet proof IMHO. The only thing I have done is the service requirements and had to change one A/C belt that broke.
    Check out this link for other owners inputs,
    http://ferrarichat.com/forum/showthread.php?t=29797&highlight=456+A%2FC
    MB
  3. Bmyth-FDC
    Bmyth-FDC F1 Rookie
    Oct 4, 2002
    2,742
    Southern California
    Byron
    The only thing I've known of is that the engines tend to run hot... I just got mine back from the shop for a full tune-up... other than the O2 sensors acting up and a slight adjustments on my windows, the only thing I had to replace were the engine mounts... There are 3 known fixes for the engine running hot (approved by FNA) and only one of three don't require mechanical fixes to the car...
    Other than that, I'm with MB - the car is solid.
    Byron
  4. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,952
    The Cold North
    Tom
    Never seen anything go worng mechanicly with an engine in a 456. Very well built and tough unit. Like others have stated though they do run hot but as along as BOTH your fans are working really not a big issue...unless your stuck in traffic in 100 degree heat with the a/c running full tilt..then you in trouble in anycar.
