epoxy floor costs? | FerrariChat
epoxy floor costs?
Discussion in 'Detailing & Showroom' started by rob lay, Jul 25, 2014.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    I'm talking about professional high end epoxy floors, what is the range of costs you seen first hand per foot? thanks.
  2. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    I have had this done on a 2 car garage, it was $2,000. Then on our new house 6 months ago, a 3+ car garage and it was $3,400. So figure about 1k per car parking spot. One of the best things we ever did. Totally transforms the garage, feels like part of the house.
  3. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    The quality on a used floor with oil stains, etc. depends greatly on the quality of the prep work. It certainly needs to be well-cleaned - and may even need to be acidized or sandblasted depending on the condition.
    That could, I suppose, double the cost.
  4. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    #4 andy308, Jul 25, 2014
    The guys I use always sands the floor first to "open" up the concrete so the epoxy will attach. This is part of the cost already since they do it every time.
  5. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    #5 andy308, Jul 25, 2014
  6. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    That is a magnificent floor coating job, Andy308.
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #7 Dave rocks, Jul 25, 2014
    Rob, if you really want to do it right, do epoxy mortar with a urethane top coat. It, 1/4" thick. It's approx $5.00/sq ft, probably more if the garage is small.
    I just had it done in our new business shop.
  8. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    #8 rob lay, Jul 25, 2014
    This sample they think will work best for me is Self Leveling Slurry Epoxy with a clear coat. They said it is most durable and quality for my application. It would only be a speckle look though.
    They have a Metallic Epoxy they could do a marble look, but much more expensive and they don't think as durable to scratches.
  9. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    #9 rob lay, Jul 25, 2014
    I like these example marble looks though, originally I was going to do actual tile, so any epoxy is still less than 50% of tile.
  10. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,799
    Dallas Texas
    If you know you know
    Russ Watkins
    Territory Manager - North Dallas
    Stonhard, Inc.
    cell: (903) 227-0868
    corporate: (800) 854-0310
    email: [email protected]
    Tell him I sent you, best product I have seen, for the industry I'm in.
    If you have time, you might drop by Autoscope Park Cities and take a look, it's what we had done in the shop.
    S
  11. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,839
    polished concrete an option?
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #12 Dave rocks, Jul 25, 2014
    If you have a smooth finish (no aluminum oxide or chips) it will break your neck if you get it wet.
    We also did metallic in our office but it has a urethane top coat too
  13. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    Hmm, so not really an epoxy or just a form of? Website looks good, mostly commercial, but I do need 1,500 square feet (garage + a patio).
  14. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    I considered it, but I'm liking epoxy type coating more now.
  15. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    that's a problem mainly because I keep my boat in there too, so it will get a little water.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Rob, be sure you know that epoxy will yellow in sun light (Patio) which is one reason most recommend a urethane top coat.
  17. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    thank you, no sun or even windows in showroom garage, but plenty of sun on the patio!
  18. BigTex
    79,321
    Houston, Texas
    Bubba
    That speckled sample would be hard to find a dropped screw!
  19. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    #19 ferraritime, Jul 26, 2014
  20. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    Looks great!
  21. rob lay
    Dec 1, 2000
    63,331
    Southlake, TX
    Rob Lay
    Russ already got back to me, they are just commercial, but he's interested and is going to put numbers together. Thanks!
    Sounds like my first quote wasn't out of line though.
  22. ddonzella
    ddonzella Karting
    Jun 2, 2014
    104
    Davie
    In South Florida $3.25 per square foot. with 3 step process; non yellowing clear top coat.
  23. myronx19
    myronx19 Formula Junior
    May 27, 2012
    653
    Toronto, ON Canada
    Myron Samila
    I did my 200 sq.ft single car garage with 100% solids epoxy ( zero VOC). It cost around $400 CAD.
    It's quite durable - but what I didn't factor in, is that my slab sits right on dirt (I'm fairly sure of it) - so no vapor barrier under the slab. Any moisture that migrates to the top of the concrete will pop the epoxy off (they look like tiny pimples with water in them), no matter how good it is or how good the prep work was done. Hydrostatic pressure isn't kind to an epoxy floor covering.
    If I were to do it again, I'd use a sealer over the concrete that is compatible with the epoxy top coat.
    100% solids epoxy is the way to go - a lot of other "big box store" epoxies are solvent based (water or otherwise) and shrink as they cure. 100% solids does not shrink during the cure, which leaves a very thick finish that so far has never had issues with hot tire pickup/lift off nor tools dropping, jack stands, etc..
    As mentioned previously - it is SLICK when wet..
    The product I used is from a Canadian company called: Enviro-Epoxy Enviro Epoxy Products Inc. - Home
    I prepped, and rolled it myself and I think it looks great! (was so easy to do)
  24. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    Good looking shop, Dave.
  25. abstamaria
    Feb 11, 2006
    2,668
    Andres
    I would ask you to consider tile again, Rob. Easier, more predictable, and possibly as or less expensive than epoxy + polyurethane. And, if you drop a hammer on it, you need to replace just the one chipped tile.
    For a working shop, I would go for a white, plain floor. Easier to find the dropped spring or washer, brighter, and easier to keep clean.
    Andy
