Evaporator Housing Leak (1995 456 GT U.S. Spec) | FerrariChat
Discussion in '456/550/575' started by Davidspop, Aug 23, 2020.
  1. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    401
    Lance Malcolm
    Good afternoon everyone. You may have seen a few of my recent posts.... I am tracking down a condensation water leak on my 456. It is coming from the passenger side....but in the area below the Expansion Valve, and below the "Anti-White Frost Feeler". I have looked at the diagrams available and it looks like that is a cover on the right side and I am thinking there must be a rubber gasket under what appears to be some kind of cover?
    Anyone have any experience with this? I drips quite profusely feels like it's coming from around that area... I really don't want to pull the evaporator out... but I guess I may have to?
  2. mic125
    mic125 Rookie
    Jun 15, 2011
    6
    South Australia
    Michael Talladira
    I have a similar car (Aus Spec RHD) which leaked water in the footwell and got to the stage it sprayed out of the AC vents. We found that it was simply a blocked condensate discharge pipe. The solution was to 'lightly' blow compressed air into that drainage pipe from underneath the car. Car hoist was handy.
    Sent from my SM-G970F using Tapatalk
  3. Davidspop
    Dec 23, 2019
    401
    Lance Malcolm
    Alas... I only wish it were such an easy solution.... I pulled both drain lines and cleared all..... condensate flows easily out the drains.... for some reason, I am getting this condensate escaping on the passenger side of the evaporator housing...... thank you for the suggestion though!!
