Euro drysump gtb diamond in the rough | Page 2 | FerrariChat
Discussion in '308/328' started by Rock, Jan 18, 2011.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,337
    Edwardo
    Sorta,, the 226245 are just like the 108947.
    The NEW Ferrari and concorse recognzed replacements came out in 2008.
    Anyway, this is correct for a 1977 GTB
    and is not Correct for a 355,,,,,,,,,, so why bother.
    Grazzi for your interest.
    Edwardo
    Cap for sale cheep.
    PM me.
  2. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    Hello Steve I will try to find you some nice console photos.
  3. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #28 Rock, Jan 19, 2011
  4. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #29 Rock, Jan 19, 2011
    some super stars idea of a perfect location for a tweeter. This door panel will have to be rebuilt and recovered with new leather. This hole is the only bad thing about the interior.
  5. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #30 Rock, Jan 19, 2011
  6. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    the rocker panels are in excellent condition, they needed some straightening in the normal spots (near the gas tanks). We also repaired the rear mounting brackets and re-spoted welded them together.
  7. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #33 Rock, Jan 19, 2011
  8. SteveG75
    SteveG75 Formula Junior
    Nov 23, 2010
    380
    FL
    Stephen
    Nice picture of the door panel. Mine have been recovered but they covered over the plug for the manual window crank. I have the crank but no way to use it. LOL.
  9. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #35 Rock, Jan 19, 2011
    the motor is removed and the entire assembly is pressure tested, then the hard work begins. Line honing of the cam saddles in the heads, all of our engine rebuilds are line honed. When we installed the reamer it would not turn! Imagine how much horse power was lost turning four cams!
  10. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    Steve there is a special two piece aluminum grommet that fits in the hole for the handle, then the button shapped plug pops into that grommet. Who ever recovered the panel must have destroyed the grommet.
  11. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Rock, Are you planning on keeping this car when all is finished, or selling her? :)
  12. red3555gtb
    red3555gtb Formula 3
    1,356
    Woodbridge/Ontario
    Rocco
    Sorta the same, different shade of yellow and horse is also different.
  13. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,670
    Avvocato
    ROLMAO - what do you think ;)
  14. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #40 Rock, Jan 20, 2011
    another shot of the rocker panel and jacking point bracker. I know that most people will not be able to see the rocker panel, but when I do a ppi the rocker panel gives an indication of how the car was treated.
  15. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #41 Rock, Jan 20, 2011
    the heads studs on the intake and exhaust side have been removed and are on the way to the platers. We have been plating fasteners and bracket for about 18 years before it has become fashionable.
  16. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #42 Rock, Jan 20, 2011
    the piston crowns look in good conditon for being 35 years old. There is little or no corrosion in the cooling system. We have started the intial cleaning of the heads, as we are going to disgard the valves, springs and guides for a new entire valve train. when your inside don't cut corners.
    The combustion chamber have never been welded, so the valves must be original as the car has 38kms or about 25k miles.
  17. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    #43 Rock, Jan 20, 2011
  18. of2worlds
    of2worlds F1 World Champ
    18,690
    ON
    CH
    Rocco very nice to see your project here. Certainly helps that you are covering familiar ground with this rebuild! Smooth sailing...
    CH
  19. brettski
    brettski Formula 3
    Feb 29, 2004
    1,754
    north of toronto
    brett swaykoski
    it's about time you decided to share some of your work with us Rock...who taught you how to upload pics ?
    lucky car to be in your hands...great project, keep us posted !
  20. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,940
    Atlanta
    John!
    Rock, if there is one thing I regret not doing with my rebuild, it's that I should have had pistons made which raise the deck height of the piston at least .055. The issue is the stock pistons sit inside the sleeve .055, and that distance combined with the compressed head gasket thickness of .050 makes for terrible quench and combustion efficiency. You want it to be between .040-.045. Doing this allows for less total ignition timing to be needed and much greater efficiency.
    In my future project, I will surely go this route.
  21. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    Great thread , we have identical cars .
    I'm very happy to see that you don't seem to have a removeable panel above the steering rack in the spare wheel well ? I noticed this in another thread and wondered if my car had been previously repaired and this panel had been covered over ?
    Your head studs came off clean and look good !!!
    Thanks for sharing
  22. jasonlanglois
    jasonlanglois Rookie
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    please excuse a question from a guy just learning the process...
    if the cam turned 'freely' from the factory and you're line reaming with the heads still on, how do you know why the cam wasn't turning freely, ie. that the head wasn't warped or twisted ?
    now material has been removed. what's the recourse if the head was twisted ? won't the new head gasket be compromised ? if your not removing the head, how are you ensuring that all of the filings visible in the pictures does not stay in the engine ?
    thank you,
    J
  23. BigTex
    79,408
    Houston, Texas
    Bubba
    He said the cutting reamer would not turn, that's different from the installed cam with smooth journals and lubrication present.....point taken though......
  24. brettski
    brettski Formula 3
    Feb 29, 2004
    1,754
    north of toronto
    brett swaykoski
    later pics show the heads off the block...
    but it's deceiving with the way the pics are shown, because it does look like the saddles were reamed before the heads were removed.
