Ethiopian 737-8 MAX down. No survivors. | Page 21 | FerrariChat
Discussion in 'Aviation Chat' started by RWatters, Mar 10, 2019.
  1. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    With the motor in the back some kind of asssit at the wheel would help I imagine, but as you said more complexity to the situation. A box of wheeties to each pilot is easier.
  2. jcurry
    21,566
    In the past
    Jim
    Was just thinking about this more .....
    The wheel and cable system from the cockpit to the jackscrew in the tail is designed based on FAA regulations regarding min and max pilot effort. Thus the cables (braided steel wire) and associated brackets and pulleys are all designed around the resulting system forces due to the applied pilot effort. Adding a motor at the wheel that could provide more input force than the current manual pilot effort would result in a re-design of the entire system. Motor at the wheel would also need to have ability to be back-driven by existing FCS motor at the actuator. Basically you start going down a big rabbit hole, although the MCAS system was its own rabbit hole by scabbing onto a system where it was not part of the original design.
  3. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Yes I see where this would be going.
    Oh well, seemed like a good idea. I'll stick to building houses.
  4. INRange
    INRange F1 World Champ
    10,202
    Virginia/Florida/Caymans
    JD
    Just delete the MCAS code and let the trim switches control the motor. I'm not sure why they continue to overthink this. Maybe it is hubris "that deleting the code is admission of guilt".....they passed that mark two crashes and 400+ dead passengers ago. Delete the code and the runaway trim problem goes away. Sure....as a "safety program" it won't force the nose down but haven't we already established that is a bad idea?
  5. red27
    red27 Formula Junior
    Sep 7, 2010
    833
    London UK
    Mark Oliver
    Unfortunately for Boeing, the MCAS is only there to allow the 737 Max to satisfy FAA control loading requirements in one specific corner of the flight envelope. Remove the code and the aircraft will either fail certification completely or fail to be considered a 737 variant ....either would be disastrous for sales.
    All the software trickery is only there to compensate for the difficulty of mating modern large diameter engines onto an airframe with short undercarriage legs. I feel that in its previous iteration the 737 had reached the natural end of its development and should have been replaced with a clean sheet design. Maybe Boeing is thinking the same now.....
    boxerman, INRange and jcurry like this.
  6. TheMayor
    TheMayor Nine Time F1 World Champ
    98,776
    Vegas baby
  7. F1tommy
    F1tommy F1 World Champ
    10,297
    Chicagoland USA
    Tom Tanner
    TheMayor likes this.
  8. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    11,032
    Texass
    All in the name of the relentless pursuit of profits.... even after the lost revenue from grounding the planes until they get a firmware update, and paying out the inevitable lawsuits Boeing'll still be in the black, right?
    https://www.cnbc.com/2019/01/30/boeing-earnings-q4-2018.html
    4.2 Billion in earnings for the last 3 months of 2018. Nice war chest.
  9. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    11,990
    FRANCE
    French consulting firm Archery Strategy Consulting, that I never heard of until today...and can't say if they are serious or not...said yesterday that they believe the "737 Max" might well not return to the skies before 2020, and they believe that the final cost for Boeing might be "above 10 billion". They are quoted by most of the press this morning (sorry if the example is in french)
    https://www.challenges.fr/entreprise/aeronautique/737-max-l-addition-pourrait-depasser-les-10-milliards_661824
    Rgds
    tantumaude likes this.
  10. BubblesQuah
    BubblesQuah F1 World Champ
    13,047
    Charlotte
    Once the grounding is lifted, how long will it take to deliver all of the aircraft that were completed and stores during the grounding?
    I assume there are test flights and such for each aircraft. Will it take a long time to work that backlog?
  11. tantumaude
    tantumaude Formula Junior
    937
    Burlington, Canada
    Mat
    A bunch of friends and family members work for Air Canada. They are expecting no earlier than xmas, with the contingency plans covering until at least next February.
    You're 100% correct, each stored aircraft will need recommissioning checks (think fluids, consumables, etc), test flightS (plural), and every pilot will need competency checks (and likely retraining). I'm sure plenty of notice will be given, but it will still take at least a few weeks to clear all the backlog. We've seen a couple moving around under ferry permits.
    I expect the biggest challenge after re-certification will be convincing the public that it's safe again. I don't think any aircraft has ever faced that kind of scrutiny before (DC10 probably comes closest).
  12. nerofer
    Mar 26, 2011
    11,990
    FRANCE
    First order cancellation by "Fly a deal" form Saudi Arabia: 30 confirmed and 30 options cancelled.
    And no...I might be French, but I'm not necessarly an Airbus fan, so I'm not rejoicing in this; I like flying in Boeings, especially the "Triple 7"; will do again in two weeks...loved the 727 also, Air Inter/Air France kept some flying for the flights to Corsica well into the nineties, to my great pleasure. Was disappointed when they replaced these with A320s.
    I'm just interested in the facts, and the way the "Max" situation is handled.
    https://www.bbc.com/news/business-48899588
    Rgds
  13. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    7,917
    Shoreline,Washington
    Robert Parks
    If Boeing had continued to do things the way they were done on the 777 and 727 there would be no problems now. I'm toying with writing my experiences on how each program on which I worked (all but the 737) had their own faces depending on their times of beginning. The best of all was the 777.
  14. TheMayor
    98,776
    Vegas baby
    I think they paid too much attention to Southwest. Too many compromises to keep them happy.
    Ak Jim likes this.
  15. Gatorrari
    Gatorrari F1 World Champ
    15,939
    Georgia
    Jim Pernikoff
    Like cancelling the 757 in favor of revising the 737 one too-many times...
  16. Gatorrari
    15,939
    Georgia
    Jim Pernikoff
    Your long-awaited sequel, Bob?
  17. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,244
    I flew on a Delta 757 yesterday...I love that thing. So nice being able to board and not having to walk past 2 dozen rows to sit in row 24...only was about 8 rows past the door. :)
  18. TheMayor
    98,776
    Vegas baby
    The Dreamliner is an awesome airplane. No one has anything as innovative and user friendly to the passengers.
    Jaguar36 likes this.
  19. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    I don't know if anybody is waiting for a sequel but I have a never ending image of the differences in the programs on which I worked and how they affected the company. All were successful but every one of them required a base of hard work and quality. No work-around gimmicks or " creative business plans".
  20. boxerman
    boxerman F1 World Champ
    18,809
    FL
    Sean
    Headquarters in Chicago, lots of MBA's and Lawyers, youre going to get lots of work around gimicks and creative buisness plans.
    However a visionary of the type that built boeing post ww2 would see very clearly that regardless of how smoothly the best case for the 737 mnax goes forwards, the 737 brand and Boeing are tarnished. Fine in an enviroment where the only alternative is sold out near forver, but those conditions can and do change fast.
    What Boeing needs is a new plane in this category, something that makes people and airlines notice that this is a leading companay and leading into the future. Otherwise a decade from now Boeing witll be in serious crap.
    lets not forget that before jets Douglass was the airliner leader. lets not forget that the Electra even once fixed never recovered. Today Boeing has seriosu competition, and this comes from a company that no one took too seriously 30 yeras ago. A company that saw the future was twins, a compnay that designed for cargo pallets, a company that is seriously still growing and at least as big as boeing, a comnpany that swooped in and bought he bombardier program for peanuts.
    However Airbus is only halfway though the A320 program, theyre not about to design a new plane. Boeing can and must, esp as this class of aircraft is the 30 year future..
    jcurry likes this.
  21. jcurry
    21,566
    In the past
    Jim
    The 737 has had serious issues in the past and survived, even thrived. Was very surprised the model was able to get past the rudder actuator issue. More than a couple significant incidents and crashes involving over 150 fatalities and yet it was never grounded nor restricted. After the CO Springs crash I was apprehensive to fly on the plane. But they corrected the issue, and since then the model has indeed been a best seller. So never say never.
  22. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    The move to Chicago was the dumbest move ever and started the subtle downward slide of the company's character where it has become a two-headed beast where one head continually blunts the good work of the other. Now, it is obvious that a subsurface transformation has reared its ugly head with disastrous results. I'm not alone in my thinking that Boeing is suffering from DD....Douglas Disease. The way things changed after Douglas moved in is very evident in the approach of new programs and skimping money first and engineering second. Boeing has got to return to the old ways that made it a great company. Solid engineering first, well trained mechanics, strict Quality Control, stable and controlled business plans that eliminate the pie in the sky whizzbang "cost cutting magic" that has now cost this company billions. Choke collars should be put on the magic thinkers and bean counters that have led the company down a slippery slope.
    I'm not terribly smart when it comes to strategic analysis and all that like some of you are but I put in 45 years working for a company that ran a taught ship and had one objective...to build that best airplanes that could be produced. I sure don't see that now.
    tomkatf, Jacob Potts and Ak Jim like this.
  23. boxerman
    18,809
    FL
    Sean
    But this time it was grounded and is a global scandal. This time Airbus has its game on. You can also only stretch piece of gum so far. Yes they can put articulated landing gear on it and raise the height for even bigger engines, but that again is another work around. Yes the public will forget, or no one will care or really know what plane theyre getting on anyway. But that strategy just leads to a continual erosion of Boeing in the most profitable and most volume part of the market.
    True airleiners are tubes with wings and tails attached, and the 737 tube is adequate and the wings and tails work. So maybe a new plane is not such a huge efficiency leap. But perception is everything, as is leadership.. Detroit big 3 lost out while other lead and invoated, they used to own that 70% of their market.
    Airbus intialy lost out with the A320 because it was more expensive to produce and less fuel efficient, but the a320 had intirnsic growth in its bones the 737 cannot match and now Airbus is in the pound seat. The long range transatlantic A320 going into production has no competitor, and who'l buy and even more stretched 737 after this.
  24. boxerman
    18,809
    FL
    Sean
    This is simply a fantastic post and says it all.
  25. Bob Parks
    Nov 29, 2003
    7,917
    Robert Parks
    I should clarify my statement about is being done at the Kite Factory. The engineering staff in PD is one of the best in the world, the engineering in the project (production) side are an unknown factor to me now since so many gray beards are gone and took vast amounts of skill, knowledge, years of experience, and most important, their dedication to their job and good character. These two disciplines produce outstanding work , the best in the world. BUT it is squandered when the business combines get their hand on it and work hard to figure work-arounds, cost cuts, and worst of all, off loading production contracts to unvetted and unskilled "partners." The 787 debacle was a wake up call that I don't think has awakened everybody in Chicago yet. The big domes back there have found another cost cutting idea. To get rid of Quality Control. I'm willing to bet that the Einstein that figured this out has never been near the production floor or involved in the complicated processes of putting a Big Tin or Plastic bird together. Obviously he hasn't read the reports of finding tools and debris in the closed compartments of some of the airplanes on the line and in those that have been delivered. From my experience years back, there would be no yelling or mean talk about this kind thing. There would have been swift changes and removals (not just the tools or debris) and a strict tightening of operations FROM THE TOP DOWN.
    Jacob Potts and boxerman like this.
