Engine Siezed... | FerrariChat
Engine Siezed...
Discussion in 'Technical Q&A' started by shawxhurst, Apr 11, 2011.
  1. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Fortunately not on my 308 but rather on my little 1932 Riley which I've been restoring for the last 10 - 12 years. I need to preface this by saying I hope I'm not breaking any F-Chat regs by seeking advice on a non F car but I need wisdom here as I've apparently done something incredably dumb. Pretend I'm talking about a 4 cyl 500 Mondial if that broadens your comfort zone.
    Anyway, as mentioned, I've been working on this car for quite some time. About 2 years ago I finally got the fully rebuilt engine in and with rudimentary electricals got it fired up. I was pleased, to say the least, with this milestone and moved on to the next checklist item which was doing a complete re-wire using the original type cloth covered wire in the correct colors. Somehow work, home projects, etc got in my way (sound familiar?) and it only occured to me recently that it would be a good idea to turn the engine which is, to my horror, stuck solid!
    "No big deal" I thought. I pulled the plugs and squirted in some oil thinking that it would free up fairly quickly. Nope! Then tried some WD40 because I happened to have it on hand but still no result. I then removed the starter thinking that it might have somehow siezed but of course it hadn't. The car has a handy hand crank at the front of the engine which I had been using but I decided to drop the car down off its jackstands to see if rolling it back and forth would do anything. It will go about a foot before stopping which probably indicates fairly massive slop in the differential and driveshaft but still no engine turning.
    So....My question is what do those of you with great experience recommend? My experience with carburetor rebuilding has been that gasoline left untouched can turn into a very unforgiving varnish-like glue and the fact that I've got new rings in there means there's very little tolerence for a solvent to work through. I realize my question may be sort of along the lines of "what's your favorite car wax" where there will be as many answers as there are wax manufacturors but I can't keep throwing in stuff at random or I will fill the tiny cylinders with primordal ooze very quickly. Thank you in advance for your thoughts and recomendations!
    Steve
  2. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    I had an old Harley when I was sixteen.Single Cylinder Frosen Solid,Took out the plus ,poured Marvels Mystery oil.It set for one Week .Whit enough effort i got hte Piston to move,Try that it can't hurt.
  3. CaptOharry
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    OH MY GOD I FORGOT SPELL CHECK SORRY!
  4. BigTex
    79,406
    Houston, Texas
    Bubba
    +2 for a long soak with Marvel Oil, couldn't hurt....
  5. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Ditto - the stuff actually works.
  6. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    I vote for PB Blaster
  7. BoxerCrazy
    BoxerCrazy Formula Junior
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    transmission fluid will work also
  8. mwr4440
    58,058
    Bavaria, The 'Other' Germany
    Mark W.R.
    Stupid question.
    Are you SURE there was oil in it the last time it ran?
    I have heard of this happeniing and seen the result is why I am asking.
  9. bill365
    bill365 F1 Rookie
    Nov 3, 2003
    3,319
    Chicago area
    Bill
    ...and when you rock the car in gear, use top gear.
  10. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,820
    wisconsin/chicago
    bo
    Try MM oil and compressed air...100psi pushed through a sparkplug hole is a whole lotta motivation...
  11. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    Try the mystery oil first. I heard a mixture of brake fluid and gasoline.
    Ago
  12. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    I would be tempted to use PB Blaster.
    That product has worked real well on rusty/frozen fasteners.
    Then after a week or so, if possible, I would push the car and pop the clutch it top gear.
    If that doesn't work, then you may have to remove the head.
    On an outboard motor we had the rings slightly rusted in the bores.
    I had to pop the head-off in Avalon harbor and with the use of WD-40 and a tap on the piston the engine worked again and we did not have to row the dingy filled with people.
    Best of luck to you.
    Mark
  13. shawxhurst
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Positive. Penrite "running in" oil. In fact we had a bit of trouble getting the oil pump to prime but once that was done got a steady 80 p.s.i. which we were able to adjust easily with the pressure relief valve.
    I'm really kind of astonished by this as I have pulled numerous cars out of barns and fields that had not turned for ages and managed to get them turning without difficulty.
    Also a bit surprised that Marvel Mystery is the solution of choice just because its been around for ages. I would have thought someone would have invented a better mousetrap with high tech chemicals and such. On the other hand, if I had a radiator leak I would immediately put in some Bars Leak which has also been around forever. Makes you wonder about all of those "New" and "Improved" ads we see!
  14. BigTex
    79,406
    Houston, Texas
    Bubba
    You are SURE it's not a starter motor issue......?????
    I have been known to jack a 308GTB and go right to the solenoid with the cables.
    (Well the hood was crushed closed, what are ya gonna DO????) :D :D :D
  15. bill365
    bill365 F1 Rookie
    Nov 3, 2003
    3,319
    Chicago area
    Bill
    If the starter is locked up and the drive is engaged with the flywheel, it could present a serious impediment to engine rotation.
    Aero-Kroil
  16. shawxhurst
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    #16 shawxhurst, Apr 12, 2011
    Tex-
    I'm pretty sure its not the starter because the starter is sitting on my bench - that was my thought also. There is a dynamo at the front of the engine driven directly off the crankshaft. I suppose I should pull that also (kind of a PITA) but I can't really imagine that a dynamo would freeze up. Just in case some of you may not have seen a Riley engine lately I'm attaching some photos. On the exhaust side you can see the hole that the starter goes into just below the voltage regulator. The flywheel teeth are right there and I tryed some prying with a big screwdriver but had to be careful not to break the transmission case. I just checked stock at the auto parts store and they have some Marvel so I guess I'll go pick some up and let it soak for a week or so.
    Thanks for help from all
    Steve
  17. tritone
    tritone F1 Veteran
    7,216
    On the Rock
    James
    Steve-
    Best of luck in solving your problem.....
    and BTW; fascinating, all those lightening holes carefully drilled into the firewall framing.....;-)
  18. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I was thinking about my old erector set girders, actually -
    On a more serious note, this thread made me rather sad. Hope you can free it up with the penetrating oil.
  19. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    An old trick I learnt from an older mechanic...........
    Pour diesel into each cylinder from the plug holes. Leave it for a few days (or more) then place car in first gear and have 2 guys push from the front and 2 push from the back. :):)
    Pretty much rocking the car backwards and forwards vigorously. It will ALWAYS free up the engine he reckons. :D:D
    I only ever did it once and had luck. I think I left the diesel in there a week though and there were only 2 of us pushing on the front. Engine free'd up after a few pushes. :D:D
    After that, drain the engine oil, fill with new engine oil and try start her up. Engine will be smokey till whats left of the diesel burns out from the cylinders. :D:D
    P.S-If the car is an auto, you have to bar the engine over from the front with a REALLY big extension on the crank bolt and hope to not break the crank bolt! :eek::eek::eek::eek:
  20. BigTex
    79,406
    Houston, Texas
    Bubba
    Well ....that's ONE way to know for sure!!!! Sorry..
  21. shawxhurst
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Nothing to be sad about really. All part of the restoration process which has taught me a great deal about patience. I'm always amused by the TV shows that take a car from a wreck to a jewell in 48 hours. It all goes together so neatly on the first try. The reality is that you can expect to take apart anything you've assembled 3 or 4 times to get it right. Then there's always the chicken and the egg issues; "lets see, I can't put in this thingy without this other thingy going in first - but the second thingy requires the other thingy to be in place before assembly"
    By the way, the pierced metal framework was made up to hold the dashboard and "firewall" (made of mahogony!) in their correct place to get the new wiring done in the correct lenghts. It (sort of) duplicates the cowl structure which is made up of english ash wood. So don't be sad - it will be wonderfully satisfying when done and its great to have a resource like f-chat even thought I'm stretching things a bit by asking all to pretend its a 500 Mondial. There's some knocking on my door - OMG its the F-Chat Police!!!
  22. BigTex
    79,406
    Houston, Texas
    Bubba
    "Never take apart anything that still runs".....:D :D :D
    It's just asking for trouble!
  23. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Steve,
    Is your car an Imp?
    KevFla
  24. shawxhurst
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    I wish! Actually its a model they called the "Gamecock" Pretty rare in the U.S. but well known in Britain, Australia and South Africa. Back in the early 90's I drove it from San Diego to Monterey and back - close to 1000 miles. Got the vintage racing bug and ran it for two years at Laguna and could not for the life of me get it to go around that track 10 times in a row. Always something minor, coil goes bad, etc. Finally got so frustrated I decided to pull it apart down to the last bolt. Tex has a point - it WAS running, but very tired in most respects. I went through some agony over the loss of the "patina" but the line between patina and what the Brits call "knackered" is a fine one. When your car becomes too knackered its just a step away from "perished"
  25. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    It's never the bad motors that seize up, they have enough tolerance in them not to. It's the good or overhauled ones that seize their rings or pistons, and such with the smallest of oxidation sometimes.
    A friend had an old Renault (10 I believe, mid-60's) that had been sitting idle for 15 years or so, less than 5k driven from new. Engine seized solid, totally, no external violence would free it. Took it completely apart, all four pistons rocksolidly seized in their sleeves. Two we managed to free up eventually but two others did not, not even in a 2.5ton press. We didn't have a better press so we gave up after that. Funny was that the two we did free up hardly showed oxidation.
    After two years or less, yours should not be that bad. Rocking it etc, can be tricky I guess with these old beasts. You might break stuff you don't want to break. Soaking it should work and if not, are head gaskets hard to come by?
