Engine Siezed... | Page 2 | FerrariChat
Engine Siezed...
Discussion in 'Technical Q&A' started by shawxhurst, Apr 11, 2011.
  1. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Quite easy actually. Available from the Club - the Riley Register and numerous other vendors for about 30 quid ($50 US). But if I need to take the head off then what? I think I would then have to pull the pan and remove the rod bearing caps. Then stick a piece of wood into each cylinder and bash on it with a stout hammer. Funning thing is that pulling the head and scraping out accumulated carbon was common maintenance back in the day. "De-coking" they called it and it was pretty much the Riley version of Ferrari timing belt replacement in terms of frequency and headache value.
    "Not to worry" as they say. I'm 99.9% sure that soaking, rocking back and forth and prayer will solve the problem within a week or so without breaking any rings. If not, I'll move on to the PB Blaster!
  2. BigTex
    79,406
    Houston, Texas
    Bubba
    Ferraris that were slogged around at low speeds often required de-coking too.
    I once had an old geezer recall the memory at a local Texaco gas station where I took my 308GTB flats.
    They'd plug them too, if I PROMISED to remember the tire was then 'derated'!! :D
  3. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Yup, if soaking it doesn't help, then I would say inspect it, either with a endoscopic device or just remove the head and see what you might find. If you manage to free it up while it has corrosion in the bores, it could be that you damage the cylinder walls running it... that's why I would advise you to inspect the top end thoroughly. It could well be that just the moisture from the initial startup has caused some corrosion that easily irons out with a light hone, preventing further damage. Otherwise your engine if off with a bad start.
    It must be that, or the bearings seized because of improper tolerances. I would say removal of the head is the least you should do and then decide on further steps, including possibly tapping the pistons out as you say.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    You aren't attempting to turn the engine over with the spark plugs in place, are you?
    Seems like your next step might be to hook up a block heater for a while, to heat up the coolant in the water jackets. That MIGHT help to unstick the rings, if that's the problem.
  5. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
    Just throwing this out there as it popped into my head after reading all of the posts, it maybe completely off target, but...
    What if there's nothing wrong with the motor? Is it possible that something may be jammed between the flywheel and the bellhousing locking the two together (like a pressure plate/throwout bearing finger), preventing it from turning over?
  6. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Hi Steve,
    How did things work out? Engine freed-up now?
    KevFla
  7. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    So heres an old old solution to a rusted or stuck motor. Coke Cola. Yes the real thing!!!!! pour it in the cylinders and let it set for a few days and presto it will losen up the pistons on the bores. It will work for head studs/bolts. Its the damest thing but it works. I have used this remdy on many of my severly rusted piston bores in my brass era car restorations and it works. I learned this from the best sorce a young man could have, his father.
    Howard Musolf
    1981 308gtsi
    1982 400i Cabriolet
    1987 Lotus Esprit Turbo
    Mserati Spider
    2 many brass era cars.
  8. BoxerCrazy
    BoxerCrazy Formula Junior
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    Yep, i have let rusted bolts and washers sit in a little jar with enough coke-cola to cover them, gets rid of that rust real nice.....
    doug hunt
  9. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,899
    So, just think what it does to our bodies!
    But, if it works...
    CW
  10. BoxerCrazy
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    i know, thats why i had to quit drinkin soda's, only water for me now, and some gatorade when im out on the boat and its goin past 95 degrees!!! [oh ya some beers too, but only on saturdays!!!]
    my friends drink diet soda's, but i tell them they are just as bad as regular soda's in a different way, just stick to water
    doug
  11. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Besides rotting your teeth, coke is VERY bad for you. :D:D
