Erotic oil temp - intermittant too :-) | FerrariChat
Discussion in '308/328' started by chrismorse, Feb 11, 2008.
  1. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Today, I got back from a 1000 mile trip with my 77 gtb, (31k miles). Twice, i had 130+ pound oil pressure on hot restart and running. My normal temp run is 120-130 dead cold, droping to 85-90 at 180 F with 0-20 mobile one. This pattern has been very consistent untill yesterday.
    My suspicion is that the oil pressure relief plunger is sticking in the bore and not yielding to the pressure to compress the spring and let the oil bypass.
    I have'nt taken things apart to check, but this is worrysome as i have an upcoming first track day.
    Help??
    chris
  2. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    809
    SF Bay Area
    John Borchelt
    Were you maybe thinking of that bumper reducer rod order when titling your post?? :)
    I know my gas gauge on my 308 does not match with reality often but the oil and water temp are usually dead on. I think your pressure is pretty good considering you are running that thin oil. I thought our old 308s ran better on the thicker stuff? I currently run 20W-50. Hopefully that's OK.
  3. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,054
    Coolum Beach AUSTRALIA
    Karen H.
    I want to know where to get the "Erotic" oil for my car!
  4. malex
    malex Formula 3
    1,249
    FL
    Perhaps K-Y expanded from personal lubricants to motor oil?
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    The relief valve sticks out the front of the motor by the crankshaft pulley. You could take off the cap nut and remove the spring and plunger and check for any nicks, dirt or grit hanging it up. You could also put a mechanical gauge on the oil filter housing and verify actual engine oil pressure directly. If you pull the relief valve, I would put the nut back on and start the motor without the plunger and allow it to (ONLY) idle a moment. That could clear any possible debris from the area, then reinstall the plunger/spring.
    I would watch it very carefully. If the pump is failing, debris from the pump could have fouled the relief valve. There really isnt much of anything downstream of the gauge that would block oil that much except a plugged main oil gallery inside the engine, and any blockage before (upstream) the gauge like a blocked oil cooler or plugged hose, would drop pressure downstream at the gauge. You better hope its the relief valve.
  6. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    thanks Paul,
    I will pull the plunger and inspect the bore. I thought i recently saw a thread with photos of a scuffed plunger. Does ayone recall the thread???
    Do 308s ever have oil pump problems?
    thanks,
    chris
  7. Steve Magnusson
    26,960
    I'd suspect the sender/gauge/wiring first (and rule them in or out) before messing with the mechanical bits (unless you are blowing oil out in places that it shouldn't be coming from). E.g., if the wire going to the pressure sender has chafed thru its insulation to ground, it would give a full scale gauge reading maybe intermittently. JMO.
  8. phdev
    phdev Formula Junior
    Dec 26, 2006
    338
    Nashville, TN
    Ian Mason
    erotic. lol
