Evans Coolant | FerrariChat
Evans Coolant
Discussion in '456/550/575' started by Euroflier, Jun 29, 2010.
  1. Euroflier
    Euroflier Rookie
    Jun 26, 2010
    10
    SoCal
    My 550 tends to get a little warm under the hood cruising around town on hot days. Someone told me about replacing the standard coolant with Evans racing coolant. Anyone have any experience with Evans Coolant in their Ferrari?
  2. Rifledriver
    37,122
    It will not reduce underhood temps. Those cars get very hot under the hood. It is a byproduct of making horsepower. Do you have a coolant temp problem?
  3. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    38,003
    houston/geneva
    Ross
    napolis runs it in all his cars. maybe he will chime in and comment.
  4. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    #4 BOKE, Jun 29, 2010
  5. Euroflier
    Euroflier Rookie
    Jun 26, 2010
    10
    SoCal
    I do not have an overheat problem and cautious that I do not in the future. Sure, these engines are "shoe-horned" in the engine bay with little ventilation. As long as the car is moving at a good clip, no problem as there is lots of airflow to pull the heat away. But in stop-and-go traffic, the temp gauge climbs quickly getting close to red line. I have heard of other 550's having this issue. So either the radiator is too small for the 5.5L or a higher performance coolant might do the trick. Just wondering if anyone has any experience with Evans Coolant in their Ferrari.
  6. Euroflier
    Euroflier Rookie
    Jun 26, 2010
    10
    SoCal
    Please do chime in. Especially if you have experience with Evans Coolant in your Ferrari.
    Thanx
  7. Rifledriver
    37,122
    Then your car has an issue which can be fixed. 550's do not have marginal cooling systems and are not prone to overheating in any climate or traffic situation. In stop and go traffic if you are seeing over 200 degrees it needs to be fixed. Different coolant is not the answer.
  8. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Hi
    We run Evans in P 4/5. The engineers at Pininfarina wanted to lower operating temperatures and using various methods they did. Evan's was part of that engineering and works very well. You have to keep in mind that Evan's doesn't boil so if your gauge climbs too high you have to shut down and find out why or you will melt your engine.
    P 4/5 runs a lot cooler than an Enzo. We don't use it in any other of our cars as we don't have any cooling issues, for some reason our P 3/4 runs very cool even in traffic.
    I do agree with Brian's post above this one.
  9. Rifledriver
    37,122
    #9 Rifledriver, Jun 30, 2010
    And....while you may not, I do define "climbs quickly getting close to red line" as overheating. "Normal" is 195 or less.
  10. BOKE
    33,965
    Lucky
    I run factory fluids in mt 355GTS F1 and my 456M GTA. I live in Las Vegas and have never had a need to deviate from what the factory specifies.
    I only posted about my experience with Evans in my Ford to let you know Evans is the best place to talk to.
    Napolis is correct about Evans not boiling. If you have an overheating issue that needs to be corrected first. Putting Evans in involves more than a flush and fill as well.
    Good Luck!
  11. Euroflier
    Euroflier Rookie
    Jun 26, 2010
    10
    SoCal
    Thank you for your insight. I will look into it.
  12. Euroflier
    Euroflier Rookie
    Jun 26, 2010
    10
    SoCal
  13. jonp
    jonp Karting
    Jun 24, 2006
    86
    Essex, UK
    Jon
    Sounds same as a prob I have just had fixed. The two small temp sensors, one on each bank under the plenum, measure the coolant temp. I think the right one is a check for the left one (or vice versa), i.e. the left one normally kicks the fans in at say around 85-90c coolant temp, but if the right one reaches 105c then as a failsafe it prompts the ecu to kick the fans in (this is detailed in the 550 workshop manual).
    So fans then kick in just before redline on the gauge, then the fans stay on to take it all the way down to normal 190F (90c), once they they reach cut off point they'll turn off, and then the whole thing repeats.
    If your symptoms sound the same and under normal driving the temp stays below 190 then I would suspect you have faulty temp switch(es).
    The temp switches are cheap, but it's 3hours or so and some new intake gaskets etc to get at them under the intake plenum, and refit plenum. If you do it yourself and disconnect fuel lines when removing plenum, remove the petrol/gas cap first to take the pressure out of the tank and feeds...amongst the usual precautions.
