Exhaust noise | FerrariChat
Exhaust noise
Discussion in 'Technical Q&A' started by scorpion, May 8, 2006.
  1. scorpion
    scorpion Formula Junior
    Jan 19, 2004
    469
    Kentucky
    A while back my 308 came down with a strange noise when first started. Using my trusty stethoscope I eliminated, tensioners, water pump, alternator, valves, etc and have tracked it down to the front exhaust header. It's a metalic rattle that as soon as the car is warmed up disappears. At first I thought it might be a baffle in the muffler (ANSA euro model) but it is way upstream from the muffler. Any ideas????
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Just isn't much in the Euro headers that can rattle. Where on the header? Up near the head, or down near the collector?
    A swag, could one of the bolts that seal the test holes be loose enough to rattle, then it expands enough to stop when things heat up?
    Or, if near the collector, it could be that the collector, or one of the pipes feeding into it has cracked loose. Had to re-weld a crack in mine, but it wasn't rattling.
  3. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    I had a rattle on my 308 US model. It was the rear manifold U-pipe that connected to the cats. The heat shield would rattle at start up. Once warm pesumably expanded and rattle would go away.
  4. scorpion
    Jan 19, 2004
    469
    Kentucky
    Thanks for the help.
    The noise appears to be closer to the head, although it's hard to tell exactly where. I don't have cats and have checked the heat shields. Thanks
  5. pernicev
    pernicev Karting
    Jun 22, 2005
    134
    I've had this problem with a past 308. As the insulation deteriorates between the header and the aluminum heat shield that wraps around the header, the heat shield gets loose and rattles. The low tech solution is to squeeze the shield so it tightens up around the header.
