Engine stand | FerrariChat
Engine stand
Discussion in '308/328' started by Nabga, Sep 1, 2020.
  1. Nabga
    Nabga Rookie
    Oct 31, 2017
    17
    CT
    Barry Enis
    Good evening....
    Finally removed the heads using puller found on this chat site!!!
    Next question is the engine stand
    Does the 308 engine mount like a USA V8 or is there special adapter for the center of the block
    Thank you in advance
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I used a standard engine stand I purchased at NAPA. No special adaptors required.
  3. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    The studs are long and slender so I used a wooden “I” support under the opposite end of the block from the stand yoke. From memory some 1” tubing spacers were also required to mount firmly to the yoke.
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I'm not sure what you are doing, but a regular engine stand works only if you remove the bell housing/transmission. If that's not part of your plan, making up a cradle that picks up the four engine mounts is pretty straightforward.
    Pero likes this.
  5. Pero
    Pero Formula Junior
    Apr 22, 2011
    825
    Sweden
    Peter R
    I used two wheel dollys and built a wooden frame on top of them. Can move it around in the garage.
    Picture not that illustrative.
    /Peter
  6. Pero
    Pero Formula Junior
    Apr 22, 2011
    825
    Sweden
    Peter R
    To clarify, each dolly has four wheels....
  7. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    The factory stand attaches to the triangular mounting points on each side of the block after transmission/sump is removed. If you are a handy welder you could build your own.
  8. miked
    miked Formula Junior
    Feb 7, 2001
    912
    Cincinnati, Ohio
    Here is a auto rotisserie that I built that also works as an engine stand. I used it for my Oliver tractor diesel rebuild, it has side mounts similar to a Ferrari engine. The position of the engine can be moved relative to the center of rotation, once aligned the 700# engine rotated easily.
    Pero likes this.
  9. BLACK HORSE
    BLACK HORSE Formula 3
    1,976
    California - Bay Area
    Rob
  10. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Very nice! Wish I could weld.
