Exhaust questions for 348 | Page 2 | FerrariChat
Discussion in '348/355' started by Dmatz, Jun 17, 2014.
  1. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    That system has separate units for left and right. I think you are missing something by not having them join up. Most use an X pipe system balancing pulses and flow of the sides. Just an observation.
  2. Moiluck
    Moiluck Formula Junior
    Mar 20, 2009
    326
    Spain
    Moisés
    Thanks for your observation Vince, however there is nothing missing in this system. It works perfectly as it is, just because both cylinder banks are properly balanced. I know that most use X pipes, but this system is a different thing and it works. There are no problems when both banks are working fine and balanced, and if F1 engines don't use X pipes, why my 348 should?
  3. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    I have read that flat plane crank engines do not require an x pipe or balance tube. I'm not an engineer , just something i have read in the past
  4. TheAmishSasquatch
    Jul 6, 2014
    52
    Samir Goncalves likes this.
  5. Evan.Fiorentino
    Evan.Fiorentino F1 Rookie
    Aug 23, 2005
    2,854
    South East Florida
    Evan
    We did see the best HP with the "X" type design when combined with high flow cats.
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I ran a true dual (seperate) exhaust on my 308 for 15 years, never one issue. Many other 308 owners have done this as well. I've seen it done on 348's too and wouldn't hesitate to do it either on my 348. True dual is pretty loud and the "X" setup does offer some additiaonl noise cancellation.
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    There is no question that performance exhaust tuning/design is a combination of art and science that requires experience and knowledge.
  8. Moiluck
    Mar 20, 2009
    326
    Spain
    Moisés
    A very good point, Meister. I am happy to know that I'm not the only F-Chatter who uses or have been using a true dual exhaust in a Ferreri (road legal) with a good report of it.
    Thank you very much for your comment. Kind regards.
  9. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Nice setup Moiluck!
    Is the wrap from cat-back? Stock headers without a wrap? Wondering how much heat is reduced in the engine bay.
  10. Moiluck
    Mar 20, 2009
    326
    Spain
    Moisés
    Thank you Randy, I'm glad you like it.
    The exhaust is wrapped cat-back (cats included). The headers are not wrapped, however they have an insulating material under the covers that keeps the heat in the pipes. I can feel the engine bay cooler, but can't tell numbers because I have not measured it.
    The other benefit of the exhaust wrap is that keeping the heat in the pipes makes it flow faster.
