Engine Ticking after oil change | FerrariChat
Discussion in 'Technical Q&A' started by speed360, Aug 11, 2011.
  1. speed360
    speed360 Rookie
    Apr 18, 2010
    21
    sarasota, Fl
    Michael
    Just had the oil changed this week on my 2003 360 Spider at independent shop. Used Valvoline 5W40 Full Synthetic, new Ferrari Oil Filter from dealer and 2 new crush rings for the drain plugs. There was no engine noise prior to oil change, The 2nd start up after the oil change I heard a lifter tick from the engine. It went away after about 60 seconds. It has been one week, and still after starting the car even after just 1 hour of sitting you will get the engine ticking, then dissapears after 60 seconds. oil level is perfect after letting it warm up and checking it running. Any help would be appreciated.
    Thank you in advance.
  2. ONEOFEW
    ONEOFEW Formula Junior
    Jan 19, 2006
    836
    LA
    Steve
    Probably it is a sticky lifter, what brand of oil? What viscosity was in it before? It is somewhat normal if the car is parked for week or longer but not after an hour.
    You may want to post this on Technical Q&A section, some will chime in.
  3. speed360
    speed360 Rookie
    Apr 18, 2010
    21
    sarasota, Fl
    Michael
    not sure what type of oil was in it before the change, I just purchased the car this year.
  4. THINKFAST
    THINKFAST Karting
    Jan 13, 2011
    195
    Earth, mostly ...
    Search under "360 Modena engine ticking" There is a member here with that same type of issue.Im not saying his concern is the same as yours,but from what I read it could be a big problem.Brian.s,and Dave Helms talk about 360 lifter problems that can result into big problems.I dont want to alarm you but I read this just recently.Double check your oil level,then have a tech listen to the sound.It may be nothing.Good luck ,keep us informed as to what you find.
  5. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    Oil filter problem perhaps? Letting all the oil drain out and has to fill upon every restart, leading to low oil pressure on startup and the ticking? Just a guess if it was not there before.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Sounds like a noisy hydraulic lifter.
  7. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    +1 More than likely one of the lifters is bleeding down and takes a little running time for it to pump back up to zero lash.
  8. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Just curious, did you use the same engine oil again or did you change brands or viscosity?
  9. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    "and 2 new crush rings for the drain plugs"
    And therein lies the rub.....;)
  10. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Sorry this seems a meaningless comment how can crush rings have any bearing on hydraulic lifter noise.
  11. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    They don't. I was only trying to add a little humor to the conversation....
  12. speed360
    speed360 Rookie
    Apr 18, 2010
    21
    sarasota, Fl
    Michael
    Not sure on previous oil used, just bought the car this past spring (first oil change) And I understand that it is most likely a lifter bleeding down, that was my first thought when I heard it...but why right after an oil change...just an oil change should not cause that symptom??
  13. speed360
    speed360 Rookie
    Apr 18, 2010
    21
    sarasota, Fl
    Michael
    Possibly change oil again with a different brand....If so, any reccomendations?
  14. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Brand shouldn't make a difference but viscosity does. A little lifter noise on start-up is no big deal since it goes away shortly.
  15. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Did you get any maint. records with the 360??? There is a possibility that the oil was not changed regularly and the detergent in the fresh oil cleaned out some sludge in the lifter that was helping hold a seal.
    I have seen this before on some metric v-twin motorcycles. In fact a co-worker just bought a used Honda VT1100 and his lifter got noisy when he changed the oil. The bad part is the lifters are no longer available from Honda.
  16. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
    #16 DenisB, Aug 16, 2011
    just wondering, when did ferrari switch from overhead cams (no lifters) to hydraulic lifters?
    I have a mondi and noticed this happened when I switched fron reg 5w50 to synth and quicky changed back , the ticking went away for me. jmo
  17. speed360
    speed360 Rookie
    Apr 18, 2010
    21
    sarasota, Fl
    Michael
  18. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    From Wikipedia:
    There are a number of potential problems with hydraulic lifters. Frequently, the valvetrain will rattle loudly on startup due to oil draining from the lifters when the vehicle is parked. This is not considered significant provided the noise disappears within a couple of minutes, typically it usually only lasts a second or two. A rattle that does not go away can indicate a blocked oil feed or that one or more of the lifters has collapsed due to wear and is no longer opening its valve fully. The affected lifter should be replaced in the latter situation.
    SO:
    Either put in thicker oil or replace the lifter,
  19. PAP 348
    Dec 10, 2005
    100,232
    Pap
    It seems odd that it only happened after the oil change.
    I would change the engine oil and filter again. Try and use the same engine oil used before you got the car. If you have the service histroy, it shouldn't be hard to see what oil was used in the past.
    If you still have the noise after the oil change, then obviously there is an issue. I remember only recently reading here that Dave Helms (im sure it was him) saying they are only starting to see issues with noisey 360 lifters now. Something like that, he may be able to confirm if he sees this thread.
    Try another oil change first mate, it's the cheapest and easiest route to take for now. ;);)
  20. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    #20 Lawrence Coppari, Aug 19, 2011
    While this is only anecdotal, one of my vehicles (not Ferrari) that has the oil filled lifters occasionally makes the tapping sound for about a second when it is first started after sitting overnight. This has been going on for a number of years. The vehicle frequently sees track use. I have also noticed that as the oil gets older and used more, the tapping occurs less. At first I was concerned but have long since quit worrying about it because if something were really wrong, the engine would have expired by now. As long as the tapping goes away very quickly, I say let it tap.
  21. BigTex
    79,406
    Houston, Texas
    Bubba
    As the oil sheers down the viscosity thins, and finds it's way into that balky lifter at a faster rate. Totally believable.
    It's odd that fresh oil would cause it for the OP, unless the weights were changed.
    I'd switch to Royal Purple....;) :D :D
  22. PAP 348
    Dec 10, 2005
    100,232
    Pap
    Yep yep. :)
  23. speed360
    speed360 Rookie
    Apr 18, 2010
    21
    sarasota, Fl
    Michael
    Thanks for all of the responses, I have put a few hundred miles on the car just to see if the oil would break down a bit, or to possibly free up a dirt blockage issue....the tick is slightly better but still there. I am changing the oil again this week....will keep you posted! Thanks again for all the reccomendations!
  24. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #24 davehelms, Aug 31, 2011
    Based on our research and findings after disassembly and prep of some 300+ lifters, dirt that goes in, stays in. They are a one way garbage can at the end of the oil system.
    Some of the debris we have identified inside the lifters could not have found its way there under normal operating conditions, it had to have been there since manufacture. Aluminum flakes, silicone worms, fiberglass header insulation, wood chips (?!)..... the list is long.
    To date we have identified no less than 5 failure modes, a number of which cant be heard but cause problems none the less. Still think you know more about what oil is best for the hydraulic lifter cars than the engineers at Ferrari....? Think again and choose wisely as it affects things many had not even considered.
    It took me months of research and testing to figure out a way to put a 3 angle valve job on a 1.7 mm overall diameter valve seat. That little exercise required a number of jigs to be built, cutters made and involves various compounds up to 3000 grit diamond lapping compound to blueprint the final valve seat lap in. Tedious work done under a microscope until a method was developed where we could get consistent results that would pass my QC tests. Results that, by design, will last and to the best of the lifter design, will prove self cleaning.
    Everything works well until it breaks. How does one know when its broken if it cant be heard? THAT is the real question that I am going to try to answer once the engine dyno is in place this fall now that I have a solution to the lifter problem. Knowing what I now know, I would still do the procedure we developed even if new lifters were available. There is a lot to this little story and I have just touched on one or two points.
  25. Catharsis
    Catharsis Rookie
    Jul 9, 2011
    13
    Do you have any updates. I also have this problem
