Engine RPM idle reading on 355 | FerrariChat
Discussion in '348/355' started by 355Blue, Aug 28, 2010.
  1. 355Blue
    355Blue Rookie
    Apr 8, 2010
    29
    Hello,
    How stable should the idle engine RPM reading be on the 355? 1000RPM +/-? is it normal to have a 50 to 100 RPM fluctuation in the tachometer?
    Thanks,
    355Blue
  2. f355spider
    f355spider F1 World Champ
    18,044
    #2 f355spider, Aug 28, 2010
    25 to 50 rpm probably what mine does on occaision...100 might be a problem. I had some fluctuation once, and noticed if I fiddled with the MAF sensor connection or cleaned it, then the idle would be stable for several days or weeks. I later had the local dealer replace the female pins on the MAF connector and that fixed it.
    Does it coincide with the radiator fans coming on? That is, does the idle drop as the fans come on?
    If you have idle drop with the fans coming on, then you will need to replace both fans: http://www.ferrarichat.com/forum/showthread.php?t=284513&highlight=355+fans
  3. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I would think that the Idle Air Control motor, if working correctly, should compensate for the drop in rpm caused by the heavy electrical load and bring you back to normal idle speed.
  4. f355spider
    18,044
    #4 f355spider, Aug 28, 2010
    You'd think, but it has been repeatedly shown not to respond that quickly. Owners have literally had the car almost stall. I have never experienced it myself, but several have described it here on this forum and corrected it by installing new fans.
  5. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Isn't the IAC what blips the throttle during shifts on the 355F1?
