Exhaust bypass valve question | FerrariChat
Discussion in '348/355' started by Ferraripilot, Feb 9, 2015.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,879
    Atlanta
    John!
    Car is a 95. Is there any switch that can permanently open the valve? Or at least offer some way to make certain it's working? I'm not entirely familiar with these cars yet and I really can't tell if this valve is operable. Thanks in advance
  2. WATSON
    23,832
    WI
    I tested mine with a power bleeder. You know, the units you can use to pull brake fluid & clutch fluid through your system without pumping the pedal.
    I just hooked the suction end up to the bypass valve and pulled the trigger. The vacuum was applied and the valve went open.
  3. Ferraripilot
    May 10, 2006
    17,879
    Atlanta
    John!
    Gotcha. Thank you
  4. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
  5. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Not very scientific I know, but mine (and a used replacement bought as a spare) open quite a bit by just sucking on a length of tube connected to the valve - i.e. not a lot of vacuum is required to tell if it's working to some extent. This can be done in situ.
  6. eyboro
    eyboro Formula Junior
    989
    Chicago
    Eitan
    I had mine tested by having my son rev the engine to around 5000 RPM and looking at the bypass valve opening by seeing the stem of the valve moving up and down
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,905
    Richmond
    Pete
    You should be able to just manually move the pushrod by hand and could wire it open if you want to.
