Euro fuse box labels | FerrariChat
Discussion in '206/246' started by mar3kl, Dec 6, 2021.
  1. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    While I was checking out my wiring this weekend I noticed the repro label on the red fuse box isn't the same as the original that came with my car. The black fuse box labeling is fine. The repro is from Parker Hall, but Superformance and Dino Parts have the same (wrong for me) labeling. Any idea where I can get the correct label? My original is the top photo, the repro is the bottom one. In position 1 (leftmost) mine says Heater and the repro says Ignition. Positions 2 and 4 are swapped and my Instruments label is combined with Electric Pumps in position 3 where the repro has it in position 4. Image Unavailable, Please Login Image Unavailable, Please Login
  2. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,486
    Germany
    Matthias
    your labels are for late E-Series....
    the second labels, so the reproduction ones, are for early E-Series... I would think the change could have been around a/c introduction.... so around #02768...
    does anybody have the later label around chassis no. #03000?
    I would be interested in a set of the later lebels too if authentic repro....
  3. mar3kl
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    As far as I can tell, my "Heater" wire is actually an ignition wire. I don't even know what Heater means, because the only electrics are ventilation fans, which are definitely on a separate, properly labeled circuit. All the other stuff matches the original labels.
  4. GermanDino
    Aug 14, 2007
    3,486
    Germany
    Matthias
    heater is: air conditioning (a/c)
