Exhaust Sound Change after 4000 rpm | FerrariChat
Discussion in '360/430' started by Emanuele Arguelles, Jun 22, 2022.
  1. Emanuele Arguelles
    Jun 29, 2020
    5
    Manny
    Exhaust sound change after 4000 rpm ?
    I have had my car for 2 years and always noticed a different sounding pitch when drive over 4000rpm, all the sudden may car doesn't do that any more? Anyone else have this happen?
  2. btshat
    btshat Karting
    Jun 10, 2021
    84
    Iowa
    Brian
    Sounds like your exhaust valves are stuck closed. The sound changes when the valves open up. I believe those are vacuum operated, so you may have a vacuum leak.
    Qavion likes this.
  3. Ferrarista98
    Ferrarista98 Formula Junior
    284
    Jason L
    Yup exhaust valve not opening
  4. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    362
    I just had to replace an exhaust solenoid valve (#178309) because of similar issues.
  5. Emanuele Arguelles
    Jun 29, 2020
    5
    Manny
    Thanks for the replies!
  6. Qavion
    Qavion F1 World Champ
    14,337
    Ian Riddell
    There are two valves. They are each controlled by their respective Left/Right engine ECUs using solenoid valves. The solenoid valves have independent electrical power sources. You will have to figure out if one or both are not operating.
    Vacuum is probably the only thing they have in common.
    Did you not get any warning lights on the dash?
  7. CoreyNJ
    CoreyNJ Formula 3
    2,476
    New Jersey Shore
    Maybe he could manually wire, not electrically but actually some wire to hold the arms on the actuator open to see if the car is louder at idle. If that works, then he can see if there is an issue with the vacuum, solenoid, or the valves themselves.
