Euro 30GTSi QV Cam Specs | FerrariChat
Discussion in 'Technical Q&A' started by ctk, Oct 10, 2005.
  1. ctk
    ctk Karting
    Jul 2, 2001
    238
    Singapore
    Guys,
    Can anyone help me with the correct valve clearances for a F105A type engine for the UK market please?
    I have the USA specs which state: With COLD Engine
    Intake: 0.20 + 0.25mm
    Exhaust: 0.30 + 0.35mm
    I am not sure if this is the correct clearances for the Type F105A.
    Anyone with the correct data?
  2. ctk
    ctk Karting
    Jul 2, 2001
    238
    Singapore
    Any help gentlemen?
    Would really appreciate it, as I am attempting to get the work done today.
  3. Steve Magnusson
    26,826
    The 308QV-328 Workshop Manual 550/89 lists the values that you show as for the F105A engine. However, the US 308QV OMs (260/83 and 307/84) and the standard version 308QV OM 248/82 show the intake as the same, but on the exhaust side they go up to 0.35-0.4 mm clearance cold.
    What is your reference for the exhaust side of a US 308QV being 0.3-0.35 mm clearance cold?
    Can you hit 0.35 mm exactly? ;)
  4. ctk
    ctk Karting
    Jul 2, 2001
    238
    Singapore
    Hi Steve,
    How are you doing?
    Due to our International Time Zones, I am just getting the mechanic to do now. Will let you know if we can hit 0.35mm exactly.
    The local Ferrari workshop uses the following specs. for the F105A
    Intake : 0.20mm + 0.25mm
    Exhaust: 0.35mm + 0.40mm
    Shims are apparently from the old Volvo 240 series engines.
    Will get back to you on what is on my engine at the moment before they are adjusted. Apparently the cams have been timed on the engine. I wonder why and will get a better idea when I measure the settings myself.
  5. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #5 Ferrari_tech, Oct 12, 2005
    Uk spec is the same as you have posted...............
  6. ctk
    ctk Karting
    Jul 2, 2001
    238
    Singapore
    Steve,
    Got the clearances checked and adjusted. Apparently, they were on 'spec'.
    INTAKE : 0.20mm
    EXHAUST: 0.35mm
    This is on a F105A (UK) spec engine.
  7. Steve Magnusson
    26,826
    Sounds good -- I think you're safe either way (and this adds to the confusion because there's no strong reason for F to correct or clarify themselves on these minor spec discrepancies). I had an anecdotal recollection in my head that when the continous air injection systems were added, they upped the exhaust side clearance a little bit for the higher exhaust temps, but I can really find no evidence to support that (so I'm trying to get it out of my head ;)).
