348 - Engine won’t rev past 5k | FerrariChat
348 Engine won’t rev past 5k
Discussion in '348/355' started by ChoonHound, May 26, 2023.
  1. ChoonHound
    ChoonHound Formula 3 Silver Subscribed
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    Car is driving great. Hauling down the road. Hitting high revs. Then the engine note changes. Car won’t rev over 5000rpm. Engine sounds lame. Maybe it lost a whole bank of cylinders? I pull over. Car dies. Both check engine lights are illuminated as well as the battery light.
    Car starts right back up. Drives fine.
    Any thoughts?
  2. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Sounds like cat ECU throwing into limp mode.
    Still have a cel? pull the code.
    Sent from my SM-G990U using FerrariChat.com mobile app
    surfwolf likes this.
  3. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    I’ve been doing some searching and haven’t been able to determine if limp mode is a thing on the 348.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yep usually get sdl lights and car runs poorly and won't rev. It's not called limp mode I'm calling it that.
    ChoonHound likes this.
  5. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    Ok cool. Thanks Eric. So I need to pull the codes from the ECUs to see what’s going on?
  6. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,350
    Ian Riddell
    ...as all 348s do when they die. Were there any lights before the engine died completely? Is it a 2.5 or 2.7?
    Here was one solution
    https://www.ferrarichat.com/forum/posts/139178423/
    But it could be anything at this point. Heat and vibration affect lots of things. Fuel, ignition, etc..
  7. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    That’s the thing: no lights whatsoever before it acted weird. It’s an NA Spider so it’s a 2.7… right?
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  9. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    No. Never.
  10. Qavion
    Feb 20, 2015
    14,350
    Ian Riddell
    That's what Wiki say, but I'm no expert.
    https://en.wikipedia.org/wiki/Ferrari_348
    Is the cutoff point the same as the name change from TB/TS to GTB/GTS/Spider?
    Does it have removable seat cushions :p
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ahh ya ok that sucks. Could be anything as mentioned.
    Crank sensors are easy to check and rule out.
    Any work done on it recently?
  12. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    Any work? Tons. New clutch, fly wheel, fuel pumps (both), major service, plugs, etc.
  13. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,450
    Los Angeles
    Sell car to @JohnK, he'll never know there's something wrong
    bjwhite and Qavion like this.
  14. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    23,717
    WI
    Who did it?
  15. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    Jiffy Lube. They had 5 stars on Yelp.
    Qavion likes this.
  16. WATSON
    Sep 9, 2010
    23,717
    WI
    Smart. Good luck.
  17. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    I think one bank is shutting down for some reason and then coming back online after a restart. That’s what it feels like.
  18. Qavion
    Feb 20, 2015
    14,350
    Ian Riddell
    Is there any reason you changed the fuel pumps?
  19. ChoonHound
    May 13, 2022
    2,238
    Saint Michaels, MD
    Lucas
    I requested both be replaced “while you’re in there”
    Reading the description of the problem it sounds like it might be what’s happening still.
    . Image Unavailable, Please Login
    Maybe it’s the FPR?
  20. Qavion
    Feb 20, 2015
    14,350
    Ian Riddell
    From what I've read on the forum, if there are no lights or messages, fuel supply/regulation is one possible cause. I think I would check for messages first, though.
    Is it hard to check for fuel leaking into the FPR vacuum line on this car?
  21. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Sounds like a fuel pump relay or injector relay for one of the banks.
    I had something similar happen to my 348TB (1993). I replaced both fuel pump relays, and both the injector relays and its never happened since.
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Kevin has a point, I replaced ever relay and fuse in the footwell, most are the old steel ones that are not sealed, it solves a lot of issues on these cars. Especially intermittent ones. I have a whole post on that. I'd start with those first few related to fuel and then possibly inspect replace the FPR (but honestly they re so cheap and easy to do it costs more to have them checked), if it still happens look at spark issues.
    https://www.ferrarichat.com/forum/threads/footpad-fuse-panel-relays.594744/
  23. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,253
    Serbia - Niš
    Miroljub Stojanovic
    When one of my pumps, a few minutes after cold start, started slowly dropping fuel pressure, I had the CEL for that bank coming on when the pressure dropped to about 25-30 psi (I could monitor the fuel pressures on the gauges I installed). So it seems that low fuel pressure should trigger CEL, indirectly through the signal from the O2 sensor as there are no fuel pressure sensors on the 348.
  24. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,243
    CT
    John Kreskovsky
    Ha, ha. I'd probably of had it fixed by now.
    And, I shift at 6k, not 5. So.... ;)
    My motto is, "If you have to ask for help on F Chat, you shouldn't be working on your car." :p
    I asked a couple of time. Always got bad advice. :(
    WATSON and Targatime like this.
  25. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Got to learn somewhere. But he does not work on it himself he has a shop do it, I think he's just trying to get a sense of direction here.
