Here is something I wrote for another forum that I pasted here if anyone is interested. By Gary Contributing Editor, PT Cruiser Links .com Did you know that in Henry's Ford day automotive varnishes were applied by brush? Back then cars were available is three colors: black, black, and black. It wasn't until the mid 1930's that dozens of new coatings were first introduced. Enamels were the new alkyd resin that made the most dramatic impact in the auto industry. In the early 1940's the first atomizing spray gun was perfected. Early spray coatings required multiple coats, and extensive sanding in-between. In the 1950's General Motors started working with a new paint process that used an acrylic resin that could be heated after initial application to rapidly evaporate the solvents and smooth the paint to a uniform finish. There is no denying it, Americans like shiny cars, and the number one buying instinct comes from our eyes. So in 1960 Ford realized this important point and went to work trying to create higher gloss, but failed in the durability and color department. The 1970's brought another change, the introduction of the two coat acrylic painting system, and by this time companies that supplied raw materials for automotive paint had grown by the hundreds. An array of innovative products allowed each manufacturer to pick the best products for each job. In the late 1980' and early 1990's the government got involved and was concerned about paint content and how it affected the planet. New laws governed the amount of toxic emissions like petroleum solvent and other volatile organic compounds. To meet the challenge the paint industry developed the urethanes and polyurethanes we know of today. Unexpectedly early versions of these paint systems were damaged by common chemicals like waxes and polishes containing petroleum distillates. The industry worked feverishly to correct the problem. Today's paint systems, mostly multi-stage clear coat systems are better than ever before, and are offered in a wide range of colors, with depth and clarity we never had before. The improvements in clear coat technology have started a distressing trend at new car dealerships. Many new car salesmen are telling their clients that the paint on their new car is maintenance free. Nothing could be further from the truth. The clear coat is NOT impervious to environmental conditions. On the other side car dealers who preach about a paint sealant lasting for years is also misleading consumers. Regular Washing Is Critical This is the most important step in keeping a healthy looking finish. Choose a quality car wash shampoo, not a product designed to clean your dishes. Using dish soap will strip any protection you have on your finish. Use the lubrication from the soap to protect against from causing swirls and scratch marks. Your wash tools are important, sheepskin or chenille mitts work great. Stay away from sea sponges and wash rags; they will harm your finish quickly. You want minimal friction to avoid damage when working. Wash the wheels first, change buckets often and never spray chemicals on hot rotors or brakes. Use an all wheel cleaner which is similar to all purpose, let it soak in a while, scrub and rinse. For brake dust, use a detail brush to loosen it up with the cleaner. Always start form the top and work down, use a final rinse of free flowing water, this will allow the water to run off the car and reduces drying time. I use an electric leaf blower, water blade and waffle weave micro fiber towels for final drying. Use the Plastic Bag Test When you are finished washing your car, get a plastic sandwich bag, put your hand in it, and gently touch and move your hand across the finish. The plastic will enhance your sense of touch 10 times or more, so you can feel every imperfection on the finish. Do you feel the bumps and rough spots? Changes are you will. That means it is time for the clay bar. Clay is the detailers answer to removal of micro particles on the surface. Every surface contaminant on your cars begins a bonding process, which over time if not removed will etch into the clear coat. Most people forget about clay and jump right into the polishing cleaning stage. Take a look at your pad after a few passes and see how it looks. It is black and dirty from all the pollution you did not remove. Clay will NOT remove any paint, like abrasive polishers and cleaners. For instructions on clay application, go to www.perfectautofinish.com and see "detailing tips". Paint Cleaners for Final Application Once you remove surface contaminants with the clay, next step should be quality paint cleaner. Some paint cleaners have polish in it which will add depth and luster back into the finish. While clay removes surface contaminants, cleaners and compounds remove defects IN the finish. Minor surface blemishes and scratches are ideal for paint cleaners. Always work in small section, and remove as you work. Don't allow them to dry, they are hard to remove. A pure polish may or may not be necessary after this step. To test try a section with a pure polish, if you see a difference proceed. If not, don't waste your time. Paint Sealants Outlast Wax Six Times Longer All the experts agree that a synthetic polymer sealant offers the best sacrificial barrier on your finish. Paint technology is constantly changing, so why use products that are as old as the Model T? Wax has been around for 100 years, our finishes have evolved to a higher quality standard, so why not use that same technology to protect your car? Old habits are hard to change. I recommend using a sealant twice a year, along with a fresh up (like a poly spray) in between sealant treatments. Micro Fiber or Bust If I get one point across in my detailing clinics that I hold in the Chicago area, it is to try a micro fiber towel. 99.99 percent of the people that try one for the first time come back wanting more. Most of them are amazed how well they work and wonder how they never tried them before. For anyone that is interested, I will mail you a tech data sheet on them. But the proof is in trying them. Every square inch of the micro fiber has 90,000 small fibers, each one hundred times thinner than a strand of hair. Plus, each fiber can absorb seven times its own weight, making it the ideal towel for glass, polish, wax, sealant and quick detail. Try it you'll like it!! Visit Gary's website at www.perfectautofinish.com for more. ^ back to top HOME | LINKS | FORUMS | FEATURES | NEWS | CONTACT Copyright PTCruiserLinks
Gary,I have a Paint question. On my 1981 308,with only 19K miles. I have a little bit of "Checking" going on with the paint in a few spots. It's a very fragile,brittle Lacquer,that is now 23 years old. Is there any way to repair that? Wet sanding? Other than those few spots,the paint is excellent. I really don't want to repaint the whole car.(monetarilly is not the issue....keeping it "original" is.) But,I'd rather have it looking as perfect as possible,regardless of potential future value of the car if I repaint the whole thing with a Modern paint. Most everyone I talk to says "keep it original"...it's only "original" once. I agree. But,I want it as perfect as I can get it...and that checking has got to go...suggestions? Thanks!!!
Frank- A 'survivor' is something to be admired, as long as it's still in good condition. Think of antique furniture; a piece in good condition, that has never been refinished, is worth much more to a collector, or a museum, than a restored item. How about Chris LaPorte's 410 SuperAmerica; I'm sure it's worth more as an untouched original, than it would be if it were a total restoration. As you know, it's in fantastic condition for it's age, even with the crazed paint. Leave you car as is; it's imperfections show it's character. If 308s ever become collectable, your car is one a collector would want! Oh, and to answer your question about the 'checked' paint, from my experience, and by what I've been told by professionals, the only way to fix it is by repainting.
Red8, I would be glad to tAke a look at it, my shop is in Roselle. send me an e mail through my web site. www.perfectautofinish.com Gary
Thanks alot Skip and Gary. Yes,I've been in the Furniture business before,for about 10 years-Making,Buillding,Refinishing,Selling,Repairing...Delivering.And,I am aware that a nice,original untouched piece is always worth more,despite the urge to Refinish it. I've seen some crazy stuff at Auctions. Same for Classic Cars,I suppose. But,I wonder if there is any way to just Buff out the couple of Checked spots,without having to repaint. If not,I agree with you,Skip. Character...like the lines on my Grampa's face...(and believe me,he's a real character!!!) Better to just leave it as is. And,keep it so darn shiny,that it's not noticable.
Right Frank, and I think you're the only one that knows the cracks are there; I've never noticed them. If paint is cracked or crazed, it's not like a surface scratch (which can be buffed out if it's not too deep). A crack goes through the entire paint surface, not just a few millimicrons of the top layer.Therefore, cracking and crazing can't be buffed out. I guess, if you can detect that aftermarket paint work has been done on your car before, it won't hurt to do paint work now.
