Exhaust Backpressure the myth | Page 2 | FerrariChat
Discussion in '360/430' started by raywong, Apr 7, 2010.
  1. Argento6spd360modena
    Argento6spd360modena Formula Junior
    Nov 20, 2009
    309
    I have to agree. I have done the test with valve off and on at least 3 times (It takes me less than 1 minute to enable/disable valves on stock exhaust).
    The car feels more responsive with valves open and sounds a lot better.
  2. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Still 4 valves per cylinder and twin overhead camshafts, plus I would like somebody to explain why this older car was able to use backpressure so effectively.
    Pete
  3. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Back pressure is not good for engine performance at any rpm! the piston try so hard to push the exhaust gases out, why would you want to put extra pressure on it? The speed of the gas flow and air wave are what it really needs.
    A bigger and less restrictive tube might benefit higher rpm exhaust flow, but at low rpm it will allow the gases and the waves to expend, cool down and slow down too much, waves messed up, momentum lost, engine works harder to push the exhaust gases out. In this situation, the valve can restore some restriction, speeding up the gases and the waves. these waves carrying a lot of momentum actually helps to suck out the exhaust gas from the engine, improving power.
  4. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    did you read the article? basically lack of computerized timing and injection.
