EV Conversion | Page 3 | FerrariChat
EV Conversion
Discussion in '456/550/575' started by vraa, May 30, 2024.
  1. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
  2. otoupalik
    otoupalik Formula Junior
    566
    Scottsdale, AZ
    Brad Otoupalik
    That is a great question, I bought these HRE’s used and am not sure. I’ll see if I can figure it out. I did help another owner here order some and we did figure out a pretty good fit.
    I will say the 325 is not even as wide as the wheel!
  3. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
  4. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
  5. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    Love that site.
    rear looks close. Front is a 265/35-19 but the offsets look pretty close. I’ll look some stuff up tomorrow.
  6. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,396
    MO
    I like the Brembo kit….
    NE550 likes this.
  7. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
    I wanna do ceramic, I might copy Taz's size of 396mm front and 362mm rear, I'm still doing some research
  8. Auraraptor
    Sep 25, 2002
    13,396
    MO
    If you decide OEM HGTC, the missing NLA part will be available soon….
  9. Auraraptor
    Sep 25, 2002
    13,396
    MO
    #59 Auraraptor, Jun 11, 2024
    I should add, IMHO, the optimal offset/ size spec is front 9in ET 32-38 range, rear 11.5in ET 17-22 range. If you want to run a 13 inch rear (yes it fits) the offset would be et28.
    I would not go lower then et 28 front or et10 rear
    NE550 likes this.
  10. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
    Otherwise you run into rubbing?
  11. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    Here is what @Depreciating Asset did. A few of us had a private conversation about this and the pics are what he ended up with. Hopefully he will see this and jump in.
    Front Wheels
    20" X 9.5" ET 41mm
    275/30 ZR20 MPS4S (diameter is within 1.5% of stock tire diameter)
    The Math:
    9.5 X 25.4 = 241.3 Wheel width in mm
    241.3 / 2 = 120.65 Center of Barrel
    120.65 - 41 = 79.3 Distance from hub to outer edge.
    241.3 - 79.3 = 162 Distance from hub to inner edge
    ***Inner edge of the wheel is approximately 10mm (.4”) further inside than the stock wheel with no spacer.
    Rear Wheels
    20" X 12" ET 26
    325/25 ZR20 MPS4S (diameter is within <1% of stock tire diameter)
    The Math:
    12 X 25.4 = 304.8 wheel width in mm
    304.8 / 2 = 152.4 Center of barrel
    152.4 - 26 = 126.4 Distance from hub to outer edge
    304.8 - 126.4 = 178.4 Distance from hub to inner edge
    He has a GREAT source for these wheels too. He had them made to look like modulars.
    575, Face76 and vraa like this.
  12. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
    otoupalik likes this.
  13. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    That is not a bad price for real CF overlay and billet center!
  14. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
    It's the same company that did my tesla wheels, I worked with them to get the load rating up to 950kg - it did increase the weight of the wheels, 13.9kg (20x10) in front 14.5kg (20x11) in the rear
    I don't think I'll need that high of a load rating for this car
  15. Auraraptor
    Sep 25, 2002
    13,396
    MO
    Otherwise it drives poorly IMHO. If aesthetics are the goal, there was a member who had custom ultrawide HRE front/rear who would be great source. He had quite impressive offsets and filament.
    vraa likes this.
  16. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
    I'm going to stick with a good driving experience, not looking for only show
    Auraraptor likes this.
  17. vraa
    vraa F1 Rookie
    3,921
    Texas
    Mr. A
    Cool beans, I just got a reply back from Fabio about doing the h pipe and the rear straight pipes in titanium or inconel, the headers/manifolds I'll keep stainless steel and get them cerakoted. I think I'll take off the capristo valve less rear muffler boxes, and also keep it in the vacuum sealed bag
  18. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    The “experience” is never made worse by wider wheels/tires as long as they fit! In fact ours is much better now as it actually has way more grip and also looks better!
    I do agree that having a fitment that requires changes to alignment or ride height to work will and does lessen the handling and experience. however, just getting a great fitment will have no drawbacks.
    but I owned a race/custom shop for 15 years so I am biased. I always get as much tire as I can under a car and at the same time build the right look. Nobody in our family has ever kept stock wheels on any car we have owned for 30+ years!
  19. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    That will sound amazing! Great call on coating the headers! Where are you located? I have a great place to coat them in SoCal if you can ship. Reach out to embee performance. They did all of our header coating for the production pieces we made as well as a ton of work for cp pistons and others in the industry.
  20. Auraraptor
    Sep 25, 2002
    13,396
    MO
    Thats true until you are over tired or have screwed up the scrub angle and are now fighting tramlining….
  21. NE550
    NE550 Formula Junior
    Mar 23, 2017
    424
    Omaha, NE
    Dave
    Don't get the OP's question. Converting a Maranello to EV makes ZERO sense. Seriously...why???
  22. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    its a joke, he is not being serious.
    vraa likes this.
  23. JohnnyRay
    JohnnyRay F1 Rookie
    3,014
    Central FL/NW WI
    I have Novitecs on my 550 now. 12.5" x 19" on the rear (with 25mm Hill spacers). I recall the tire size may be 345/30R-19 (Michelin Pilots) - tbd.
    Ferrari55whoa, otoupalik and vraa like this.
  24. JohnnyRay
    JohnnyRay F1 Rookie
    3,014
    Central FL/NW WI
    Seems to me that a set of 25mm or 30mm rear wheel spacers would go a long way towards filling out the wheel openings on your 575. You might be pleasantly surprised just how much that improves the look. Other than that, and as a few others have also suggested, perhaps get to know the car before making all these mods right out of the gate. My two cents...
    vraa likes this.
  25. otoupalik
    566
    Scottsdale, AZ
    Brad Otoupalik
    Back in 1999 I made the first set of 30mm tug approved spacers (using our car as the template). It’s when I had my shop. We had H&R make them for us and that is how we had TUV. I agree that they are perfect. 25 is too little for stock wheels imho.
    But when making custom wheels, no need for spacers as you can just build the wheel with the right offset!
    btw, the novitecs look great. We were a dealer for them back in the day and put those on a few 430’s (even did a couple twin screw upgrades, one for a celebrity that I drove daily for 3 months at his request). Fun days being in the biz back then.
    Ferrari55whoa likes this.
