Epoxy, DIY epoxy, garage tiles? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by iheartf430s, Sep 15, 2024.
  1. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    220
    TN
    Ed
    Used the search option and found a lot on this topic. Concluded that everyone seemed really happy with epoxy floors.
    But I couldn't find anything about people doing putting down their own epoxy floor.
    Is everyone just hiring contractor for the work?
    Also garage tile look good too. And they seem reasonably easy to put down.
    We're moving to a new house, garage is empty so easy to hop on to get a epoxy contractor in or getting to do it too.
    Can I get yall's imput on it?
    I like the look, don't like the cost... please give me guidance....
  2. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    220
    TN
    Ed
    Also looking for imput from people that put down their own epoxy? Was is easy? Cost? Happy with outcome?
  3. kestrou
    kestrou Formula 3
    1,548
    Danville, IL
    Kevin E. Stroud
    I did my 20x20 workshop with a commercial urethane a few years ago.
    Was easy, but I did five coats in fairly rapid succession (all within 24 hours) and it STANK so bad while curing that the neighbors were complaining of the smell…
    I did that coating because… well… it’s a workshop and has wheeled carts and sand motorcycle loft around, so needed to be TOUGH. But, when I weld, I put down a welding blanket on the floor near there as it can be burnt through.
    I'm happy with it,
    In my 20x30 garage I’m getting ready to do tile - mostly cars and bikes rolling out, so doesn’t need to be as tough.
    Kevin
    iheartf430s likes this.
  4. FerrfanFL
    FerrfanFL Formula 3
    2,281
    Florida
    Ara
    epoxy is easy, it's the PREPARATION of the floors that's a chore. I rented a commercial dual head grinder to clean/prepare my floors. took longer to prep than to lay it down. use clear coat as top coat. no fisheyes if prepared well. don't backroll more than recommended. use some aggregate in high traffic areas so as to reduce how slippery floor is. the smell was unreal as it gassed off, but went away in 2 days. i love it. also, if your area is large enough, you'll need more help as it has to go down fast so you're either doing half one day and half the next or you're having 4 guys laying down at the same time.
    INTMD8, technom3 and kestrou like this.
  5. kestrou
    kestrou Formula 3
    1,548
    Danville, IL
    Kevin E. Stroud
    What he said! I did expoy/urethane on my 20x20 workshop because it was new concrete - so didn't need grinding. Still had to "acid etch" it, but that wasn't too bad.
    The reason I'm tiling my garage is the floor is oily/dirty and would require grinding. F that! :)
    Kevin
    technom3 likes this.
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
  7. FerrfanFL
    FerrfanFL Formula 3
    2,281
    Florida
    Ara
    the grinding is a motha
    INTMD8 likes this.
  8. technom3
    technom3 F1 World Champ
    18,896
    Phoenix AZ
    Justin
    Done several myself. All my shops except the last one (way too big)
    I love epoxy.
    I use a product called tile clad from Sherwin Williams and they have a two part clear called rexathane. I absolutely love this stuff. I've found that it works excellent. If you get an account or phone number it's actually affordable. The retail price on rexathane is EXPENSIVE but the **** is great.
    Double up on the clear coat.
    Do not do anything single stage. Don't do anything without clear in other words. It will stain and turn to ****.
    Grinding is important as is a water vapor test.
    The grinding isn't as bad as most say. It's pretty loud... It's pretty hard on your body ... With two people one using the handle and the other dangerously grabbing the head with their hands it's really easy. Just loud and dusty.
    You must wear a respirator on all aspects of this adventure. Grinding.... Acid etching (if you do that) and application. It's really really bad if you don't.
    As far as chips... These are mandatory. You need twice as much as you think. Don't buy the crap retail. Google it.... They probably make some in your area. You can buy it by the I think 20 lbs box. I saved at least a thousand bucks doing this.
    Honestly though... The jobs are slowing down and these guys are looking for work... It should be getting somewhat affordable again.
  9. FerrfanFL
    FerrfanFL Formula 3
    2,281
    Florida
    Ara
    full face respirator is a must. flake is personal preference. I don't like a ton of flake, to me it looks like oatmeal. I have a ton of flake left over from my job. I wanted the flake and their corresponding colors to accent the base color of the floor - not to dominate it. totally up to each individual.
  10. JoeCab
    JoeCab Formula Junior
    470
    Colorado
    Joe C
    I've done a couple of spaces with epoxy, both DIY and professional installation.
    My favorite so far is a "full broadcast" treatment. That means there is no colored epoxy - they lay down a layer of clear and then literally add color chips until no more will stick. After that is dried they vacuum up the extra chips, lightly scrape to get any chips that are sticking up too much, and then apply a layer of clear over the top. This leaves a nice, uniform, slightly pebbly texture that is really easy to clean up. It doesn't seem to suffer from tire marks or discoloration like the colored epoxies do, and seems more scratch resistant, too.
    kestrou likes this.
  11. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,486
    Did epoxy with chips for garage- spectacular- but professionally done, grind, acid etch, clear coat the works the basement was done epoxy- same color but no chips- smoother more conventional surface that sees lighter use.
