Exhaust system jargons! | FerrariChat
Discussion in 'Technical Q&A' started by jaturon, May 31, 2005.
  1. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    I am no technical so very puzzled when reading through the exhaust system vocabularies so would appreciate if someone can elaborate the meanings and differences among the followings: manifold, exhaust, muffler, test pipes, silencer.
  2. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Manifold = headers = the tubes that extend from the exhaust ports. They come together in a collector. In a post 1980s car there is usually a catalytic converter next (or there may be a "B" pipe before the cat). Catalytic converter is there to clean up emissions. Then follows the muffler (US term) = silencer (Brit term) to slow the exhaust gases and quieten the beast down.
    Test pipes are a straight pipe that takes the place of the catalytic converter. This is done (usually) to increase performance.
  3. Steve Magnusson
    26,931
    My 2 cents:
    muffler = silencer = a passive (acoustic) device at or near the end of the exhaust flow path.
    manifold = a passive component with more flow inlets than flow outlets. Where this gets confusing is that, in the US, a thick-walled cast iron manifold is always called a "manifold"; whereas, a manifold made from thin-walled tubing is called a "header" or "tubular header". IME, in the F documentation, a manifold made from thin-walled tubing is called a "manifold".
    test pipe = a passive component meant to replace an active component (i.e., a cat or a pre-cat). Usually just a short, straight section of tubing with flanges, but not always.
  4. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    there is only one name you need to know CAPRISTO or football [arsenal he he he ]
  5. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    Am I correct to say that Manifold=header (the multi-pipes extended out from the engine, 8 in V8 and 12 in V12).
    Silencer=muffler the oval/round box-typed to quiet down the noise.
    Exhaust is the tail bit.
    Testpipe is the opposite alternative of cat. converter.
  6. DGS
    DGS Seven Time F1 World Champ
    72,942
    MidTN
    DGS
    So is "resonator" only factory-speak for "another muffler"? ;)
  7. steve f
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    to make this simple
    manifold. = fits to the engine
    cats. testpipes. = fits between the manifold and exhaust
    exhaust. muffler. auspuff. silencer. = is the big box with the tail pipes on
  8. jaturon
    jaturon Formula 3
    Oct 25, 2004
    1,599
    Bangkok Thailand
    Zane
    Thanks Steve, see... you can be helpful when you are not fishing!
  9. steve f
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    ha ha ha
