Exhaust rattle! | Page 2 | FerrariChat
Exhaust rattle!
Discussion in '308/328' started by tinterow, Mar 13, 2017.
  1. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Ron, that's a very nice offer and beautiful exhaust. I will definitely keep it in mind. Robert, I like the way you think! You must have been there done that...Justin, another good idea!
  2. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Just another data point. I have a '77 GTB without cats and no insulation on the headers for over 30 years. No heat issues.
  3. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Thanks, Andy!
  4. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,085
    FRANCE
    I might be beating a dead horse here, but nevertheless...
    Please keep in mind that exhausts of the two-valve cars cannot be fitted on the four-valve cars and vice-versa...
    Exhaust tubes (those that go on the engine exhaust ports) of the two valve cars are rounded; exhaust tubes of the four valve cars are oval.
    Those of the QVs and 328s are interchangeable.
    Rgds
  5. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,298
    Black Forest Germany
    Martin N.
    Sorry!
    I thought that's common US-american wildlife :)
    Best Regards from Germany (where we have vipers too, but rarely seen)
  6. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,614
    California SF bay area
    Paul
    I'm no expert here but given the nature and function of the air injection system it is quite possible that the main purpose of the shrouds is to INCREASE the internal temperature of the headers to aid in the effeciency of the Cat(s) - especially immediately following cold starts when air is being injected into the headers.
    In other words, they may not be there to prevent engine fires.
    I know of at least one owner who has removed them and ceramic coated his headers with no apparent problems.
  7. 308 milano
    308 milano F1 Veteran
    5,351
    Montana
    Kim
    The whole point of my post was to say .. if you happen to drop one ignition bank on a US spec car it takes very little time for those headers to glow orange. Would rather have a sheet of aluminum between it and the rest of the components than nothing at all. My car is a euro spec. so not an issue for me anyway (no cats) just sayin.
  8. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    The reason the exhaust is wrapped on emission equipped cars is to keep the heat inside and lite off the catalytic conver as fast as possible. This reduces emissions.
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Has anyone tried to Jet Hot coat their headers/exhaust? Supposed to reduce heat tremendously from the outside.
  10. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    Mike, that was my plan, until I ran across a local Chicago company displaying at World of Wheels (Autorama), called LoKo Coatings. They charge $300 for a set of headers ($350 for chrome finish), and use the EXACT same industrial process as JetHot, for about half the price. Wound up having them powedercoat or ceramic coat 28 parts during my restoration project. Highly recommended. There are some who say Zircotec uses a different process, but who knows.
  11. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    So Ron, are your ports round or oval?
  12. Rifledriver
    37,288
    Correct. They did also lower engine bay temps but that was just coincidental.
  13. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Oval ports. I think the 4 valvle engines are oval and 2 valve are round.
  14. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I have, but mine is a turbo. I do think it reduces heat.
  15. absostone
    absostone F1 World Champ
    10,215
    I used the same thx to Justin
  16. absostone
    10,215
    Haha
  17. detroiter
    detroiter Karting
    Apr 30, 2013
    205
    Munich, Bayern
    Carter
    Perfect timing for this topic to come up... just spent an hour under my car trying to figure out what to do with my rattling heat shield.
    I also got cold feet cutting it off due to the heat issues on the surrounding electrical parts and maybe even cabin heat.
    Now I'm thinking the recommendations on here to coat the headers is probably the best bet.
  18. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    I, too, was a bit worried about radiant heat w/o shields, so I bought several lengths of 1800 degree heat shield hose wrap from Jegs and wrapped the 12v-starter and alternator wire bundle, then also put a velcro heat shield wrap around the starter (I actually purchased a Euro starter heat shield, but wouldn't fit around my gear reduction starter).
  19. dave80gtsi
    dave80gtsi Formula 3
    1,951
    Ohio
    Dave Meredith
    #44 dave80gtsi, Mar 15, 2017
  20. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Boy...them be fancy! Now...what about the air injection holes? Can the air injector tubes be removed and plugs installed without removing the headers?
  21. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    BTW, my take on the heat issue...Overkill! The car was designed to be operated more often than once a week or month as we drive now. So, in that short amount of operation, I can't imagine the aluminum shields being relevant, except for originality. Which is why, for the time being, I am cleaning mine up and leaving them on. :)
  22. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Also amazing, that in this one thread, a completely opposite function for the heat shields has been discussed. One...to keep heat out of the engine compartment...Two, to contain heat to hasten warmup in conjunction with the cats...
    Don't these two observations cancel each other out?
  23. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    #48 wildcat326, Mar 15, 2017
    Do you mean the "sniffer" tubes that go into the header ports, or the air injection rails that feed into the engine block? Either way, you can install plugs without pulling the headers (though you're gonna need some serious acrobatics for the front bank if the gas tanks are still in). Be very careful removing the sniffer tubes, as they rust into place and are easily damaged by turning a wrench on them. 12mm line wrench, and maybe a healthy pre-soak with PB blaster. I also used Deacon crow seal 2500 degree specilty threadlock for securing the plugs. It's pricey, but almost no other product out there has the heat tolerance for exhaust temps right when the gas exits the combustion chamber.
  24. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    #49 wildcat326, Mar 15, 2017
    Here's the heat shield I added to the starter after removing the header shields (beefier solid euro shield wouldn't fit over my new starter). Who knows if it'll make a lick of difference, but I got a chance to feel creative for a couple bucks...
  25. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    #50 wildcat326, Mar 15, 2017
