Euro Car Aircon Recharge. | FerrariChat
Discussion in '308/328' started by cessna, Sep 10, 2016.
  1. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Hi,
    Does anybody know the quantity of the new aircon refrigerant so as to recharge my system. My owners manual states the old refrigerant value.
    Regards,
    Stephen
  2. 2281GT
    2281GT Formula 3
    Oct 9, 2006
    1,134
    Germany
    Markus
    1,1 kg filling up , 1,3 kg complete new filling. Just done 4 weeks ago, used R134a.
    Better to evacuate the system before new filling.
  3. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
  4. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    First thing you have to do is determine what refrigerant was in there. Are you sure it's 134? My 1980 has R12. In other words, you better check. Good news is that the fittings are different, so you can't screw up :)
  5. Dr Tommy Cosgrove
    36,445
    Birmingham, AL
    Tommy
    It had R12.
    Unless you source more R12, you will need to convert and that does not simply mean change fittings and refill with 134. You will have some problems, mostly from it leaking through the hose material. Won't blow as cold either.
  6. AP328
    AP328 Karting
    88
    Canada
    I don't know the quantity of R12 that a 328 requires, but I have been told by our mechanic that due to differences in the refrigerant, when using 134, it should be filled at 80% of the original R12 requirement. We did this on a non-Ferrari this year, and found the system was cold and worked perfectly. If the 134 fill rate is used, then the system will blow less cold. We just did 80% of the R12 fill on our 328 at a major service and it is blowing cold (which it didn't on the last fill - so we presume it was overfilled previously).
  7. Dr Tommy Cosgrove
    36,445
    Birmingham, AL
    Tommy
    You are still going to have problems with you old non barrier hoses.
