Ernie's diff....iculties | Page 6 | FerrariChat
Discussion in 'Technical Q&A' started by fatbillybob, Apr 21, 2006.
  1. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    After the next setup FF,the half n half,how are you goin to set up the diff?? The static slip? Ideally,would you set it 75 lb/ft? Let us know tomorrow when your done brother. Appreciate the time and effort you put in here for the boys. :)
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Would 75 lb/ft of static drag be enough to impact, noticeably, 0-100kph times for a stop-light racer?
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    No, for a roadie on road tyres, 75 lb/ft with the 40% (both ways) GT4 diff is too tight. I'll leave it at 35 lb/ft if it's still over 50 when set half and half staggered. If half half split puts it to 45-50, I'll do that.
    Drag racing... is that when boys dress up as girls and run really fast? Not something any Ferrari is much good at.
  4. fatbillybob
    Aug 10, 2002
    29,427
    socal
    Why is it too tight? What happens?
  5. pistole
    pistole Formula Junior
    Jan 31, 2005
    771
    Malaysia
    well thats because boys usually are bigger boned , so the dresses are
    very tight , and this results in slower times.
  6. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    The ramp angles combined with excessive static preload, on a road car with a tight turning circle, tend to promote chatter when turning slowly.
    A race car typically has a reduced turning lock (wide wheels/brake ducts etc), so it's ok.
    A good oil can reduce or eliminate the chatter, but I'd rather avoid the cause, than attempt to fix the symptom.
    Anyway, ran out of time to play with the GT4 diff, so put it in with 36 lb/ft preload.
    I've got another in bits on the bench, and I'll do the stacked/staggered/half half test again some day soon.
  7. fatbillybob
    Aug 10, 2002
    29,427
    socal
    O.K. and chatter does what besides make noise? What happens to how a car behaves when "too Tight" that is what is important?
  8. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Not much, other than excessive rolling resistance on lock (try pushing it around the garage!)
    Chatter causes shock loads to the drive line, and is uncomfortable and unnecessary.
    Let's not get all rocket science like over a diff.... Go karts don't have them, nor do Aussie V8 supercars.
  9. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    I would definately put all the friction surfaces into play for a track car. I'm working on obtaining a quote for alternate angle ramps (I am a rep for Modena Engineering in the States).
    As stated prior, the downside to too much diff clutch preload is increased potential corner entry understeer.
    Best,
    Rob
  10. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Are you really, I wondered who he used over there.
    Maybe I could get stuff from you, because he won't answer his phone and when I go there he dodges all the questions, if he's there (usually away or out).
    I HAVE had a few 360 Diffs off him, and some 360 gears too, but FRIKKIN hell he's hard to deal with!
  11. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    depending on the ramp angles of course......
  12. fatbillybob
    Aug 10, 2002
    29,427
    socal
    Cool on the ramp angles project I want to try playing with this.
    Can you compensate for the entry understeer by trail braking and jumping on the gas as early as possible? Or does a ramp angle change give you the benefits without the corner entry understeer negative?
  13. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    a quick google gets this... which should help you get your head around it.
    http://icpcitation.com/variloc_tuning.htm
    http://icpcitation.com/variloc_theory.htm
  14. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    Fantastic links Phil, thanks!
  15. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    yeah, a bit too good!
    Bloody internet gives all the secrets away!!
  16. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    For free even :D
  17. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Bump...
    so what have you done Ernie/FBB??
  18. ROLOcr
    ROLOcr Formula Junior
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    speaking of diffs, i need info on 250 gte rear end, any help?
    prices and availability
    thanks
  19. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    what exactly do you need.
  20. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    to rebuild a rear end, ring and pinon for a pf cab 2,
    upon disasembly of the car we notice it had WAY TO MUCH play due to a bad bearing probably,so we need ring and pinnon, don't know the ratio yet, on monday i will take it appart and post pics
    you know i did a search and found nothing about this, i'll try some more and if not, i will open a thread about 250 rear ends
  21. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    Good Idea. In the mean time, contact Symbolic and/or DK Engineering for parts and good information.
    I think I have a manual somewhere too..... need to have a look.
  22. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    THANKS, and the manual would be of GREAT assistance!!, i'll take pics on monday, and start a thread about it with pics and a detail report
  23. fatbillybob
    Aug 10, 2002
    29,427
    socal
    Actually, the diff is stock set-up...zero preload. Ernie is rebuilding his G Box in my garage at his pace and leisure. I'm just looking over his shoulder since I've done it a half dozen times and the comraderire is fun. I think he should shim up the diff to see what happens but he is thinking leave it stock or stagger plates mostly because he is at that point in a project where he just wants to find the time to finish it and the weather is getting really good in So. Cal....
  24. ernie
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    I really am working on this thing at a turtles pace. But as FBB said I do want it back on the road as summer has arived in sunny So Cali. I'm just gonna stagger the plates and clutches. My car is going to live the vast majority of it's life on the street, so I'm not so concerned with exit corner speed as if it were a track only car like FBB's 348.
    However on a side note. While I was putting the lay shaft back together I noticed something interesting on the synchronizer sleeve. There are are notches on the under side, the side where the teeth are, that the pad and knuckle for the synchro sleeve fit in. One of the notches is deep, and the other two are more shallow. When putting the sleeve on, you need to make sure that it goes on properly so that it can side over the synchro rings and gear properly.
    Now for what I noticed. If you put the sleeve on one way, pad and knuckle fit into the deep notch. However if you rotate the sleeve the other way, one tooth, the pad and sleeve fit into the smaller notch. When I have the sleeve positioned so that the knuckle was in the deep notch, it took a bit more force to get the sleeve to slide over the gear. When I rotated it so that the knuckle was in the shallower notch is took less force to move the sleeve onto the gear.
    Now I'm thinking that having the sleeve positioned so that the knuckle is in the deep groove yeilds to the notchyness of the 348 gear box. I am seriously considering setting it up so that the pad and knuckle are sitting in the shallow notches. My thinking is that this will take the notchyness out of the gearbox and lead to smotther shifting.
    But before I do this, I would like to find out if the smaller notches are a result of machining, or were they put there on purpose, and as in typical Ferrari fashion they don't tell anyone about it. My concern would be that if I did it would pop out of gear, or if I wanted to put it in neutral the sleeve wouldn't want to cooperate. It's seems like it would be fine, but what do you guys think?
  25. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I think that you may be on to something.
    DO IT FOR THE BROTHERHOOD!
    EDIT: one of the 550 drivers, I think in Kuwait right now, mentioned that his transmission had been rebuilt by an old Ferrari pro to shift fast and shift smoother than any transmission that he'd ever used...one has to wonder what the old pro did.
