engine removal on 348 question | FerrariChat
Discussion in '348/355' started by 2mmuch, Oct 29, 2015.
  1. 2mmuch
    2mmuch Formula Junior
    326
    Ontario
    Luigi
    Is it possible to remove the engine out the top and not from the bottom. I was just about to start doing my engine out over these next few cool months here in Canada and was wondering if anyone has pulled the engine out the top. I have a four post lift and was trying to avoid hanging my car out the front of my garage if I didn't have to.
    The other thing I was thinking was building a couple of steel L-posts that I could slide in on the sides then lower my hoist leaving the car up and lowering the engine down with the hoist.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2 2NA, Oct 29, 2015
  3. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Yes, a package deal.
    Nice stand too.
  4. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Tim and Wade are the ultra experts. The thing to grasp is that the engine and tranny is mounted in a frame which can only be removed below the car. When you open the lid and look down at the engine you may think that there is room for it to be lifted - illusion, the whole issue must be removed from below in its frame...........
  5. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,268
    Worcester, England
    Phill J
    It would be a complete pain in the a:censored:e to try to take the engine out from the top.
    The engine subframe will not clear the engine bay opening so you would have to leave the subframe in the car and lift the engine off the frame - However, the gearbox will not clear the rear chassis members on the frame so you would have to separate the gearbox from the engine, etc., etc., etc.
    Trying to take the engine out from the top is a bit like trying to reinvent the wheel - You're just making a comparatively simple task a thousand times harder for yourself!
    Considering that you're taking the entire drive-train out of car, to be fair to Ferrari, they did make it as relatively simply as anyone possibly could!
  6. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Yes, you could, no you should not, unless you're a masochist.
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Yes, Wade Williams at Ferrari of Atlanta (foatech) and the other Wade at Sport Classic & Competition (308nut), those guys know their stuff.
  8. 2mmuch
    326
    Ontario
    Luigi
    Thanks guys. Out the bottom we shell go.
