Ethanol in fuel | FerrariChat
Ethanol in fuel
Discussion in 'Technical Q&A' started by AceMaster, Dec 22, 2009.
  1. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    #1 AceMaster, Dec 22, 2009
    Hello, I was wondering if anybody knows whether or not we should be avoiding fuel that has Ethanol in it. I use Sunoco Ultra 94, but it has up to 10% Ethanol, and I am hearing that Ethanol is bad for the Ferrari engine. Is this true? Or maybe true only for specific Ferrari models? I own a 348. Or should it only be avoided during cold winter months? I am going to also post this in the 348/355 section. If it is bad for the Ferrari engine, what does it do to it?
    thanks in advance
  2. Steve Magnusson
    26,846
    Haven't heard that it's bad for IC engine metal components (although would like to hear the discussion/theory about how it could be a part of the 355 header problem as mentioned in the 348/355 section), but two areas that I think are fairly well established:
    1. Doesn't stored that well (and a lot of F are little used) -- the ethanol can separate out causing corrosion problems (see Dave Helms' posts), and
    2. reduces the life of the rubber components/hoses.
  3. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    Thanks Steve. You raise interesting points, hopefully someone will be able to shed some more light on this topic.
  4. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    Where I live it has been impossible to get auto fuel WITHOUT ethanol in it for at least 10 years. There's no way to avoid it.
    All my cars and lawnmower still run fine, including cars that are 43, 22, 12, and 10 years old with their original fuel systems.
  5. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Start by taking a hard look at the inside of your rubber based fuel lines. When I replaced my lower supply and crossover lines on the TR I went to Silicone Nomex thanks to the urging of Dave Helms
  6. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    Manufacturers have know about ethanol for decades. I've heard lots of anecdotal evidence of damage, particularly in the marine world, but does anyone here have actual proof of damage? I can't say that I've ever seen an instance when I could say conclusively ethanol was the fault of trouble.
    I'm not being argumentative, just asking the question.
    Tom B
  7. Rifledriver
    37,122
    #7 Rifledriver, Dec 22, 2009
    I recently replaced a fuel pump supply hose on a 308QV. It was a Gates hose of the current formula installed about 2 years prior. It was reduced to sponge. Cracks so large the fabric layer below the top layer of rubber was hanging out. The interior was collapsed and it was leaking profusely.
    Daves Scuderia Innovations hose is all we install now. We have rehosed numerous cars in the last few years with the Gates garbage. Can't wait to see what they say when my lawyer contacts them for covering costs to replace it.
  8. Rifledriver
    37,122
    #8 Rifledriver, Dec 22, 2009
  9. tomberlin
    849
    Bethesda
    tom berlin
    Brian-
    Is this assumed to be ethanol damage or bogus fuel line?
    I've never found Gates products in general to be impressive.
    I can accept either answer as I always value you opinions.
    TomB
  10. Rifledriver
    37,122
    Gates hose in general is the best US hose we have found that offers the range of hose we use most. If you don't like them you really wont like Dayco. Problem did not exist a few years ago so I am assuming it is gas formula. European products have in general been worse. Problem is far worse in cars that spend long periods unused.....like many Ferrari's.
  11. tomberlin
    849
    Bethesda
    tom berlin
    Sure would be interesting to see the response you get from Gates. Do you not like Wurth products as well? I always had reasonable experiences with their hose.
  12. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    Ethanol will also attack aluminum over time (gas tanks, hard lines, etc.). Ethanol content is usually dictated by the air quality regulations and vary from area to area. If given a choice, I try to buy the one with the lowest ethanol content.
  13. Speedmade
    Speedmade Formula Junior
    387
    Minneapolis, MN
    Reed H
    I'm building a hot motor for my GT4 to be optimized for E85 fuel.
    3.3 liter, 4V heads, big valves, 348 cams, custom EFI and 14:1 compression.
    I am building new fuel cells and plumbing to handle to ethanol.
    Of course it helps that we have ethanol refineries and over 350 gas stations that carry E85 here in Minnesota.
  14. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    IIRC, when it was first introduced here in Australia by Shell, Ferrari made an announcement that they didn't recommend its use.
  15. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    It was the response from Gates engineering staff 3 years ago that forced me on the path to build fuel hose after finishing the coolant hose. Gates Headquarters is right in town and I couried failed hose samples directly to their lab while they were still wet. New hose that failed within 10 mins with fresh fuel on a newly restored, Lucas injected Maserati Sebring.
    Now going on the fourth year of research, I now know more about hose than any sane person should. What has been written and discussed is but the tip of the iceberg and my research continues in other areas affected by the fuel. Some say its all a farce... others have had to deal with it.
  16. tazandjan
    39,195
    Ferrari started adding CYA alcohol notes in their owner's manuals in 2004/2005. The 2003 575M manual does not have it, and the 2005 does. No helpful hints, just if you use it it is not our fault if something goes wrong.
    Taz
    Terry phillips
  17. 12659
    12659 Formula Junior
    Oct 6, 2005
    349
    Seattle WA. USA
    mark
    I recently replaced the fuel pump covers on my 550. The pump covers themselves are a problem, just another cheap FIAT part. However in doing so, I discovered to my horror that the fuel pump isoation gaskets had deteriorated to the point that bits of rubber were floating around in the tank.
    After asking around I learned that Ferrari refuses to change their rubber products to handle the ethanol. I ended up replacing the isolation gaskets with the same. I will look forward to a repeat experience in about 10 years time.
  18. UroTrash
    Jan 20, 2004
    40,509
    Purgatory
    Clifford Gunboat
    Sadly, I read recenlty there is a big push for 15% ETOH. Now THAT will melt some rubber!
  19. gatorgreg
    gatorgreg Formula 3
    1,944
    NAPLES
    Greg Griffin
    #19 gatorgreg, Dec 23, 2009
    I am not having problems with my Ferrari's, but I am having troubles with my Marine equipment.
    I have Jetski's and the ethanol is playing havoc with the motors. I've heard the same thing is happening with the motorcycle industry too.
    The problem is when gas is sitting in the tank for long periods, the ethanol starts to seperate from the gas creating clumps of ethanol.
    The local repair shops are recommending using enzyme fuel treatment. I assume the enzyme is eating or preventing the ethanol from clumping.
    Although I have not used it in my Ferrari, it seems to work in the Jetskis, but not very well.
    Maybe some expert can chime in.
    If you can find it, do not put ethanol in your Ferrari if it is going to sit.
  20. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    Was not good for this Ferrari. Not sure if it had anything to due with cracked hoses, but somehow the gas vapors were escaping into the engine bay, so probably. Its an interesting watch and makes you think about what could happen with these cracked hoses like the one Brian posted.
    http://www.cbsnews.com/video/watch/?id=706226n&tag=api
  21. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I had to rebuild the carburetor on my two year old weed eater because it plugged up with disintegrated rubber bits from the fuel system and carb.
  22. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    I am in a 10% ethanol state and I know fuel lines on all my cars are calling for replacement more often....because of ethanol or just crap lines?...I don't know
    However, my carbed 308 is now running much better with the jets richer for the 10% blend.
    Truth be told, it was probably set lean at the factory for emissions but the more alcohol in the fuel, the larger the jets must be. Bought a A/F meter and played the jet change game until the mixture is right.
    The engine is very happy now
  23. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,310
    Ventura, California
    Robert Garven
    Friends,
    I am in the process of doing a major on my GT4 and I am buying all my hoses from Dave. the only ones I am out sourcing are the ones he does not have, which luckily are few and not fuel.... he has been amazing to deal with, a fount of knowledge, and I think he spent more of his valuable time helping me than the hoses cost. I love my car and am doing everything possible to make sure it is safe. BTW his coolant hoses are also the best! Will post pictures when done.
    The seattle car looks like one of the filler neck hoses.......
    Rob
  24. staatsof
    96,000
    Fuggetaboutitland
    Bob
    Well I was getting bored with the global warming "debate" anyway so now we have something new to discuss.
    I have 4 Italian toys ranging in age from 1979 to 1996 some of which I've owned since the mid 1980s and the 71 Espada (newest aquisition) is the only one where I've seen a real issue. The stupid interior gas hose in that car is now a solid line but when I bought it it had a brand new piece of aeroquip SS braided hose in there and it just never would stop stinking. No wet leaks but lots of vapour smell.
    My race engine guy who's worked with alchohol fueled cars for 30 years thinks that they've gone about as far as they can with this in commericial cars before we're going to start seeing some really bad trouble.
    I think those split fuel hose pictures are plenty bad enough.
    Bob S.
  25. staatsof
    96,000
    Fuggetaboutitland
    Bob
    Well this isn't Nomex covered and on your TR you're dealing with FI so it's a lot higher pressure but is the following something like you're talking about?
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260445489689
    Bob S.
