Exhaust Bypass Solenoid | FerrariChat
Discussion in '348/355' started by mwhitesell, Oct 27, 2006.
  1. mwhitesell
    mwhitesell Formula 3
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    Is there a way to test the exhaust bypass solenoid when they are off the car? My CEL came on with p1448 which is usually caused by the bypass solenoid. So I ordered a new one since they were cheap, but I want to make sure that is the problem. I'm not sure if I put current on this solenoid what I would see. I have a new bypass valve already so I know it is not that.
    Before I even put the new one on, I went through and cleaned both of them and checked all the hoses and put them back. I reset the CEL and it has not come back on even after some spirited driving.
    I may end up with a spare, but if anyone has a way to test these I would appreciate it.
    This is solenoid 159177, there are two behind the right rear wheel. (one for air pump, one for exhaust bypass.
    Thanks,
    Mark
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Great description of the "issue" :)!
    Yes, they are very easy to test. One just needs a 12v source. You can use a battery charger to put current to the soleniod. Polarity is not important because you only need to excite the coil inside.
    After you put 12v to it, you should feel/hear it click. You can also blow into the bottom barb (the end one) and notice that air will flow through when you have current to it. When you take the current off it sould not flow. The other barb will flow air slightly all the time. That allows the valve to close when the vacuum source is shut by the solenoid.
    Hope this helps :)
  3. brendon0
    brendon0 Formula Junior
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Just as a side note, blowing anything that has a 12v battery attached
    to it, bad idea.
    How about using an air compressor and just shooting some air thru it?
  4. mwhitesell
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    I just told my wife that she had to fix it, and it involved geting it excited and blowing. LOL
  5. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    If you want to get her really going, you may want to use more
    then 12 volts.
  6. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    The rubber hose has plenty of electrical insulation to prevent any shock.
