EU Plans to Fit All Cars With Speed Limiters | Page 2 | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by PhilNotHill, Sep 1, 2013.
  1. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,870
    This won´t happen, but if it happened, it think it would some benefits. It would force manufacturers to concentrate in other things, like making smaller, nimbler cars for mountain roads, which is not a bad thing in my book. It would also bring better looking and bigger variety of designs, as at low speeds aerodynamics are less relevant.
    Although I´d put a higher speed limit, something around 150-160 kph.
  2. papou
    papou Formula 3
    1,751
    plantation Fla
    daniel ross
    In England we have a wonderful word for the EU commission
    WANKERS.
  3. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    Or those who have "truly gone fishing"!!
  4. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    with an endless supply of rocket polish
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,458
    On the Limit
    Dino
    I notice that most of the folks who seem to think this is a good idea, have little to nothing in their profiles and of course have no Ferrari.
    If the socialists manage to sell this to an ignorant public based on the safety fantasy, they deserve it.
    I think Ben Franklin said something to the effect of.... People who are willing to give up freedom for security, deserve neither.
  6. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,870
    For one moment forget all the crap that belongs to PR and think about the acceleration of a 600 bhp car with gear ratios for just 150 kph.
    Whoa.
  7. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    721
    It won't happen primarily due to the revenues that go to governments due to speeding traps (cameras, etc.)
  8. deppi0
    deppi0 Formula 3
    Jun 30, 2010
    1,246
    London, UK
    Edmondo
    +10000 :)
  9. AndrewG2
    AndrewG2 Karting
    Feb 22, 2013
    115
    Las Vegas NV
    This is just the minority trying to impose there will on the majority. The same thing is happening here in the good old USA. Im sure Obama, Pelosi, Reed and all there Hippie friends are going to work on this one.
    The threat of job losses doesnt bother them either, just look at the EPA and there war on coal.
  10. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    IMO, they should put their money on improving collision-avoidance systems instead. These can come in many different forms that can all work together without being heavy-handed.
    For instance, combine a proximity detection system and brake boosters to ensure sufficient braking pressure is applied during collision avoidance. Many accidents occur because people simply don't brake hard enough around the mid-point of their brake application. This can be easily gauged by a computer that knows the closing speed, rate of deceleration and distance to the object in its path.
    Then there are the systems that automatically maintain a safe distance between your car and objects in its path.
    Blind spot monitoring systems would also benefit everyone. Along the same lines, some sort of situational awareness display would help monitor vehicles around your car. If the same system is combined with GPS maps, traffic sensors, posted speed limits, road condition reports, rain sensors, road surface temperature sensors, ABS/slip sensors the system can warn you of a potential mismatch between your speed and road conditions as well as sections of roads you are approaching.
    A simple display to tell the driver how slippery the road is, based on sensor readings, can help the driver adjust appropriate driving response. They don't have to set off alarms - they can be a simple display.
    My '86 BMW used to issue warnings of icy roads based on road surface temperature determinations from its temp sensor. It worked well.
    In a nutshell, implement systems that make the car work better, correct potentially catastrophic driver error and provide more useful information for the driver so the driver becomes more thoughtful and is better able to make sensible driving decisions. Applying a speed limiter assumes everyone has no brains and is incompetent.
  11. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
  12. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I found the German speed limits and trafic rules to be some of the most reasonable anywhere. The speeds in busy towns are low and they expect you to behave. The highway speeds are reasonable and much higher than the US. And the German speed limiter is 155 mph, which is a long way from 70.
  13. ScuderiaWithStickPlease
    ScuderiaWithStickPlease F1 World Champ
    Dec 17, 2007
    10,263
    NY Metro
    Agreed. But that doesn't change the fact that they inspect cars at random, and that they'd be able to quickly ID modified speed limiters if they wanted to.
  14. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,273
    Worcester, England
    Phill J
    The German manufacturers factory set 155mph limit is simply a Gentleman's agreement that they all agreed upon, there's no legal legislation for it, and they are not all set to exactly 155mph! (if you get My meaning! ;) ).
    Also, there are ways to drive around the limiter, even with the standard factory ECU set-up, for example, when you hit the limiter in top gear, drop down a gear and for a few seconds you can accelerate to a speed above 155mph. After a few seconds, the ECU cottons on to what's happened and pegs you back to "155mph" but you can simply repeat the process over and over again.
    Added to that, if you pay for the performance package on such cars as the BMW M5, they will not only reprogramme the ECU for more power, but they will also remove the limiter!
