Ever think about dropping a 360 V-8 into a 348? | FerrariChat
Discussion in '348/355' started by 348SStb, Aug 2, 2004.
  1. 348SStb
    348SStb F1 Rookie
    Don't beat me over the head with all the potential difficulties and inconveniences of doing this... I can imagine what they are.
    What I want to know is, has anyone ever contemplated this? How awesome it would be! Does anyone know anyone who dropped a 360 V-8 into another Ferrari?
  2. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    Ferrari already did something simmilar, they called it a 355.
  3. ferraristiforlife
    Jul 27, 2004
    27
    Miami
    Michael
    for that money you would have to spend ( + trade in your 348 ),just buy an used 360 and as side effect you also get the better car.
  4. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    Totally cost prohibitive.
  5. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    What about mounting a Pontiac Fiero engine in the 348. Would it fit? Or would the 348 engine fit inside the Fiero if you wanted to do that? In fact, how about a cummins diesel in the 348? Any thoughts?
  6. 348SStb
    348SStb F1 Rookie
    very funny
  7. Steve Magnusson
    26,776
    Did you see the thread about BLACKHORSE putting a 355 powerplant in a 308QV (IIRC) chassis?
  8. 348SStb
    348SStb F1 Rookie
    No, I didn't... sounds interesting though
  9. Steve Magnusson
    26,776
  10. Dr.Bleed
    Dr.Bleed Karting
    Jun 5, 2004
    139
    Indianapolis
    Nathan E. K.
    Hey, my Dakota R/T has a 360 V8. :D
    (j/k I know what you mean :) )
  11. 348SStb
    348SStb F1 Rookie
    Well I don't think a flat 12 would fit in a 308 or a 348...
    But I think the 360 engine--an absolutely marvelous engine--would fit in just about any V-8 Ferrari.
  12. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,958
    MO
    Omar
    We have a member on this site with a flat 12 in their 308.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    You could build the 348 engine to produce about the same power for much less work and money I would think.
    I'm sure you could make way more power than the 360 engine will give you by adding a supercharger or turbo to you 348 engine. My supercharged QV engine is delivering about 520 hp, Jeff (turbo348) is making about the same from his turbo 348. IMO you get way more bang for the buck by adding boost.
  14. 348SStb
    348SStb F1 Rookie
    Have you had any reliability issues with your turbo'ed Ferrari engine? Any "Check Engine" or "Slow Down" light issues?
  15. vincent355
    vincent355 F1 Veteran
    6,513
    Wine Country
    Vincent
    There are a couple of guys on the site with Twin turboed 348's, very fast machines. They seem to have pretty good reliability. I think Mark has a problem keeping the tires hooked up all the way to third. that is one bad QV!
  16. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Er v12, from a 330 I believe. Flat 12 would be impossible, with the car still resembling a 308 atleast ;)
    Pete
  17. Auraraptor
    Sep 25, 2002
    13,958
    MO
    Omar
    My bad, thanks for the correction.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    Mine's supercharged, but no real reliability issues...I fried the clutch early on and had to upgrade it, but I like the new clutch much better han the old one anyway, it has a much lighter pedal (it's a tilton 7.25" triple disc carbon-carbon).... and rear tires don't live near as long as they used to :)
    I'm using an aftermarket ECU, so no check engine light. This is my second supercharger, the cat was on the car with the first and it seemed fine. With the new blower setup, I removed the cat and installed a borla exhaust because I wanted more flow, so I don't know what would have happened if I left it on.
    I think Jeff's 348 is really quite similar to my car but a few small differences. He's at 15 psi, I'm at about 18. I run a haltech ECU, his is Motech. I went with the multi-disc carbon-carbon, he has a single disc kevlar clutch. I think he still has his emissions stuff....I know there is a guy, Paul (turboQV) with about a 4550 hp QV that had to pass CA emissions...if I recall it has a hyperflow cat and a GM electric air pump. Norwood build both of the turbo cars, they can give you much better info about them than I can.
  19. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Wow! ... how urgan legends start I guess :D :D :D
    Pete
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    yeah, i heard about that 4550 hp car too....:)
