engine running at very reduced power | FerrariChat
Discussion in '456/550/575' started by byronmallen, Nov 9, 2015.
  1. byronmallen
    byronmallen Rookie
    Aug 16, 2014
    5
    friendswood, tx
    byron m allen
    drove my 1995 456GT 2 weeks ago, it ran perfectly. I drove it yesterday and it is making 1/2 or less power, no codes, no fault indications. This happened once before when I took it to a shop for complete oil seal change and when I got it back, it ran perfectly. The shop said they did nothing to fix it. Thinking an ECU quit but if it did, it was turned off when it happened. Could be a bad connector? HELP!!!!
  2. MotoMeccanica
    MotoMeccanica Formula Junior
    450
    Canada
    It's happened on mine, MAF connectors......a couple pins had corrosion on them.
    Scott
  3. TZ 750
    TZ 750 Formula Junior
    Jul 18, 2009
    912
    Crank angle sensor: $120
  4. tazandjan
    39,175
    Byron- Take it to somebody who can diagnose it properly.
  5. MoeD
    MoeD Formula 3
    Aug 1, 2007
    1,278
    Moe D
    Happened to me after a major service once- They forgot to connect throttle cables properly
    Sounds dumb, but you never know...
  6. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,438
    Yes, try the basics first.
    1. MAF connectors.
    2. Crank position sensor
    3. Fuel Pump/Fuel Filter (you could have blockage from the disintegrating rubber gaskets/holder inside the tank)
  7. byronmallen
    byronmallen Rookie
    Aug 16, 2014
    5
    friendswood, tx
    byron m allen
    thanks to all, the Ferrari mechanic says it was a corroded fuel pump relay which shut down the fuel to 1/2 the engine. Picking it up tomorrow. I think I'll go through all the connectors and clean them.
  8. tazandjan
    39,175
    Byron- I love a happy, and inexpensive, ending.
