Enzo engine dies at Laguna Seca | Page 5 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Bill S, Oct 8, 2010.
  1. S Brake
    S Brake F1 World Champ
    Aug 3, 2006
    17,182
    Utah
    Dave
  2. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,486
    Austin, Texas
    Michael C
    Wow... I remember those pics but i didn't know that it was your home & cars. The photos made me sick but I can only imagine how you must have felt.
  3. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,527
    Bournemouth, UK
    Hello there!
    Ferrari uses liquid nitrogen to shrink and then fit such engine components. This task is performed by two robots called Romeo and Juliet.
  4. sixcarbs
    sixcarbs F1 World Champ
    10,620
    SF
    Hi Bill,
    Sorry you have to go through this, but you are definitely doing it the right way.
    Will you put it on a dyno before it goes back in?
  5. PAP 348
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    Hello friend. :D:D
    Yes, I saw the 599 Factory video. :D:D
    Shows them fitting valve seats with Remeo and Juliet. :D:D
    I wonder if they use the liner puller or freeze them at the factory? :):)
    If you freeze them, you dont need the special tools to fit the liners. :):)
  6. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #106 Bill S, Feb 16, 2011
    Hey guys. See below. The factory says heat the block to 90 degrees C and insert the liners at room temperature. That's because they use rubber O-rings which would crack if you used liquid nitrogen.
    We are having a problem with the liners. They are not seating fully. We're using Prussian Blue to see the contact points. Any ideas on why they may not be seating fully?
  7. PAP 348
    Dec 10, 2005
    100,245
    Pap
    There ya go, special tool to fit the liners. :D:D
    I dont know why they wouldnt be seated hard Bill? :):)
    They should pull straight in man. Perhaps an issue with the deck height on the block? :eek::eek:
    We have NEVER had an issue with fitting liners, but our blocks are cast iron. Not alloy. :eek::eek:
  8. mrbucket2
    mrbucket2 Formula 3
    Nov 6, 2006
    1,109
    Bergen County
    Michael
    Thats for valve seats, not for cylinder liners.
  9. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,527
    Bournemouth, UK
    It would seem that you are quite right sir.
  10. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    #110 JeremyJon, Feb 17, 2011
    on the bottom of your attatchment is a note about the first liner possibly causing issue with sbsequent liners if not seated fully.....
    .....i know on the bmw v12 we had a hella-time, and found we had to work super-super-fast, more then we thought, as the block cooled so quickly.....finally it was a sprint-race, and suddenly in she went!? hope this helps?
    PS reminds me, we also let the block linger for a while in oven-box, not just as soon as when the block reached the temp, mind you that isn't as valuable as anEnzo block, which is also likely made of less aluminum mass, so warpage would be of concern, but these were our observations
  11. MD326
    MD326 Karting
    May 6, 2007
    192
    MD & FL
    WJP
    Any update on the liners Bill? Or a general update. Thanks! Hope everything is getting figured out.
  12. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    The liners are in! We needed to apply a bit more force than expected.
    With all the parts in, things should start moving quickly.
  13. GregW
    GregW Rookie
    Jan 25, 2011
    2
    I had that problem. The dealer found several ends from valve springs in the oil during an oil change. I had to ship the engine back to the factory for a complete rebuild because it was clear to me that they had a problem with a bad batch of springs and I did not want any of them left in my engine and I wanted a through inspection to see if there was damage to any of the cylinders. I had to pay for shipping and removing and reinstalling the engine and Ferrari in Italy did th rebuild for free. The car was about 15 months old.
  14. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    I assume you were the original owner, the car was 3 months out of warranty, and "goodwill" paid for the engine rebuild?
  15. Metal Guru
    Metal Guru Rookie
    Jun 19, 2010
    10
    Beverly Hills, Mi.
    If a seat was to fail it would have fallen out of the head as one piece. All seats are present and accounted for.
    It looks to me like the valve itself failed. Are the keepers still holding the stem up?
  16. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
  17. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,227
    Huntsville, AL., USA
    Andrew
    By now you must be really anxious to get behind the wheel of your Enzo again. :)
    All the best,
    Andrew.
  18. NWaterfall
    NWaterfall Formula Junior
    Aug 2, 2009
    564
    The Track
    Waterfall
    I would love to see dyno numbers from this rebuild!
    If you ever have the car near Salt Lake City, I've got free dyno time with your name on it!
  19. PAP 348
    Dec 10, 2005
    100,245
    Pap
    Good to hear mate. :D:D
  20. Norm512TR
    Norm512TR Formula Junior
    Nov 10, 2001
    895
    Colorado Springs, Colorado
    Norm
    Nice to see some good progress on this project
  21. Buxton
    Buxton Formula Junior
    Oct 31, 2010
    484
    B Buxton
    Looking good mate!
  22. Serpent Driver
    Serpent Driver Formula Junior
    Jul 4, 2004
    324
    Norway
    Can you please post some pics of the car with the engine removed? How is the removal prossedure?
  23. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,227
    Andrew
    #123 NeuroBeaker, Apr 4, 2011
    I once took a couple of pictures of an Enzo (not Bill's) with the engine removed. I don't know how helpful it will be, but here you go. :)
    All the best,
    Andrew.
  24. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    #124 Bill S, Apr 10, 2011
  25. nthfinity
    nthfinity F1 Veteran
    Mar 21, 2005
    7,467
    South East MI
    Isaac not Issac
    Just call it a 'Flinstone Superleggera'
