355 - Evaporator cabin fan unit | FerrariChat
355 Evaporator cabin fan unit
Discussion in '348/355' started by lanab, Jun 25, 2022.
  1. lanab
    lanab Formula Junior
    Feb 21, 2016
    510
    Stockholm, Sweden
    It was pretty hot outside when i drove yesterday and started noticing a nagging squeeking noise from the passenger side, my HVAC panel hasn't been installed yet so i couldn't control the fan speed.
    I stopped the car with the engine running trying to localize the noise, opened the hood, heard if came from the evaporator unit and started diconnecting some cables and found that it stopped when disconnecting the wire to the fan inside the evaporator.
    Might be some bearing on it's way, are these fans replacable and what part no?
  2. Qavion
    Qavion F1 World Champ
    14,272
    Ian Riddell
    Sounds like bad news. Even if you found good (used) parts, you would have to remove the whole evaporator unit.
    I haven't seen any motor part numbers mentioned on the forum. The entire evaporator, if available new, will cost up to U$5000. There's a used fan/motor for sale here, but you may end up with the same problem.
    https://www.ebay.com.au/itm/334432195385?
    I didn't get any useful hits for "borletti climatizzazione". I don't know if anyone has tried lubricating or replacing the bearings.
    lanab and Mike Morrissey like this.
  3. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    Either way if the bearings can be lubricated i need to get the damn thing out and that is a nightmare....don't know if i have any energy or motivation to do this right now, need to empty AC system of gas, empty coolant, alot of things for a damn fan....
  4. Qavion
    14,272
    Ian Riddell
    Indeed... and there is a growing list of owners who are in the same situation.
    lanab likes this.
  5. Brambleworth
    Brambleworth Formula Junior
    388
    NY
    Ted
    I just took mine out because the drum jammed from old foam peeling off. While I was in there I thought I would install a new fan and was told they are not sold separately. I didn’t drain the coolant, just had a few plugs, caps and clamps ready. I placed plastic sheet and a few towels in the trunk and quickly capped the coolant lines, really didn’t loose any liquid. It was also a good time to clean out debris and dust and change the sensors and stepper motors. I also had a stripped gear in the drum motor from the jam. My evaporator box had never been removed before and the worst part was pulling the unit out as the adhesive foam was very hard to separate. I actually reinstalled the evaporator with a one sided foam to make it easier the next time.
    Laserman and Qavion like this.
  6. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Had to remove dash board or anything to take it out ?
  7. Brambleworth
    388
    NY
    Ted
    It actually pulls forward through the trunk. If you take out the firewall trunk liner you will see the heater/AC box.
    Qavion likes this.
  8. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    It seems there is a replacement fan blower you can source on the market, however i don't know the part number from Magneti Marreli.
    I came over a blog post in Japan where a dealer replaced the fan blower but he didn't say where he got it from.
    http://blog.livedoor.jp/prize_east/archives/65923005.html
    Qavion likes this.
  9. Qavion
    14,272
    Ian Riddell
    #9 Qavion, Jun 27, 2022
    I wouldn't get too excited. That blog is 5 years old. I tried to find earlier messages which included the fan, but no luck.
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    is there a part number covered up there by the plastic lip? 9921 does nit seem like a part number.
  11. Qavion
    14,272
    Ian Riddell
    I saw 9723 on the other fan, so probably not a part number. Maybe a date?
    EDIT: DATA means date in Italian.
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Maybe numeric item number like 9723 item built. If anyone finds a part number met me know
  13. Qavion
    14,272
    Ian Riddell
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Looks like this may be the number but its probably Ferrari part number which is useless as they don't sell that part alone. Pretty sure the actual part number is under that plastic lip under "Made in Italy".
    Maybe @Brambleworth has it.
  15. Qavion
    14,272
    Ian Riddell
    I think that Borletti number is on the evaporator unit.
  16. Qavion
    14,272
    Ian Riddell
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    For the fan unit? The fan is a separate part , it seems it would have it own part number as part of a larger assembly. Maybe the fan unit part number is on the blower housing too?
  18. lanab
    Feb 21, 2016
    510
    Stockholm, Sweden
    But if you translate he writes that the fan he found is similar to the genuine fan, so he probably knows the part number....
    Data is just the manufacturing date on the fan, we need to know what it says further down which is blocked by the rubber ring....
    Why does Ferrari make it so hard for the community with older parts, if they can't supply thru their own channel they should release the part numbers, this is stupid policy....not even Porsche does this, if you want a part from a 60s 911 you just contact Porsche Classic and they get it for you.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    can probably order it directly from MM but need that number.
  20. Qavion
    14,272
    Ian Riddell
    Unfortunately, we don't have a lot of Japanese speakers on the forum. @ShineKen seems to know a lot about all things Japanese?
    I sent FChatter Takewa Niwa a PM, to see if it's possible to contact the blogger, but I don't know if he's still around on the forum. He's one of the gentlemen who makes 3D printed HVAC timing actuator cogs.
  21. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    I definitely don't speak Japanese. Just recognize car part words here and there after searching for parts for nearly 2 decades :).
    Qavion likes this.
  22. Qavion
    14,272
    Ian Riddell
    Ah, ok :p
    It seems that anyone can post on this professional Japanese mechanic's blog, so I sent him a message (translated with Google). I hope the message makes sense. From my understanding of Japanese, I can see that Google Translate makes a mess of even the basic stuff. From his latest posts, he seems pretty busy, so I'm not expecting miracles.
  23. Tridentecavallino
    Mar 15, 2013
    93
    Germany
    Thomas
    I have an original F355 replacement fan blower motor im my stock of spare parts.
    This is written on its label:
    MAGNETI MARELLI
    MP 12V DATA 9915
    MADE IN ITALY
    CODE: 050.772.080
    Qavion and lanab like this.
  24. Qavion
    14,272
    Ian Riddell
  25. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Got response back from MAGNETI MARELLI, they say they don't have it in their catalog as a replacement to sell, so what ever motor is used to replace it by others its a compatible one from someone else.
    lanab and Qavion like this.
