Exhaust Note Question . . . | FerrariChat
Discussion in 'Technical Q&A' started by Revenge_of_KARR, Nov 25, 2004.
  1. Revenge_of_KARR
    Nov 18, 2004
    6
    Brooklyn , OHIO
    Sir Craig R Lembke
    Hello everyone !
    I am rather new to this Ferrari / Lamborghini forum.
    I am a huge fan of Italian exotics, sadly though, I doubt that I'll ever afford a genuine production model . . . on a Correction Officer's income.
    I envy the sound of the Italian Exotic's exhaust note, and always will.
    My question is the following : Is there any modification of the exhaust on an American 305 Cubic Inch / 5.0 Litre V8 , that will duplicate the sweet sound of your Italian Engines / Exhaust ?
    I currently have headers and a Flowmaster exhaust system installed.
    But, the sound is more of a low range octave rumble, ( the typical American V8 sound ) that exhibits the American Musclecar Power.
    I love the sound of the Countach's Exhaust.
    The sound of a higher pitched raw power, attention grabbing note.
    Please don't tell me to get another (Italian V8 / V12) motor.
    Thanks,
    Sir Craig R. Lembke
  2. axemansean
    axemansean Formula Junior
    Jul 11, 2004
    801
    You can pick up a late 80s or early 90s Testarossa, 348 GTS, 328 GTS or such like for under $50k with under 50k miles on the odometer. Ferraris are affordable with a little bit of smart saving. :)
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Craig, welcome to the forum.
    All of the following are my observations only:
    Ferrari exhaust notes generally fall into two different catagories - the smooth lower tones associated with the vintage V-12s and the higher pitched Formula one shrieks like the modern V-8s and racing engines.
    The main noise generating characteristics that differ between your American V-8 and the Ferrari V-8 is the crankshaft, operating rpm and displacement. The American V-8 is typically a 90 degree throw that gives the classic American V-8 burble and rather rougher sound at speed. The Ferrari has a racing 180 degree, or 'flat' crankshaft like V-8 formula one engines (e.g. Cosworth, etc...) that make it like two 4 cylinder engines on each side (and yes, they can run smoothly and independantly of each other (ask us how we know) giving a bit smoother sound throughout the range. The classic wail of high reving smaller displacement motor is a higher frequency sound as compared to the relatively slower turning larger displacement American torque monster. The popular 'Tubistyle' muffler and the like used on modern Ferraris accentuates the high rpm scream being a smallish 'acoustic box' type muffler with no resonators.
    That all being said, I've heard a Dynomax large body large bore super turbo muffler on a 305 F-body like yours that really smoothed out the pulses well with almost (not quite though) a V-12 quality. Also, tip resonators also make a big difference in smoothing out the rougher sound characteristics. A set of quad 10" Ansa resonators on the back of the flowmasters would smooth it out significantly.
    To get the really higher wail like the smaller higher reving motors is may take some extension of your rpm range above 6000 - 7000 rpm to get the high frequencies. The general rule of the larger the muffler, the lower the tone may also apply here if you use it in reverse. If you have the larger flowmasters, may look at a smaller flow through muffler (as opposed to the chevroned flowmasters) with some tip resonators to smooth it out. Just guessing a bit here, but flowmasters are pretty well known for that lower rougher tone.
    Again, in the end, what you are trying to duplicate is not an engineering characteristic of your engine, but you can do some things to approximate the sound.
    Anyway, I could also be full of poop - this is just my experience from having tried and made several different systems on my Ferrari.
    Hope you enjoy the board - there are some really smart people here that may chime in with a better answer.
    best
    rt
  4. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,411
    E ' ' '/ F
    Enzo Gorlomi
    One suggestion would be fitting a set of 180 degree headers to your engine. They're impractical and tough to fit on a street car, but do dramatically change the sound of the standard V8s.
  5. jmillard308
    jmillard308 F1 Veteran
    May 29, 2003
    6,687
    Perth West Oz
    John Millard
    A balance pipe between the two pipes helps as well
  6. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    The cost to buy the car isn't the issue; the cost to maintain it properly is what's expensive.
    Don't want to, or can't afford to spend the money to maintain an F-car......that's fine.....someday the car will become a lawn ornament, in front of your single wide.
    Many of you give false meaning to the term 'affordable', leading many 'dreamers' into a money pit they can't afford.
    Let's get real, and start talking about the real cost of ownership!
  7. axemansean
    Jul 11, 2004
    801
    Good point, I should have included that in my post. My sincere apologizes.
  8. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    You are forgiven, my son. :)
  9. DGS
    DGS Seven Time F1 World Champ
    73,023
    MidTN
    DGS
    A newer computerized 550 is expensive to maintain ... by paying an authorized dealer with the proper computer diagnostic tools to do for you.
    A 70's era Ferrari can be home maintained by anyone with a bit of time, patience, mechanical aptitude, and a well stocked tool box ... and access to the FerrariChat tech forum. ;) (Of course, that tool box needs to be in metric.) The '80s cars get a smidge more complicated, with computerized ignition and CIS injection, but are still within the grasp of a well equipped home shop.
    I wish I had the time to do more of my own maintenance. Ferraris are not only pretty on the outside, but the classic cars are elegant engineering, too. Besides: the professional Ferrari wrenches know Webbers, the OBD-II handles the newer stuff, but you need a VW mechanic to cope with CIS. ;)
  10. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Exactly, but not everyone falls into that category.
    But if they do, parts are still expensive.
  11. Revenge_of_KARR
    Nov 18, 2004
    6
    Brooklyn , OHIO
    Sir Craig R Lembke
    I truly hope that you weren't referring that I was the one who owned a single-wide... as in a trailer park home?
    Just because I can't afford an Italian exotic... Because I already have one Italian Exotic in my life, my Beautiful Wife !!!
    My Trans Am will without a doubt outlast your Lams/Ferr for years to come.
    But I'm not here to sling mud as to who builds a better car.
    I love both cars the same, I just am asking the best way to duplicate the same exhaust note on my AMERICAN ENGINE.
    Respectfully Submitted,
    Sir Craig R. Lembke
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Craig,
    Relax, no need to be defensive, it's just the internet.
    The exhaust note will also depend if your car has a complete dual system or the two into one with a single inlet muffler. If dual, does it have an H-pipe (balance or X- pipe)? Although somewhat dramatic to fit, Tillman's suggestion of tuned 180 degree header would go a long way to give the impulse pattern and sound you may be looking for. If that's not a player, an X-pipe (like a balance pipe) close to the header outlet is next best. Will pick up some hp as well if you do not already have one. Want to achieve as even a pulse spacing as possible. Most good racing shops are pretty well versed in this (more than me, anyway), and if there is one close by, that would be a great option.
    Hope this helps
    best
    rt
  13. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    In no way was I referring to you, or anyone else in particular.
    It was just an attempt at a little humour, and I'm sincerely sorry that you took it the wrong way.
    You have my apologies.
  14. T.O. Dino
    T.O. Dino Formula Junior
    Oct 30, 2004
    350
    Toronto Canada
    Acually I really don't think your Trans- Am will outlast any ferrari. Slim next to none of finding a ferrari in a scap yard because of neglect. maybe because of an accident. Trans- Ams , well they are scapped everyday just from peaple trying to collect money from the metal in the car.
  15. DGS
    73,023
    MidTN
    DGS
    Not if you're depending on the dealer for service. ;) And if you can keep a Trans Am running, you can do much of the maintenance on an Italian machine. (Are Trans Ams metric yet?)
    American muscle has a sound of its own. Why make it something it's not?
    The priority of aftermarket exhausts should be performance -- at least, in a certain power band. Large exhausts, while reducing flow restrictions at higher rpm, tend to reduce exhaust velocity at lower rpm, and can lead to pressure pulses at idle, producing a rough sounding idle. This is often a source of a muscle car's unique idle sound. A smaller exhaust manifold would improve idle flow velocity, but would limit power at the top end.
    On the 360, I believe, Ferrari went with a variable exhaust to try to find a happy medium.
    There's more to exhaust "tuning" than picking a song on the jukebox.
    Besides, no exhaust note from your TA will frighten a Hemi Cuda. :D (ducking)
  16. T.O. Dino
    Oct 30, 2004
    350
    Toronto Canada
    Sorry Craig, I wasen't referring to your car in particular but just mass produced cars.
  17. Revenge_of_KARR
    Nov 18, 2004
    6
    Brooklyn , OHIO
    Sir Craig R Lembke
    I suppose I may have over-reacted in my response... I dearly apologize if my post offended any readers of this fine forum.
    I WOULD someday love to have aN Italian Exotic Automobile, but at this time my Trans Am will just have to be my Muscle Car !!!
    I love it to death, love the visual styling and the mystique of the Italian Motoring Models.
    Maybe the reason that your automobile will be around longer is . . . you don't drive them in the snow, ice and SALT.
    You pamper your cars, RIGHT? LOL.
    Admit it...
    I would love to have a ride in a Ferrari or Lamborghini (Countach preferred).
    If there's anyone in the Ohio, Pennsylvania, Indiana, Michigan area that would like to fullfill the previous... let me know.
    I would be happy for years.
    Once again sorry I flamed...I hope I am still welcome to be part of this forum.
    Sir Craig R. Lembke
  18. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    I'd be happy to give you a ride, and probably let you drive.
    But I'm in Illinois and winter is setting in, so it would probably be months off.
  19. Revenge_of_KARR
    Nov 18, 2004
    6
    Brooklyn , OHIO
    Sir Craig R Lembke
  20. Revenge_of_KARR
    Nov 18, 2004
    6
    Brooklyn , OHIO
    Sir Craig R Lembke
    Let's do it in the Spring 2005 !!!
    Good???
