Engine whines belt durability | FerrariChat
Discussion in '360/430' started by raywong, Jul 17, 2010.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I went to a trackday a few months ago, after all the hard driving, the car developed a faint whining noise coming from my engine. It was pitch dependent, starting at 2600 rpm and disappear at 4400 rpm. My mechanic found out it was caused by vibration of the alternator belt which was lose due to stretching. He tightened it and all noise were gone.
    3 months passed... I don't drive this car a lot, but the whines has came back after a few hard drives recently. Apparently the belt is stretched again! I am a bit worry about the durability of these belt, specially if the timing belt is made of the same material.
  2. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    #2 chrmer3, Jul 18, 2010
    Could it be a bad bearing in the alternator and tightening the belt temporarily masked it? Also was the belt originally tightened by a hertz frequency? If not maybe that is why- either to tight (causing premature bearing failure) or too loose causing the belt too sing? Just a guess but least you know exactly where to look for issue.
  3. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    why is a frequency meter need to adjust belts? I always measure the top to bottom movement for correct tension.
  4. Euromog
    Euromog Karting
    Apr 5, 2009
    102
    Oakhurst, CA
    John Wessels
    Even when installing a new altenator belt with a service to the factory spec I have had it stretch over night and become loose. Then had to adjust the tension again. If you have a belt on any car that keeps stretching after several adjustments I would suggest replacing it. Not on a Ferrari but I have had a few new belts over the years that made better rubber bands than a drive belt. Only fix was to replace them.
  5. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Ask Ferrari, its right in the service manual....
    Timing belt:190-210hz
    AC belt: 131-145hz
    Alternator/Water pump: 90-100hz
    steering pump: 90-100hz
  6. SpecialK43
    SpecialK43 Karting
    Oct 12, 2007
    198
    Kzoo, MI
    K Russell
    Are you supposed to pluck the belt itself and measure the frequency?
  7. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Yes. On another recent post named frequency meter for timing belt service I found a hz meter that is a bargain at $250. I checked it's accuracy and it is dead-on or off 1 hz at the most!
    Chris
  8. highpower
    highpower Rookie
    Jul 20, 2010
    1
    what model car do you have?
  9. TheMayor
    106,168
    Vegas baby
    Just because the timing belt is also made of rubber doesn't mean they are "the same". They have a completely different construction and have completely different forces acting on them.
    But, if you're concerned the timing belts would have the same problem, they are really apples and oranges.
