Engine serial number | FerrariChat
Discussion in '458 Italia/488/F8' started by 488 owner, Jun 25, 2020.
  1. 488 owner
    488 owner Rookie
    Jun 25, 2020
    10
    Not interested
    I see on the owners manual where the engine serial number is about located but I have just a couple questions.
    Will I need to put it on a hydraulic lift and take off the bottom to see it? Can it be seen from above? I cant seem to see it by just looking from above. Will I need an extended camera?
    If I need to take off the bottom, do I need any special tools? Anyway, sorry for the barrage of questions!
  2. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    As far as I remember, you can see it just looking down into the engine bay. At least on the 360 I believe that was the case. I would think on the 458 it would be a similar situation.
    As I remember, the manual makes it look a little worse than it actually is, location wise.
    This link might help:
    https://www.ricambiamerica.com/where-is-my-assembly-number/
    Oh actually that's assembly #, sorry. Nevertheless, I seem to remember it's visible from looking down into the engine compartment with a flashlight. I might be wrong.
    Ray
  3. RayJohns
    RayJohns F1 Veteran
    7,940
    West Coast
    Ray
    I dug this up out of the service manual. It appears to be located near where the motor bolts to the gearbox housing, from what I can tell.
    Ray
  4. 488 owner
    488 owner Rookie
    Jun 25, 2020
    10
    Not interested
    An update for those interested. It was necessary to put it up on a lift but then it was very easy to remove the access point and see it.
