Enzo engine dies at Laguna Seca | Page 4 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Bill S, Oct 8, 2010.
  1. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    If this thinG was made with TI Rods-they are almost CERTAINLY made by PANKL...
    A re center to center, new hardware, materials evaluation certificate, bushes, bearrings, retrueing, and a balance of .1 of a gram at 1 inch on two planes for the crank as well
    imho...rods should be thoroughly investigated as per previous posters opinion...FWIW
  2. of2worlds
    of2worlds F1 World Champ
    18,755
    ON
    CH
    Since things are taken apart is this a chance to 'upgrade' or is it just the stock parts being replaced with OEM parts in the motor?
    CH
  3. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
  4. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    We're just replacing the stock parts with OEM parts. That's primarily to maintain the value of the car and because I didn't want to get into a major engineering project.
    Yes. Ferrari calls them "detonation sensors".
  5. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    #80 JeremyJon, Dec 5, 2010
    interesting...that's 1 knock sensor (sry. detonation) for each cylinder pair, typically see 1 per 4 cyls
    i've done my fair share of engine work, never seen that many before, allows them to run such an aggressive tune
    glad to hear things are coming back together for you, and it wasn't a total write-off
    do you have any pics of the crank and crank case? i'm curious if they have a barrel type crank case, or conventional (insert nerd mechanical moment here LOL)
  6. 91f40
    91f40 Karting
    Sep 25, 2005
    106
    I was there with my car that day. and havent been here in a while. I spoke to a friend of mine who worked at the Ferrari factory and F1 team and he told me he thought pulling the right strings ferrari would help with the repair. Did you try that route?
  7. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    We did but didn't get too far with the dealer and Ferrari of North America (FNA). FNA says the original Enzo warranty is only 1 year and they wouldn't even help their best customers (which is not me) 7 years later. I'm disappointed and would expect more from FNA, especially with their flagship car and the engine failing without abuse (and proper maintenance) with only 4K miles. They didn't even care why it failed and didn't come to inspect it. That doesn't seem right for Ferrari.
  8. technom3
    technom3 F1 World Champ
    18,972
    Phoenix AZ
    Justin
    Working in the Auto industry I understand the situation you are in... well i guess both sides of the problem.
    It may not be your style... and you may have already done this... BUT... try hard and rattle cages. The squeaky wheel gets the grease! Always. I hated it, but the customers who were cool and calm (which were the ones you wanted to help the most) didn't get "taken care of" nearly as often as the ones who were A-holes that you wouldn't stop and help them change a tire... they seemed to have always gotten what they wanted.
    If I were you I wouldn't stop rattling the cages at North America, if that failed... Ferrari Spa would be my next stop.
    But, i know this route is not for everyone... and I could also see if you purchased your enzo second hand (which most have by now) it could also be more difficult to earn favor... but you really got nothing to lose... except for time.
  9. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #84 finnerty, Dec 6, 2010
    I sure wouldn't --- doesn't surprise me in the least. FNA is worthless to their private customer base. The only "customers" they recognize are the Dealerships. They don't generally give a rip about the folks who actually buy the cars :(
    Seems spot on to me....That's what they do. You gotta be in their "top 5%" to get any attention from Ferrari --- to them, the other 95% of us are nothing more than the aggregate contributing to their balance sheets :(
  10. George330
    George330 Formula 3
    Oct 19, 2009
    1,460
    Switzerland
    George
    I can understand why they wouldn't want to foot the bill for the repair 6 years after the warranty expired. However they should show more interest and investigate the reasons for the failure. This is the best car they ever made, bought by some of their top clients who deserve better than this. If it happened to me I'd be fuming
  11. Buxton
    Buxton Formula Junior
    Oct 31, 2010
    484
    B Buxton
    I'm not feeling the love from FNA either.
    There were a batch of bad valve springs in Enzos where the end tips separated leaving metal particles rolling around in the oil. Ferrari ultimately alerted some that a supplier had problems. I'm sure its to FNA's immediate benefit not to step up and do the right thing
  12. AX lover
    AX lover Karting
    Jul 6, 2007
    80
    The Netherlands
    How is the rebuild going? Almost finished?
  13. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    Yes, almost finished. The car should be back on the road later this month. Some parts took a while to get. We're still waiting on 3 pistons (we're replacing all 12 pistons and sleeves).
    We're being very meticulous. Evey part was ultrasonically cleaned and we replaced the oil pump because we couldn't get the O-rings. We magnaflux tested all parts except the titanium rods which were very carefully inspected and no damage found. The cams, crank, springs and most valves were undamaged. We're replacing all the pistons and sleeves only because we saw noticeable scratches. But those could have been there before the major failure.
    I believe it will be better than new. The rebuilder stated that he's seen metal particles in even new Ferrari engines, like spirals from drilled holes. This engine will be absolutely clean.
    We're still not exactly sure what caused the original damage, but the rebuilder thinks it could have been due to an overrev condition, possibly occuring when the engine was bouncing off the rev limiter. The valve appears to have been bent first and then broke later. I did notice a ticking sound before the major damage, so that may further support what the rebuilder thinks happened.
  14. Emil
    Emil Formula Junior
    Jul 20, 2006
    321
    Solihull
    Emil Ahmed
    are you going to use any pre-cautionary methods regarding the over-revving? like changing the way the ECU is so the rev limit is lower?
  15. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,917
    Cape Town,SA
    Jacques
    #90 Ferrari 360 CS, Jan 2, 2011
    Interesting observation, though surely just brushing the rev limter wouldnt be enough to cause such severe damage?
  16. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Glad to hear its close to running again Bill, you must have missed it to say the least :)
    Will be a strong running engine with all the care you have taken...looking forward to the pics and description of the "ressurection drive" !
    Happy New Year my friend
  17. Buxton
    Oct 31, 2010
    484
    B Buxton
    I believe Bill has clipped his toenails and that's all the restraint it gets!
  18. 365gt2+2
    365gt2+2 Karting
    Nov 28, 2006
    172
    with the wife
    Norman B'stard
    And the knowledge that the thing has been put back together correctly, fastidiously will mean that you can enjoy the car even more, also knowing that you and only you is now in total control of the destiny (read: life, longevity) of that engine ..
    A friend of mine had a 355, it was about 6 years old and 12k miles when he got it, yet he insisted that he start it and let it idle for 5mins prior to driving so everything is properly upto operating temps and or tolerances etc.. Which is all well and good, I would never condone starting and revving the knackers off any engine when cold anyway, but did the 3 previous registed owners and countless other dealers/salesmen/technicians/delivery drivers/valeters/potential customers who have been near the car pay it the same courtesy?.. I think not!.. So Mr S.. It's been a long, painful and expensive exercise but now you are safe knowing that your engine is just that, your engine.
    And thank you for taking the time and letting us know the various ups and downs you have encountered along the way, I have enjoyed following this thread and look forward to the next installment!
  19. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #94 Bill S, Jan 28, 2011
  20. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,676
    Avvocato
    Bill - maybe you covered this, but curious as i ddint read it.
    did FNA at the very least cut you a deal on all the parts or some, or was it at retail , or close too ?
    did they even want to know of the rebuild of an "enzo" name sake engine ?
  21. Bullitt44
    Bullitt44 Karting
    Feb 22, 2005
    226
    Westlake, OH
    Jon Sabo
    #97 Bullitt44, Jan 28, 2011
    Wow. My wallet hurts just looking at it, but looks like it will make a full recovery.
  22. PAP 348
    Dec 10, 2005
    100,244
    Mount Isa, Australia
    Pap
    Nice pics! Cool parts! Im cracking a woody looking at them. :eek::eek:
    Are you using liquid nitrogen to get those liners in? :):)
    We remove and replace liners at work on engines using a special tool to pull them in and out. One would think Ferrari would do it this way. :):)
    Or did they heat the engine up and semi-freeze the liners at the factory when they assembled the engine in the first place? :):)
    (They probably just bashed them in with a copper hammer. :eek::eek:)
  23. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    great to see things coming back together for you now.........seems like it would be an opportunity to do the 6.3L upgrade (stroke/crank)?
  24. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Bill: this is a great conclusion, well done. I think this will be a quick Enzo!
