Engine Question? | FerrariChat
Engine Question?
Discussion in 'Technical Q&A' started by jwbest, Jan 2, 2009.
  1. jwbest
    jwbest Rookie
    Oct 14, 2008
    23
    Southeast
    Walt
    I tried this question in the 360/430 section with no replys (so it must be really dumb). Why does the 2006 F430 have 40 valves and the 2007 have 32v? Also, can anyone tell me the front clearance on the F430? I have a bump in my driveway and garage and want to make sure this is not a problem. Thanks in advance...
  2. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    Everything I have found says the F430 is a 4-valve per cylinder engine. Thus, 32 valve DOHC.
    Can't answer about ground clearance.
  3. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Where did you get that info from Walt? :p:p
    ALL 430's have 32 valves mate. :):)
    Ground clearance is pretty good in the 430. I cant confirm a number for you, but someone should soonn tell you what the clearance is. :)
  4. SonomaRik
    SonomaRik F1 Veteran
    the 355 had 40
  5. Rifledriver
    37,099
    #5 Rifledriver, Jan 2, 2009
    All 430's had 4 valve motors. Anything you might have read to the contrary was incorrect.
  6. jwbest
    jwbest Rookie
    Oct 14, 2008
    23
    Southeast
    Walt
    I am considering an '06 or '07 F430. I was looking at a (non Ferrari) dealer site and the '05s are described as SOHC 40v, the '06s are DOHC 40v and the '07s are DOHC 32v. I was confused why this is. I guess it is just incorrect from the dealer. Thanks for the input!
  7. tazandjan
    39,167
    Walt- The 355 and 360 had five valves per cylinder and the 430 (all of them) had four, as did the late model 12 cylinders. Optimum breathing with four valves or simplified mechanicals compared to five valve heads? Who knows? The 430 and 599 did do away with the cam belts, so progress is being made. The last SOHC Ferraris were the 365 GTC/365 GT 2+2. The Dino 206/246 GT and 275 GTB/4 and later cars were DOHC.
    Taz
    Terry Phillips
  8. Stew
    Stew Formula Junior
    Apr 16, 2006
    547
    Los Angeles
    I heard PAP had 6 valves. 4 for him, 2 extras for the ladies !
    Regards,
    Stew
  9. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Lol! Cheers Stew! :p:p
  10. cuneo
    cuneo Formula 3
    2,469
    #10 cuneo, Jan 5, 2009
    I thought just the 355 has 5 valves per cylinder, the 360 has 4, 348 has 4, 430 had 4? That's supposedly one of the reasons the 355 sounds the best out of all, no? :)
  11. SonomaRik
    that begs to ask, How many for intake and how many for exhaust :D
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    +1
    I've had a 348, 355 and now 360 and for sure, the 355 sounded the best. Your valve counts are correct, and they're all DOHC, so this comment, from a *dealer*, no less, warrants an "outing" IMHO :)
    OK, on re-reading the above, at least it wasn't a "factory" dealer putting out the BS......
    Cheers,
    Ian
  13. Rifledriver
    37,099
    Hey guys, the 360 has 5 valves.
    5 valves, 3 valves, whatever, has little to do with the noise it makes.
    Forgive me for injecting correct info.
    I will leave now.
  14. BigTex
    79,380
    Houston, Texas
    Bubba
    You'll have to repave/regrade the driveway....megabuck 430 owners just have to take these issues in stride, maybe renovate the garage also, with about $60K in swank cabinets, epoxy floor paint, and tools....:rolleyes:
  15. BigTex
    79,380
    Houston, Texas
    Bubba
    It's not the number of valves that counts, but the fact you don't drop them behind you onto the highway.........
  16. tazandjan
    39,167
    Brian- Thanks. You have taken off the heads and seen five valves per cylinder yourself. I just read it in magazines. I did get to look at the weird camshaft profile of a 355 yesterday (assume 360 is similar) when I dropped by my local shop. They had just pulled the engine for a major, including new Hill Engineering tensioner bearings for the belts. Camshaft lobe profiles completely different from anything I had seen before.
    Taz
    Terry Phillips
  17. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Oh ****! Where is the "very embarrassed" icon?..... Crawls under rock and hides.... It seems I don't know how many valves are in the friggin' thing..... I humbly apologize and will now retire to re-read my owners manual. [Again.]
    I was sure only the 355 had 5. Sorry!
    Cheers,
    Ian
  18. Rifledriver
    37,099
    Its ok Ian. For a Gin and tonic in VC all will be forgiven.
  19. tazandjan
    39,167
    Ian- You really cracked me up on that one. The other thing that was funny in this thread is three intake valves changing the exhaust note. Brian has heard this all before multiple times, no doubt.
    Taz
    Terry Phillips
  20. SonomaRik
    naw, not the 3 intake making that noise...it's the two exhaust making that noise :D
    which BTW they all seem to have......
    best gin.... junipero serra gin hands down IMO
  21. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #21 Fast_ian, Jan 6, 2009
    Fortunately, I never made any "claims" as to *why* the 355 sounded the best, just that it did ;)
    [I got more "I assume that's a Tubi?" comments on that car than any other - It wasn't btw.]
    Cheers,
    Ian
    PS - Multiple G&T's @ VC should cover the embarrassment. [Junipero Serra it seems - Hopefully stocked in the G.H.H. They did stop carrying draft Guinness last year, which sucks :( ]
  22. Rifledriver
    37,099
    You really make an interesting point though. Many don't really ever think about it but a good deal of the noise a motor makes is intake noise especially if the intake isn't muffled. Listen to an F1 car passing you. Some make more noise approaching than leaving. Pretty much all cars employ some sort of muffling on the intake. An air filter alone does a good deal of it. I used to have a Datsun 510 with a 200HP 1800 in it. It had a very free flowing but quiet exhaust on it but the Weber 45's with velocity stacks were loud enough to get me some tickets for excessive noise when measured with a meter. They used to do that on the roads approaching Laguna Seca in the old days and would have a whole line of cars pulled over getting tickets for loud exhaust.
    I tried to explain it wasn't the exhaust but they didn't care.
    Couldn't hear the radio in that car over the carbs.
  23. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :D
    Brings to mind the Ford Cortina "wagon" (!) my cousin owned - We popped a Lotus twin cam in it for use as a tow bus. Lotus "headers" feeding the stock exhaust. The *only* thing you could hear was those 45's sucking...... [And a lovely sound it was IMHO :)]
    Cheers,
    Ian
    PS - It met a sorry end - I figured it's failure to start one morning was due (as always) to Lord Lucas' execrable electrics, but upon opening the hood discovered someone had *stolen* the entire top end - I was looking at piston crowns! :(
  24. tazandjan
    39,167
    Brian, Ian- I am at the other end of the scale with the Novitec exhaust on the 575M. It drowns out most of the lovely intake noise. I just picked up a factory HGTC exhaust (for $399) and should have a good match soon. Nice intake and exhaust sounds. I now have three exhaust systems for the bloody car. Will probably give away the stock system and sell the Novitec.
    Taz
    Terry Phillips
  25. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #25 davehelms, Jan 7, 2009
    Makes for very expensive hot rod regrinds! They had to pack 5 pounds of **** in a 3 pound bag there and I suspect it was a major factor in why the 5 valve system was abandoned. The cost to produce a complex design and the ability to make the same power, different ways with the simpler 4v...
    Outward appearance, it is quire incredible but mount one on a flow bench with a smoke machine and you can see both the genius and a hint of the short comings of the design. I am still fascinated with the concept and the theory. As soon as I have the finances in place, thin the current crop of projects and get the nod from the boss I will find a project car and start playing with these a bit more.
    My camshaft development guy and I have discussed this many times (involved a great deal of moaning on his part) but have some ideas that I believe hold water. I suspect I will end up with the engine cradle Dzus fastened to the car as many times as that engine will come out before a successful combination is attained. My biggest fright is loosing the exhaust note they have.
