Engine silver finish | FerrariChat
Discussion in '308/328' started by 3px19, Jul 3, 2024.
  1. 3px19
    3px19 Karting
    Aug 29, 2006
    218
    Calvin crouch
    Have the engine out and am cleaning things thoroughly as I progress. What I noticed is that some of the silver finish on many parts, ie block ,intake manifolds etc has been worn away. I wan to touch this all up and this begets the question of what the finish applied at the factory was, it doesn't look like anodizing. Anyways what should I use to spruce it back up, engine paint? Please on whatever you recommend state manufacture and color if possible I should utilize. I expect regular paint wouldn't have the heat and fuel resistance. Thanks. Cal
  2. Rifledriver
    37,105
    On the V8s they used nothing. Its bare aluminum.
    Hannibal308 likes this.
  3. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    744
    Omaha, NE area, US
    Steve
    #3 bitsobrits, Jul 3, 2024
    [QUOTE="Anyways what should I use to spruce it back up, engine paint? Thanks. Cal"[/QUOTE]
    On almost all the alloy castings (trans, block heads), I just went for super clean with some Scotchbrite pad work were there was some staining. Belt covers and intake were low pressure bead blasted with ACF 50 oil to finish. The only parts I painted were the cam covers, which I shot with Eastwood Alumablast paint, which gives a durable, slightly textured finish that looks very much like sand cast aluminum. Because of that textured finish you can't just wipe it down, but it cleans up well with some Simple Green and water rinse.
    The cam cover in the photo was a NOS die cast (smooth surface) piece which I prepped by low pressure glass beading the external surfaces before painting.
    ProvaMo, waymar, bjunc and 2 others like this.
  4. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    393
    Julio Saiz
    Bear in mind that 308s american versions have different cam cover finish than the european version.
    AND on top of that rear and front cams finishes are different from each other, in the american version.
    My advise is that you just clean them with non agressive method. And no paint at all.
    Sergio Tavares and Newman like this.
  5. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    While Brian is correct, some choose the easier way and I find that Duplicolor DE1650 Cast Coat Aluminum precisely good at imitation aluminium colors and texture.
    If you select paint, please take a look at this lustered one
  6. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Copper wire brush and simple green to clean, then scotchbrite and mother’s to get the aluminium looking great.
    3px19 and Rifledriver like this.
  7. Rifledriver
    37,105
    The North American 2 valve motors have a sand cast valve cover on the rear bank. All other valve covers are die cast.
  8. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,671
    Argent/Brasil
    Guido
    Nice video how to paint an engine (512TR)....
  9. Rifledriver
    37,105
    #9 Rifledriver, Jul 23, 2024
    Chains to lift a Ferrari motor? Little wonder it needs restoration. Lifting it by the intake manifolds? These guys are morons.
    They didnt disassemble the intake manifolds before painting. They painted right over the special hardware, and the old wrinkle paint? Then they hand paint the cavallino which is just bare aluminum. See the runs and sags in the paint? And this video is supposed to showcase the work they are so proud of. Thats pretty sad.
    I have seen better work in high school auto shop classes.
    Nice video in making it look like a junkyard steam cleaner/rattlecan restoration.
    Du_Man and ggjjr like this.
  10. theunissenguido
    Jan 21, 2004
    2,671
    Argent/Brasil
    Guido
    Brain, I was thinking likewise...would not hold it back for the forum.
