Enzo motor vs. LP640 motor | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by istanl, Jul 6, 2006.
  1. istanl
    istanl Formula Junior
    Apr 30, 2004
    662
    Melbourne, Australia
    Ian
    I was reading an article in EVO magazine about the LP640 and as most know
    the capacity has been upped to 6.5 litres from 6.2, hence making 631bhp and
    487lb.ft torque. Then I thought about the Enzo's engine.
    The Murcie makes its peak power at 8000rpm. The Enzo on the other hand is "just" 6.0 litres and has a peak power of 650bhp at 7800rpm. Thats half a litre and 200rpm lower, yet it makes 20bhp MORE. And even though the engine is down on displacement it still makes 485lb.ft of torque, matching the LP640.
    If the Enzo's engine had the Murcie's capacity, theoretically it'd be making over
    700bhp!
    Just makes you marvel at what Ferrari do, they seem to have all bases covered
    nowadays.
  2. Koby
    Koby Formula 3
    Dec 14, 2003
    2,307
    The Borough, NJ
    Jason Kobies
    And then Ferrari found another 200hp for the FXX!
  3. kevboaster
    kevboaster Rookie
    Feb 20, 2006
    45
    Pennsylvania
    Good point, but you have to remember that the Enzo cost about $300k more than the Murc.
  4. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    Amazing improvements can be gained with porting an managing both intake and exhaust flow.
    But also keep in mind these are quoted numbers...
  5. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    It is also interesting to take into account the fact that the Enzo's engine began development more than 3 years ago and it still makes more power...
  6. Rev.ATARI
    Rev.ATARI Formula Junior
    Sep 20, 2004
    683
    Guam USA
    Leland Jones
    Engines are purpose built and HP is not everything, the LP640 being a heavy car needs its grunt more in the lower power band. I’m sure that the torque on the LP640 engine kicks in at a much lower RPM then the engine in the Enzo does.
  7. JH
    JH F1 Veteran Silver Subscribed
    Nov 14, 2002
    5,080
    Odense, Denmark
    Jonas H.
    rev.atari, you are correct. But the weight/power ration is also a lot better on the Enzo, so the lp640 would probably have no advantage there either.
  8. ScreaminRevs
    ScreaminRevs Formula Junior
    Apr 4, 2004
    411
    Chicago
    The Murci's engine block can be traced back to the mid 70s; it's hardly cutting-edge when compared to a clean sheet design from 2002.
  9. istanl
    Apr 30, 2004
    662
    Ian
    It's just very rare to see an engine lower in displacement and with a lower redline to be making more power than a bigger engine that revs higher.
  10. NHeerDesign
    NHeerDesign Formula Junior
    Jan 25, 2006
    600
    Canada
    Nick
    While the Enzo is the engineering marvel here, I've gotta bring up another engine. The Viper's engine displaces a massive 8.3 litres and they can only find 500 hp in there. Theoretically, if you gave a Ferrari engineer 8.3 litres, they'd be able to get....
    about 900 horses. That's based off of Enzo figures. If we take into account the design of the FXX engine, an 8.3 litre version would churn out over 1000 hp!
  11. kizdan
    kizdan F1 Veteran
    Dec 31, 2003
    5,505
    The Lambo motor makes 97bhp/liter.
    The Enzo motor makes 108bhp/liter.
    Any normally aspirated motor that can crack the 100bhp/liter mark is a truly exceptional piece of engineering.
    The Honda S2000 (with the 2.0-liter) is the highest I have ever heard of at 120bhp/liter.
  12. 85GTO
    85GTO Rookie
    Oct 13, 2005
    48
    it also weighs as much as a boat anchor.......hmmm, a 4 cyl that weighs as much as a V-8.....WHAT A GREAT IDEA!!
    the best engine is the CGT's V-10. ~400lbs and 600hp.
  13. R0B
    R0B Rookie
    Apr 26, 2006
    4
    how much does the s2000 engine weigh?
  14. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Dont know? How much does a boat anchor weigh...............:D :D
  15. Rev.ATARI
    Sep 20, 2004
    683
    Guam USA
    Leland Jones
    Honda F20C 375 lbs
    Chevy 350 600 lbs
  16. 85GTO
    85GTO Rookie
    Oct 13, 2005
    48
    chevy LS7 450 lbs (at least use an engine produced this century).
  17. BAM
    BAM Formula Junior
    Dec 7, 2004
    686
    MN
    Jeremy
    winner.
  18. ScreaminRevs
    Apr 4, 2004
    411
    Chicago
    The 997 GT3 comes very close. I just read that Porsche guarantees each engine makes at least 415 hp. With the ram air effect it's supposed to generate an extra 10, I believe. From a 3.6 liter- probably the best 6 cylinder in the world that I've heard of. Seems like most people look past these engines at the turbocharged versions of the same block; that's somewhat of a shame.
  19. wmoon89
    wmoon89 Formula Junior
    Feb 24, 2006
    304
    How come Ferrari never puts in superchargers or turbos into their engines like Porsche?
  20. [355]
    [355] F1 Veteran
    Apr 10, 2006
    8,482
    Spacious tent
    Harold Faltermeyer
    but its also a matter of how highly strung the motor is
    Viper may be much less efficient as a capacity-power ratio, but will churn out 500hp for decades with the odd oil change
    Enzo will sh*t itself unless it gets its weekly cam belt..yada yada
    bit exaggerated but u get the point...
  21. kizdan
    kizdan F1 Veteran
    Dec 31, 2003
    5,505
    'cause that's cheating!
  22. kizdan
    kizdan F1 Veteran
    Dec 31, 2003
    5,505
    What is the source of this statement? Sounds like a load of rubbish to me.
  23. Napolis
    Napolis Three Time F1 World Champ Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    They do.
  24. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Don't forget the 288 and F40 as well. Not to mention their F1 cars from 1980-1988...
  25. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    208 Turbo, 288 GTO & F40 all have turbos. Any others?
    EDIT: oops, the judge beat me to it.
