Engine swapping???? | FerrariChat
Engine swapping????
Discussion in '348/355' started by cscott67, May 26, 2007.
  1. cscott67
    cscott67 Formula Junior
    May 13, 2007
    418
    Milwaukee
    Scott
    As I wait one more day to pick up the new toy, I was wondering if anyone has put a 355/360 motor in a 348? (I know blasphemy, and I apologize to the purists) If the 355 motor/block is the same, can't one just slap on a new set of heads? (and of course all the other intake/electronics that go with) There is a 360 motor for sale on the ad page. I'm sure others have looked at this already. Just curious, seems a lot cheaper than twin turbo set-up, Scott
    Flame suit on! ;o)
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Nope. The closest to that would be the 355 throttle bodies Plugzit has on his car. Though there is a 308 running around with a 355 engine in it. If I'm not mistaken it's twin turbo charged too.
  3. cscott67
    May 13, 2007
    418
    Milwaukee
    Scott
    Thanks for the info, I'll pm Plugzit! Scott
  4. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
    We figured that it makes no senes to do a 355/348 swap since the motors really are not the different in the end. Yes they have the 5 valves and 8 tbs, but it's considered an evolutionary step. Excelsior has the 308/355 turbo swap I believe. He's considering a 512TR transplant into his 355. Power junkie...
    The 355 and 360 motors have 6-speeds to you are talking drive train swap. I can't see the reason given the cost. You can just save the cash and sell your 348 for a 355. Now it makes much more sense wringing out more output from the 348 motor.
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    The factory left a bit of untapped HP on the 348 IMO :)!
  6. cscott67
    May 13, 2007
    418
    Milwaukee
    Scott
    I hear you guys, and I understand the cost issues with a swap. So what ways can you up the power from the stocker? I have seen, cat delete, different exhaust, different filters, chipping. With all of these, you might see what, 50hp more? (and not sure about the chipping, consensus so far is that it doesn't give much increase for the money) Are there larger cams? I guess you could bore it out, but now you have really gone into the engine. Any other suggestions besides twin turbos. The turbos seem VERY expensive. Scott
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    A freeflow air cleaner and Exhaust should add a bit. Pap gained over 18 RWHP with his X-ost brand muffler. :)
  8. cscott67
    May 13, 2007
    418
    Milwaukee
    Scott
    Thats a start, and one I'm sure to do. Haven't heard from Plugzit. Anyone else done any other mods? Scott
  9. mondialman
    mondialman Karting
    Apr 23, 2004
    148
    N. CA
    A Ferrari sage once said to me "if you want a faster Ferrari, buy one".
  10. cscott67
    May 13, 2007
    418
    Milwaukee
    Scott
    Don't like the looks of the 360s and up though. Scott
  11. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    +1
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yup. Well, to be fair, the factory shipped some 348 Competizione's to Michelotto with 360 hp, changing only the chips (and substituting the F-40's half-shafts) and exhaust.
    In turn, Michelotto bumped up more than one 348 CLM to as much as 550 hp.
    Michelotto dumped the factory black u-tubes into the air intake and went with larger MAFs (as well as more agressive chipping). One such 348 had the 2nd fastest time in class at Le Mans in 1994.
    None of the above were turbo-charged.
    So there is more hp potential left untapped in most stock 348's. You want a free-er flowing exhaust, straight air intakes, larger MAF's, larger intake plenum, larger fuel injectors, and more agressive Motronic software (e.g. ignition advance, fuel/air ratio).
    Individual throttle bodies or at least larger throttle bodies would also be a plus.
    Same cams. Same cam/valve timing. Same block. Same stroke. Same pistons. Same fuel pressure. Don't touch the core of this beast. Just add more air, more fuel, better software, and more ignition timing advance.
    Group77 also has a neat 348 trick with the ridiculous 90 degree bends in the fuel lines going up into the fuel filters that's worth stealing.
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Can you get 550 hp out of a 360 motor without turbo-charging/super-charging, or nitrous?
    ...because you can get 550 hp from the 348 motor with simple bolt-ons. That's what ran in the 348 at Le Mans in 1994.
  14. cscott67
    May 13, 2007
    418
    Milwaukee
    Scott
    I hate to say it n'all, (since I graduated from UAB) yer mak'in my thang hard!!! ;o) I am in contact with Plugzit on the throttle body/intake set-up. I'm sure I'll be pm'ng you more, Scott
  15. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    +2
    Speaking of which. When are you gonna get yours on the rollers Dave?
  16. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    What kind of RPM were these Michelotto machines turning???
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    9000
  18. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :eek: with the same engine internals (rods...) as production 348's?? Did they use the same intake manifolds??
  19. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    For 24 straight hours at Le Mans 1994 (2nd fastest qualifying time, 4th place in class).
    ...that's probably more than 3600 miles of redline driving.
    These beasts can handle it. They're tougher than most of their owners.
  20. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The 348 CLM engines used intake plenums that look suspiciously like the 1995 355 (as well as have 8 individual throttle bodies like the 1995 355's).
  21. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Plugzit is going to love this.......no wonder he's looking for a big rear wing.....200mph down the LA freeway with a BK whopper in hand and FBB navigating...lol
  22. cscott67
    May 13, 2007
    418
    Milwaukee
    Scott
    Sir, do you have any pics/details for the res of us power hungry speed junkies??????? Scott
