348 - engine start trouble | Page 3 | FerrariChat
348 engine start trouble
Discussion in '348/355' started by marc556, Jun 28, 2022.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Cold:
    - when i start the engine without touching the gas pedal, RPM are very low and a lot of vibrations. - does it immediately smoothen out if you then touch the gas pedal?
    - When i start the engine when i push the gas pedal (a very few), it starts perfectly. - and does it idle correctly thereafter?
    Hot:
    - when i start the engine without touching the gas pedal, it tries to start but do not.
    - When i start the engine when i push the gas pedal , it starts after a few seconds. -
    I wouldn't worry about having to press the accelerator somewhat during hot starts as it is a fairly normal procedure. I wouldn't worry either if the answers to all of the above "red" questions is "yes".
    The "don't touch the accelerator" applies mainly for cold starts and also in the case of the ECU controlled IAC-s, like the ones on the 2.7. What you have a re some kind of mechanical idle control devices that appear to sense intake vacuum based on which they "decide" how much to open or close the bypass air. Perhaps they are a bit tired and need a bit of push on the accelerator to make them establish the kind of "equilibrium" between the intake vacuum and opening of the bypass.
  2. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,339
    Atlanta, GA
    Steve D.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    That's exactly what I was going to say, turn them out 1/4 - 1/2 turn max and do ecu reset and see if that helps. If it does rebalance the 2 sides with vacuum gauge.
  4. steved033
    Apr 12, 2017
    10,339
    Atlanta, GA
    Steve D.
    I don't have any IAC on mine, and my bypasses were gunked up. Helped a ton.
    sjd
  5. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
  6. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Our discussion is very interesting, sept by step i’m Learning how the engine works.
    Could you explain how to rebalance the two sides with a vaccum gauge?
    Where to connect it and what vaccum gauge may i have to buy ?
    To should be nice to know that.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    its in the workshop manual, do you have it?
  8. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    I only have a part of it
  9. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Top thank you
  10. Qavion
    Qavion F1 World Champ
    14,520
    Ian Riddell
    How long was there between the service and your start troubles?
  11. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    6 months I drove my car 2 times after the service.
  12. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    So if i understand well, the bypass is the N.2 part on the picture (one on both side).
    May I clean it (and all the pipes) with brake cleaner spray ?
  13. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Sorry for this (maybe) stupid question, but what do you call bypasses and how did you clean them ?
  14. Qavion
    14,520
    Ian Riddell
    Bypasses are shown in post #52.
    I imagine you would need vacuum gauges before you decided to disassamble these? Note the "do not touch unless you know what you are doing" yellow paint :D
  15. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    ok, now i understand.
    I shall open 1/4 on each side and check after an ECU reset.
  16. m.stojanovic
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    If you decide to remove the bypass adjuster screws for inspection and cleaning, first screw each in until stop and record the number of turns from their original positions. After cleaning, you can then put them back where they were.
  17. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    yes, of course !
  18. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    When i left my office This afternoon, i went to the garage where my car is.
    My idea was to clean the by-passes.
    I’ve checked the toolkit but the right wrench was not there, so it was not possible to do the job.
    It will be done tomorrow.
    I started the engine and....... very strange, it started correctely, without the gas pedal !
    What is different from sunday ???? Just the air température (hot wheather today), from 25 to 31°C
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    problems like this often come and go and are not consistent making it difficult to resolve, change something and it works then problem comes back and the thing you changed did not affect it, it just seemed that way.
  20. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Yes, you are right !
    I bécote crazy !
  21. marc556
    590
    Wiltz (Lux)
    Marc Foyen
  22. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Here is one of the two air bypasses.... both are very dirty!
    on one side, when i put it back on the throttle body, i can screw 1/4 revolution more to close it !
    Qavion likes this.
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Post #52, you want to clean out that orifice, there is an o ring in there to replace if dry or damaged.
  24. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    The O-rings are in good condition on both side.
