430 - Engine side cover bolts | FerrariChat
430 Engine side cover bolts
Discussion in '360/430' started by c6vette, Apr 13, 2019.
  1. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    So I removed both parts of the left hand side engine covers to get access to the fuel pump on my 430 and two of the allen bolt heads were stripped out. Had to drill and extract one but the other came out with just pilers. What I'm wondering is what is everybody using for replacements? The bolts seemed extremely soft to me so I am hesitant to replace with stock ferrari part number bolts. I checked the local hardware store and they don't have anything that matches exactly. Anybody have a source for some quality bolts?
  2. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    I just stuck with stock from ricambi. You can put a touch of anti-seize so they don't get stuck again.
  3. Ricambi America
    Sponsor Owner
    E60 M5 likes this.
  4. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    Thanks for the replies. None of mine were in very tight it's just the hole where the allen key fits rounded out VERY easily.
    Ricambi your price is very good on the 20mm bolts but I found the 50mm much cheaper....do you price match? If so I'll order from you.
  5. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    They usually do 10% off for fchat guys.
  6. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Those bolts strips out easily. I have a couple that are in bad shape. I'm in the process of replacing them with titanium bolts.
  7. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    Yea that is why I am reluctant to replace them with OEM bolts. Where are you sourcing the Ti bolts?
  8. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    PM sent.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    I changed mine for stainless ones and spray painted them . I think they are called flange head allen screws
  10. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    The stock oem ones are stainless steel anodized black. I don't know if you used high temp paint but it may not do so well with the heat in the engine bay.
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    #11 mike32, Apr 14, 2019
    The ones holding the covers in my 430 were soft enough to be aluminum alloy, stainless allen heads do not turn out like that. The paint has done fine for 3 years as engine bay is not that hot with the capristo blankets on the exhaust. You can find the stainless headed screws on e bay if that is any help. - button head flange screws is the proper name,
  12. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    No offense...I don't like the idea of painted screws. My screws are stainless and I doubt they are aluminum. They weight too much to be aluminum.
    I have titanium ones coming that I will anodize. I also will replace the airbox cover screws along with the diffuser and under tray hardware.
  13. Dicecal
    Dicecal Formula 3
    1,859
    Phoenix, AZ
    Rob
    Same problem on my 430, the factory screws are too soft and strip easily. If someone has a better option, please post!
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Search for button head flange screws on e bay- you can just spray paint the heads. Looks exactly the same as OEM on mine. Use some high temp paint if you prefer but the normal paint is ok
    Yesitsfast likes this.
  15. evilruss
    evilruss Karting
    Jan 27, 2015
    57
    Rockford
    Was just dealing with the same issue trying to get the side covers off to replace the headers on my 430 where the soft bolt heads were stripped by whomever installed them last. I was able to find some stainless bolts without the flange at the local hardware store for the shorter bolts. Installed with the old washers they worked fine, but they do stand out a bit though compared to black. Looks like the flanged stainless bolts on ebay also have some longer lengths available, I may give those a try and pain them black as a more permanent solution.
  16. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I gave up on stock button head bolts and just used a stainless steel 10mm regular bolts.
    I'm OK with plain stainless steel bolt head color as it matches my Kline Innovation Exhaust.
    Now its so easy to remove my side panels.
    Yesitsfast and Flea7 like this.
  17. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    919
    Georgia
    Mark Gronsbell
    Lots of black stainless pieces available from the UK. Google is yor friend.
  18. 24000rpm
    24000rpm F1 Rookie
    hi, Daniel. As i have observed ,the 430 spider screws are totally different than the coupe ones.
    Can you do a little more research onto the spider screws? I think the one on your website is incorrect , what it lists is a washer ( https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/430-group/f430-spider/shields-outside-finishing.html)
    The pic attached is what I observed on 2x 430 spiders, which are 2000 miles away from each other and the owners don't know each other.
    They all look like this so I think this is the screw that came from factory. Not only it is not 20mm , it has a bigger hex than the coupe version.
  19. 24000rpm
    24000rpm F1 Rookie
    on another front, as I have observed on at least 3x F430 coupes( euro market and chinese market, though), securing the engine panels are 3 types of screws
    1. the 50mm one
    2. the 20mm one
    3. somewhere in the middle, i am guessing 30mm. This screw is needed for 1 on each side, for the position where the larger panel meets the smaller panel.
    can you do a little more research on this as well, as on the website it lists only 2 types
  20. 24000rpm
    24000rpm F1 Rookie
  21. Ricambi America
    Sponsor Owner
    218200 is 5x30 We don't stock it.
  22. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Those engine bay screws will just keep on stripping out.....and corrode. They are too weak for the application.
    I replaced mine with stainless steel bolts.
    Will replace it soon with Titanium bolts for even lighter and better look.
  23. treue
    treue Formula Junior
    Jan 22, 2004
    290
    Oklahoma
    Tom Treue
    1. I just stayed with the OEM screws.
    2. Every time I got into something with those oval-head/washer/socket head screws, I applied anti-seize to the treads before re-installing.
    3. Make absolutely certain the allen wrench is all the way down into the socket head. If it isn't the socket hex will strip.
    4. To "restore" an old screw, place the threaded part in a vise with the underside of the screw head resting on top of the vise jaws, lightly close the vise jaws on the threads, then, using a small hammer, tap the top of the hex to "forge" the peened-out top of the hex socket back into place. This should also slightly work harden the socket hex top edge.
    5. It will help to grind your allen key business end flat (eliminating the radius on the end) with sharp end edges so you get a bit more length in the effective gripping ridges (apeces (plural of apex)). This process may also help get a screw with a stripped hex socket out.
    Number 3 is crucial when removing these particular screws.
    Tom
    Need4Spd and MCASEY like this.
  24. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,503
    Honolulu
    Kevin
    #24 Kevin Rev'n, Jun 19, 2019
    PAUROSO, Need4Spd and whatheheck like this.
  25. Matt1984
    Matt1984 Rookie
    Jul 17, 2020
    25
    jupiter, florida
    matthew goodrich
    Hey guys new here, i have a 2006 ferrari f430. Have decided to start to take even better care of my car myself instead of relying on my mechanic. I have a couple questions please excuse my ignorance. the bolts that go to the side panel where the f1 fluid goes what size are they? Secondly the f1 fluid that goes in there is the shell spirax s4 correct. thanks
