Exhaust ecu location | FerrariChat
Discussion in '348/355' started by margarita, Jan 17, 2021.
  1. margarita
    margarita Formula 3
    Mar 20, 2011
    1,617
    usa
    Hello guys does anyone have a picture of were the exhaust ecu are located in a 1999 ferrari 355 thank you
  2. Qavion
    Qavion F1 World Champ
    11,534
    Ian Riddell
    Is it not in the usual place on a panel behind the right hand wheel arch on a 1999 model?
    Just follow the shielded wire from the thermocouple. It may be mounted on the front or rear of the panel. Perhaps slightly above the two vacuum solenoids.
  3. Qavion
    11,534
    Ian Riddell
    Actually, this diagram shows the bypass thermocouple ECU next to the vacuum solenoids, not above them
    Anyway, follow the braided line to/from the bypass valve thermocouple in case someone has swapped over the braided line or electrical cable to the ECU. If you can see the wire colours on the electrical plug, the bypass thermocouple ECU should have a purple-black wire, not a plain purple wire. The other two wires are green and black (same on both)
  4. margarita
    margarita Formula 3
    Mar 20, 2011
    1,617
    usa
    Thank you very much guys
