Euro Dino Front indicator lights (Mathias please help?) | FerrariChat
Discussion in '206/246' started by premieram, Jan 12, 2018.
  1. premieram
    premieram Karting
    Jun 10, 2004
    211
    All over the place
    Joseph T. Seminetta
    All (and particularly Mathias):
    I am reworking the front end of my Dino to look like a European spec car. This means changing the front indicator lights from the recessed rectangles to the trapezoidal flash lenses ( yes I understand the metal work involved ). From the various photos, it appears like there are two shapes of these lenses. One is like the car below from Mathias’ book (Which has a flat vertical inside edge):
    While the others appear to have an angled inside edge (like the photo of the replacement lens in the package).
    Did they produce two different lenses or is this just optical because of the photos? I would really like to find the one with the flat vertical edge if did they produce two different lenses or is this just optical because of the photos? I would really like to find the one with the flat vertical edge if it exists.
    Please let me know your thoughts.
    Joe
    miurasv likes this.
  2. pshoejberg
    pshoejberg Formula 3
    1,696
    Denmark
    Peter H
    Optical illusion.....
    Best Peter
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,411
    Toronto / SoCal
    Rob C.
    There has only ever been one light. What you see in the photos is as Peter said an optical illusion
  4. swift53
    swift53 F1 Veteran
    6,733
    E.S.
    Alberto
    Love the change to European. You can save the pieces you cut out, and can always
    go back to original if required.
    Regards, Alberto
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,838
    Norfolk - UK
    Tony
  6. premieram
    premieram Karting
    Jun 10, 2004
    211
    All over the place
    Joseph T. Seminetta
    Thanks everyone. I will more about the car in the future. Placement of these is crucial. I have seen them look so right and look like kit cars on others. I want to create the “optical illusion” that is in many photos :)
    I am just going to have my body shop (which is one of the best in the world), go off of the pictures. Any placement/alignment advise by those that have made the conversion is very welcome.
    Joe
  7. racerboy9
    racerboy9 F1 Rookie
    2,523
    I am not a fan of changing the original configuration but if you are bent on doing it I would try and find a euro Dino you can take measurements from rather than just from pictures. Sheet metal work and a paint job aren't cheap so you want to get it right the first time.
  8. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,654
    Southern California
    I agree with this. You really need to make super accurate templates by using the lower hood shut-lines and headlamp recess. I wouldn’t just trust a body shop no matter how good they are. Also definitively keep the original sheet metal pressings. Also, really ask yourself if you’ll be happy with a conversion vs selling yours and just buying a Euro spec Dino.
    Freeman
  9. swift53
    swift53 F1 Veteran
    6,733
    E.S.
    Alberto
    Joe, sent you a pm.
    Regards, Alberto
  10. premieram
    premieram Karting
    Jun 10, 2004
    211
    All over the place
    Joseph T. Seminetta
    All:
    This is been an interesting process. I’m absolutely convinced that the solution is optical based on both the Dino body curving to the side in the angle of the hood coming front to back. I have seen this conversion done poorly and having it right from every angle is key to making this look correct. Thank you for everybody’s help. I will post pictures when the car is complete.
    JTS
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    They are not very good when I bought them, castings off of an original part subject to shrinking in cast.
    I had this done and each one will be custom no matter what car you pattern it off of. In fact, since the bracket and housing may be reproductions and slightly different sized, you should probably get the housing/bracket before cutting any metal
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,838
    Norfolk - UK
    Tony
    most items today are reproduction, the chances of finding OEM parts would be extremely rare.
    I had this issue with a replacement water pump but the quality of the product was good although not 100%. Either that or no pump!
  13. swift53
    swift53 F1 Veteran
    6,733
    E.S.
    Alberto
    Fibreglass is the solution for the housing, no distortion or shrinkage. As far as the sheetmetal, easy.
    Believe me, I know, as many others do :)
    Regards, Alberto
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I do have a spare set of the Shaughnessy reproduction housings, I got through Garry who apparently got the lot and sold them.
    In any case, definitely buy your housings before doing any metal work as you can not count on any being a standard size
