Euro model front indicator/parking light cross slot screws | FerrariChat
Discussion in '206/246' started by GermanDino, Oct 6, 2023.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,485
    Germany
    Matthias
    dgt likes this.
  2. bradley baum
    bradley baum Rookie
    May 1, 2005
    36
    Me too.
    Thank you.
  3. gcalex
    gcalex Formula Junior
    607
    Mostly New Hampshire USA
    Alex
    Believe it or not, you could probably scan and then 3D-print that in either bronze or stainless (both of which you could then plate); I have done some stuff like that successfully.
    Expensive, however; probably something like $50US per screw to fab, and you need a very fancy scanner (and of course, an original) to get a good copy.
    Nicolas21 likes this.
  4. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,299
    Sergio Tavares
  5. pshoejberg
    pshoejberg Formula 3
    1,818
    Denmark
    Peter H
    It’s not self tapping. I would call it guided witch makes sense for the purpose. Nice screw that would work much better than the chromed screws that tend to corrode very fast when used in that exposed location. I’m in for 4.
    best, Peter
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Those are called either a Narrow Cheese Head or Fillister Head screw and are available:
    https://www.mcmaster.com/products/screws/rounded-head-screws~/narrow-cheese-head-phillips-screws/
    https://www.mcmaster.com/products/screws/rounded-head-screws~/high-profile-narrow-fillister-head-phillips-screws/
    For a PERFECT match you need to do a little machining but they are very close to perfect out of the box. A polish with polishing paste while spinning them in a drill will give you a perfect chrome finish look.
  7. DinoParts, Stefan
    Sponsor
    Mar 1, 2015
    141
    Eschwege, Germany
    Stefan Kratzer
    #7 DinoParts, Stefan, Oct 9, 2023
  8. swift53
    swift53 F1 Veteran
    8,272
    E.S.
    Alberto
    Great find Rob!
    Except, the taller ones only are in inch thread.
    The slightly lower ones are metric. They can be raised with clear plastic washers.
    Regards, Alberto
  9. GermanDino
    Aug 14, 2007
    3,485
    Germany
    Matthias
    yes, the original ones are made in stainless steel.... !
  10. GermanDino
    Aug 14, 2007
    3,485
    Germany
    Matthias
    Stefan, possible to do a remake in stainless steel?
    They were original even to the early cars (206 GT) up to the late cars (E-series)
  11. DinoParts, Stefan
    Sponsor
    Mar 1, 2015
    141
    Eschwege, Germany
    Stefan Kratzer
    I hink its feasible, Matthias. It would be easy to 3D-print but one would not like the surface of areas that aren't reachable for grinding or polishing, so I have to see if our CNC guy can mill the phillips head. Will finalize the desgin, enquire and report back.
    GermanDino likes this.
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    #12 TonyL, Oct 10, 2023
    I tried to locate these screws a few years ago but was unsuccessful.
    Beware they are not normal pan head machine screws, the head diameter is much smaller at 6.85mm (most are standard machine screws at 8mm dia. and dont fit inside the lens cover hole)
    Also 12mm is too short and greatly depends on where the lens housing is mounted. I would make them 20mm overall length instead of 14mm. Better to be too long than too short!!
    Tony
  13. GermanDino
    Aug 14, 2007
    3,485
    Germany
    Matthias
    Tony, on all my cars the original length of 12mm fits.... I´m just looking for original ones or remade to original specifications...
  14. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I have the original ones I found some time ago and are 14.52mm long (overall) but they are a tad to short, maybe if i moved the actual housing forward they may be OK. Its a lot of messing around so am looking for some a bit longer.
  15. GermanDino
    Aug 14, 2007
    3,485
    Germany
    Matthias
    14.52mm long (overall) is correct....
  16. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Beware - the hole in the lens cover is just over 6mm dia so these are no good unfortunately. The head dia must be 6mm max otherwise they will protrude above the lens cover.
  17. racerboy9
    racerboy9 F1 Rookie
    2,642
  18. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    With a lathe handy to take down a fraction of a mm from the diameter of the head these work very well:
    https://www.mcmaster.com/91737A127/
    I know the first thing people will say is that those are imperial and the originals are metric. This is entirely true but the 8-32 thread is very close to the M4 and because it is threading into a cast aluminum thread that is far from precise and it is not a critical fastener with specific torque, most people will find that the 8-32 will thread right in without force and you would never know the difference. Given how cheap this option is and how close the screws are it is worth trying them out.
  19. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Rob, worthy solution on paper but in reality the pitch is close but not close enough, the unc bolt will lock up within a few mm and potentially strip the threads very quickly without to much effort.
    I'd stick with the M4 machine screw, plenty on the market but the head diameter is the biggest stumbling block.
  20. gcalex
    607
    Alex
    If the pitch really is pretty close, one might be able to re-cut the threads with an M4 die, so that they match the needed pitch; still, reducing the head might be easier (if it is just a couple of screws to do, putting the screw in a drill (drill grips the shaft of the screw), and holding the head against a file will likely get you what you need).
  21. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Re-threading the screw to M4 wouldnt work as the pitch would recut & destroy the UNC threads after 5mm. Tried it:)
    The original screws are brass and chrome plated (they are on my car!) so you would have to use stainless steel screws to avoid destroying the chrome plate!. Bottom line is a compromise, you only ever see the actual head of the screw once fitted so a philips type head would be the best option.
  22. gcalex
    607
    Alex
    There is never any substitute for "trying"... :)
    If you've lost an entire thread after 5mm, then the thread pitch can't be all that close; sounds like it is best to stick with an M4...
  23. DinoParts, Stefan
    Sponsor
    Mar 1, 2015
    141
    Eschwege, Germany
    Stefan Kratzer
    Here is what you get from this source compared to the original one:
    And this is what you can machine out of it:
    Our CNC guy fainted when I asked if he could mill the philipps head. I have one more enquiry at a fastener company and if they don't want to make the small qty., adapting these could be the best option.
