Error Codes 4121 and 4114 on Engine 5-8 348TB Help! | FerrariChat
Discussion in '348/355' started by foxnick348, May 17, 2008.
  1. foxnick348
    foxnick348 Karting
    Nov 22, 2007
    56
    Racine, Wisconsin
    Nick Fox
    Hey Everyone.
    Re: 1992 348TB - Hesitation and stumbling 5000 rpm and higher after Washing car.
    I'm getting error codes 4121 and 4114 on Check Engline Light 5-8
    4121 appears to be because of the Cat ECU
    4114 appears to be because of the cam phase sensor
    Is my research from previous posts correct?
    If so, does anyone know the part #'s for the Cat Ecu's and Cam Phase Sensor.
    Seems as if something has gotten wet and is now faulty.
    What is strange is that when I purchased the car, dealer unplugged Cam Phase Sensor and when I brought the car home and inspected I noticed and plugged back in.
    Any help would be appreciated.
    Thanks,
    Nick
  2. Dean355
    Dean355 Formula 3
    Sep 4, 2006
    1,101
    South Florida
    Dean
    Nick,
    Before you do anything, clean all the connections for the sensors and apply Stabilant to the contacts, then clear the codes and check if the problem is solved.
  3. Davidt
    Davidt Formula Junior
    Nov 18, 2003
    713
    Ontario, Canada
    Dave T.
    +1 I had the same issue after I did a engine detail. Stabilant solved it. Good luck.
  4. foxnick348
    foxnick348 Karting
    Nov 22, 2007
    56
    Racine, Wisconsin
    Nick Fox
    Yes, I did clean and inspect all connections, but the hesitation still exists.
    I guess it might take a few days for the electronics to dry out.
    Seem like I can't drive the car in rain or wash the car.
    I will investigate further after a few days of drying out in the garage.
    If it still persists I will conclude the the drivers side cat ecu has been damaged when washing the car.
    I will also try unplugging the cat ecu on 5-8 and see if that does anything.
    Nick
  5. Dean355
    Dean355 Formula 3
    Sep 4, 2006
    1,101
    South Florida
    Dean
    Washing the car and letting water get into the engine compartment is an issue. I had that happen once after washing the car. Then I started covering the engine under the hood with old towels (engine cold), and avoided direct spraying of water over the engine hood as I washed the car. Pain in the a$$!
  6. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    I wash the car with the hose sprayer set on the shower/mist setting and aim into the air above the car and let it "rain down" lightly on the car. The car is built to handle rain so this approach works fine. Never aim the hose directly at the car and use high pressure water setting. Also, I bought a cheap tarp from Walmart and used it to cover the engine bay and shut the lid down on it. The engine stays virtually dry throughout the wash.
  7. Ricambi America
    Sponsor Owner
    Same problem here. Over aggressive hose = bad stuff.
    Mine did the same thing until I pulled connectors and used CRC contact cleaner then applied Stabilant 22a.
  8. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    exact same thing happened to me last night. the 348 is no swimmer... my light came on and dropped power about 10 mins into the drive immediately after washing. after a long drive and and a few stops and starts the car was fine. beside the light coming on and the power drop i also noticed erratic speedometer movement - has anyone had this? from this point on i will be taking the car for a good drive and covering the engine with something before washing. troy
  9. BobH
    BobH F1 Rookie
    3,138
    Morristown, NJ
    Robert H
    Your profile doesn't list your car but a 2.7 Motronics is 142581 and a 2.5 is 141037. Apparently the problem with this part is that the engine bay temperatures eventually dry and crack the plastic housing which admits moisture and it subsequently cooks the circuitry. I think they are about $600 a piece.
  10. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    For newbies, don't let the washing related issues dissuade you from driving the car in the rain. I have done it several times w/o any issues.
  11. foxnick348
    foxnick348 Karting
    Nov 22, 2007
    56
    Racine, Wisconsin
    Nick Fox
    The car is a 1992 348TB.
    I've let the car dry out for a few days and it's still having the same issue. I've cleaned all of the switches and filled up with gas.
    Hesitation and stumbling at about 5000-6000 rpm under heavy acceleration in 1st and 2nd gear, but eventually smoothes out if you give it more gas.
    I've got the bypass cat pipes and it backfires or spits back as well.
    Accelerating without hitting 5000-6000 rpm's is fine and crusing in 3rd, 4th and 5th gear is just fine.
    I've also unplugged the Cat ECU's and no change.
    Where else should I start looking??
    Thanks,
    Nick
  12. mjbcswitzerland
    mjbcswitzerland Karting
    Jan 8, 2008
    87
    Hi All
    I'm hanging this onto this thread since it is related.
    I have a 1991 348TB Chassis ends with 000090861 and assembly number if 7749. Since it has been playing up for a while (slow down light flashing and supposedly half of the engine intermittently cutting out due to cat. control unit problems - as disussed in various threads) I saved up and bought two new ones (to be on the safe side). I ordered parts 141037 for Motronic 2.5.
    When they arrived I realised that they had different plugs (4 wires instead of 6 on one cable) and, after taking out the old ones they turned out to be parts 142581 (they had serial numbers 296 and 297 or similar stamped on them - perhaps early production ones), which go with Motronic 2.7. Checking the Bosch part number on the units behoind the seats this seemed to match the M2.7 number too.
    Im my 348 repair manual it states that Motronic 2.5 is used in cars from 1989 to 1993 and Motronic 2.7 from 1994. It seems so straight forward that I didn't think about checking and now have two brand new cat. control units here with nowhere to go and have had to order two more of the correct ones.
    Somewhere I read that there may have been an upgrade done on post 1990 cars. Does this mean that my car was maybe upgraded back then? Is this typical?
    Also, if anyone wants two brand new units for M2.5 - part number 141037 - still in their box just tell me ;-)
    Regards
    Mark
  13. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #13 mj_duell, Aug 11, 2011
    I'm betting, cracked or wet crank sensor boots. Under the car at front of engine. Changed mine out for new ones and my wet driving stumble went away. Also, invest in a gold connector kit so you are not chasing ghosts.
    Helpful thread:
    http://www.ferrarichat.com/forum/showthread.php?t=236698&highlight=KIA+crank+sensors
    --Mike
  14. f27
    f27 Rookie
    Aug 12, 2014
    10
    Has this problem ever been solved? I'm experiencing the same, but nothing seems to do the trick...
