Excellent Mechanic for Carbureted 308? | FerrariChat
Discussion in 'Chicago' started by cray54, May 22, 2010.
  1. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    I'm looking for an experienced and recommended shop for a 308 w/ carbs in the Chicagoland area. Any suggestions?
    Thanks,
    Chris
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    You might want to talk to Ed at 847.934.6111.
    Those Webers are pesky critters!
  3. RanchHand420
    RanchHand420 Rookie
    Mar 21, 2007
    37
    Naperville
    DT
    try Continental Auto Sports. You can't go wrong with factory trained techs.
    Call the service dept today. 630-655-3535
  4. sagekilz
    sagekilz Karting
    Aug 21, 2008
    96
    Bensenville, IL
    Jeremy Sus
    Dale Schieder at Continental Auto Sports has serviced every year 308 since they were brand new.
    630.655.3535 ask for service.
  5. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    I did end up taking my Dino to Continental Auto Sports. I was generally dissatisfied with the service provided and would not recommend this location to other 308 owners.
    The work included upholstery, electronics, ignition, carburetors and timing belts. The cost projections were quite poor (the actual cost to do the work planned was 3 times the cost estimate). After completion of the initial work I was told the car was repaired. I planned a trip to Chicago (I live out of town) to pick up the car with Continental’s knowledge. Upon arrival I found the paperwork was not in order and had to put several hours into work they should have done to allow me to pick up the car while in Chicago. The car was clearly running very poorly and I returned it for further checking (and I returned to Massachusetts). They reviewed the “repaired” car and found the actual remaining cause. There was an associated increase in cost, but the subsequent repair work completed was not on the initial estimate (so I understand such an increase in cost). In the end, the car was effectively repaired and it appears to be properly functioning but at great cost, time and stress.
    Con:
    *Very poor time and cost estimate
    *Seeming inability to locate problems
    *Inability to meet time schedules
    *Much work required by me to ensure quality
    Pro:
    *Gary in service was very helpful throughout process
    *Final result was satisfactory
    Ultimately, my car was repaired and for that I am thankful. I will not take my car there in the future.
    Thanks,
    Chris
  6. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Ed's in Palatine IL. Ed is 'old school' and very knowledgeable when it comes to synching multiple carbs.
  7. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,612
    @ the wheel
    Andreas
    +1
  8. drgek
    drgek Formula 3
    Jun 21, 2004
    1,142
    Gary
    I'm sorry you had those difficulties, but I've had six different Ferraris serviced at Continental over the past 15 years and have always had superior experiences. The belt service for my '01 550 was completed for significantly less than the estimate given DESPITE my adding a 4 wheel alignment not included in the original quote.
  9. cray54
    cray54 Karting
    Nov 4, 2005
    184
    Ashfield, MA
    Christopher Gray
    #9 cray54, Jun 13, 2011
    I expect my experience was not representative of their entire operation (otherwise, they would not come highly recommended). There were many stages to my interaction with them, and their performance with every stage following the the start of major work was consistent with my desire to avoid their location in the future. I get the sensation that the significantly lower priced models are not treated with quite the same service as newer vehicles.
    -Chris
